Question about Toro Lawn Mower. 22 in. Personal Pace with Blade Stop System Self-
Toro push mover starts then quits - Toro Lawn Mower. 22 in. Personal Pace with Blade Stop System Self-
  • Toro Master
  • 2,478 Answers
Looks like a fuel problem. Remove fuel line from carb., should get fuel.
Posted on Nov 25, 2013
I have a 6.5 hp toro lawn recycle mover , that will start, but will not continue to run but a few seconds
Their's a bowl under the carburetor ,remove gas from tank or pinch gas line and remove ***** under bowl and gas will come out,clean bowl and reinstall and start it up,Trash gets in their,need a inline filter to stop it.Lowe's has them,3 dollars.
Mar 16, 2016 | Toro Power Lawn Mower
What is the size of drive belt for toro riding mover lx460
Refer your inquiry directly to Toro or a local Toro dealer.
Jul 27, 2014 | Toro Garden
Toro model 20199 timemaster mover over reving whats the cause
check the cable check that the small spring has not broken from the carby to the governor leaver.
May 31, 2014 | toro"" 2-cycle engine oil"
How to replace pulling rope in lawn mover
Go to smalleng.com they have video on how to do what you need. Check it out awesome website! The cord you can buy at any local home center. or repair shop.
Jun 08, 2010 | Toro Lawn Mower With Toro Power Tools
I have a 22in recycler lawn mover. the recoil
There is a safety brake on the handle that MUST be held down to start the engine. You must squeeze the safety agaist the handle to operate the mower. If not you will not be able to start the mower.
If your holding the safety mechanism and it is still locked then either the cable has become detached or... borken. Check to make sure the cable is connected to the safety mechanism. If it is and it still does not release then you should in all honesty contact Toro for the nearest warranty repair center.
Thanks for using FixYa.
Kelly
May 22, 2010 | Toro Lawn Mower With Toro Power Tools
Starter rope needs to be replaced on torro mower
yes you can fix it your self go to your local home center buy a replacement mover cord. remove the cover off the of the mover. remove the old cord and wind the new on on to the spindle. remembering to load through the top cover hole first.then place the cover back on. next put the pull handle on and give it a go.
Mar 25, 2010 | Toro Lawn Mower With Toro Power Tools
Toro 6.5HP lawn mover it starts the it stops.
CHECK FOR WATER. DRAIN TANK AND REFILL MAY HAVE TO DRAIN CARB
Sep 24, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn mover 605 recycler
Your carburetor is definately dirty or it needs new gaskets, screen, and needle valve( carb. kit). Is this something that you think you might want to attempt? It really isn't that difficult. Can be done in about an hour. If so, let me know and I can give you a few tips.
Jim
May 28, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn mover
If you mean that you prime the engine, it starts then dies a couple of seconds later, your carb needs to be cleaned/repaired.
May 24, 2009 | Toro Lawn Mower With Toro Power Tools
My toro lawn mover won't start after a year not in use. Change air filter and spark plug, still having problem to start the engine. please help
Hi radevils. Here is what I do. Get yourself some quick start. It's like either and nitro! Make sure you have new gas not last winters. Check for condensation also.Spray the quick start into the removed filter directly into the carbuerator once it fires it is self priming and then gasoline takes over. If you still have a problem you might have a clogged .jet If you have a compressor place an air hose in the gas resovoir and flush the gasline line clean. That should do it. Good luck. Let me know if this helped. skypope@live.com
May 02, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower. 22 in. Personal Pace with Blade Stop System Self- Logo
89 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
