Question about Sharp LC70LE633U 70" inch LED HDTV 1080P Wifi Ready
Won't turn on. All it will do is flash the power light in the middle of the set.
I get a short flash and then a long flash from the power light in the middle of the set, and then it repeats. If I'm reading it correctly, the Service manual says the problem as "Lamp Error". I've ran into 2 other people with the same problem so I'm wondering if there is a common problem/fix for this?
    Top Expert:
  • Sharp Master
  • 74,887 Answers
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Posted on Nov 25, 2013
Testimonial: "As stated in the initial problem, the blinking code is a short flash, a long flash, and then repeat indefinitely. The corresponding fault code is "Lamp Error". Since I've heard of two other TV's with the exact problem, I'm wondering if a tech out there has actually repaired this fault and what's needed for the repair."
3 Suggested Answers
  • 8457 Answers
SOURCE: Aquos model LC46D64U...approx 2 years old..Won't
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Posted on Oct 18, 2010
  • 99 Answers
SOURCE: I own a Sharp Aquos
there is a problem with the power supply. most likely too much ripple that is ac leaking into the dc. I have seen the power supply repaired but it is not always possible. If there is an obvious swelled capacitor on the power supply that can be replaced this will be the best bet for repair. If there is nothing visually obvious then it gets a little harder since you won't really know which component is not working, the tv shuts down on a protection circuit so if the power supply can be repaired and the voltage "cleaned up" then the tv could work again. I have also seen replacement power supplys sold.
Posted on May 26, 2011
Testimonial: "Thank you for your insight. Much appreciated."
Sony HCD LX20i audio shelf sysyem won't turn on. Standby light flashing. Disc stuck in it.
Check the speaker wires for shorts, if okay! suspect the audio output ic's, the protection circuit won't come out of standby because there is a short.
May 06, 2012 | Audio Players & Recorders
RCA HDTV lights flashing but won't stay on
Short in power supply of set or something that it feeds--a model number would be helpful here.
Apr 23, 2012 | RCA Televison & Video
I have a Hitachi 53uwx10ba power light flashes and tv won't turn on
It is rare in this set but it indicates a short somewhere that is pulling voltage inside the set down---not a do it yourself repair unless you are a Technician with some basic equipment and a schematic diagram.
Have someone look at it from a repair shop or ?
Apr 14, 2012 | Hitachi Televison & Video
Controller won't link to the ps3 middle button just flashes as if its trying to connect. I have connected the tab coors but still nothing works.
Is the controller completely charged? If it is, then try this
1) Manually turn on your PS3 using the power button on the PS3.
2) Take your USB charger for your controller and plug it into the USB port. (Do NOT turn on your controller yet!)
3) Plug the controller into the charger that is connected to the PS3 USB port.
4) Now turn on your controller using the middle "PS" button.
The lights will flash for a few seconds, and that will sync your controller to that particular PS3 system. This might help :D
Jun 20, 2011 | Video Game Consoles & Games
I have htc p3400. i replaced the battery but my phone is not turning on. no indication that the battery is charging. (no orange light). when i switch on the charger, only once the light (red & green...
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jun 17, 2011 | Cell Phones
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
Installed a lexmark z12 printer but not the power light but the light next to it keeps flashing and it wont print
  1. Turn the power OFF.
  3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer.
  4. If it does not, close and reopen the cover:
  5. Remove the color print cartridge.
  6. Close the cover.
  7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
  8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
  9. Remove the black print cartridge and reinsert the color cartridge.
  10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
  11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
I have a mitsubishi projection tv vs 6021 manf date may 1998. I have no picture no audio. the power swithc light is green and contiously flashes. Deos any one know what is wrong with it. thank you Denna
3 things will cause this and one wil be the problem. first off flashing green indicates protection mode.
Check for a faulty vertical chip. usualy removing it and briefly turning on the set will make the set work with a line across the middle of the screen. If the chip is the fault please replace the capacitors around the i.c as the fault will reaccur.
next check the horizontal out transistor , it should not be shorted between base and collector. if so check for dry joints around flyback trany and horizontal stage circuit.
last is the 8 volt regulator that supplies the micro its power. located on the power module.
Jul 07, 2008 | Televison & Video
Blue screen with Green Star-burst image in center?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 19, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Flashing green light
Jan 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sharp LC70LE633U 70" inch LED HDTV 1080P Wifi Ready Logo
121 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
