SOURCE: Kodak 5300 color ink error
OK so i found some new information that should solve the problem. The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK CARTRIDGE EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error. So to fix your problem First Remove the ink cartridges and download and install the new Firmware. Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimburstment of some sort like a free set of ink tanks.
SOURCE: Kodak Printer will not Print Red Ink
I have problems printing red ink too. What can I do to resolve this and how can I purchase a new Printhead to see if this is the problem?
SOURCE: kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
SOURCE: reset chip kodak esp 7 ink cartridge
Kodak printer works with genuine Kodak cartridges and that too brand new not refilled cartridges. The brand new cartridges have a certain code that is recognised by the Printer.Kindly buy genuine cartridges as the printer may be damaged by Non comaptible cartridges.
SOURCE: Kodak ESP 3250. Error 3527. I put new ink
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
