Question about Siemens Ovens
Siemens oven modelHB55M550B NOT HOLDING TEMPERATURE
WHEN TEMPERATURE SET ABOVE 160DEGREES WILL INTERMITENTLY DROP BACK TO 160DEGREES
4 Suggested Answers
  • 139 Answers
SOURCE: Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
Posted on Aug 28, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: when oven is set at certain temperature, it goes
Bad thermostat, Your thermostat needs to be replaced. That is causing your temperature to go higher then what you call for
Posted on May 17, 2009
  • 4 Answers
SOURCE: ovens wont heat to temp
What model oven or ovens? Is it a double stack or single? If double does it happen to both or just one?
Posted on Sep 12, 2009
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
I just had my igniter replaced on my Kenmore oven, now the temperature foal won't go above 260°, the oven is heating very hot, but the dial won't go higher. Can this be reset?
Your oven is probably in Celcius mode - try holding bake (or broil) for 3 seconds (after cancel) to toggle. If not, the owners manual will tell you how to switch back to degrees F.
Sep 16, 2015 | Kenmore Ovens
I cooked something for 40min as it said and at the end it was raw, I had to pur it on further 40 min this is a conventional oven
It could be your oven isn't as hot as you set it. Get a thermometer and check it. It could be the "something" you cooked was larger than the recipe was expecting... It's cooking, you have to adjust. It could even be your altitude above sea level. Higher, water boils at a lower temp, things take longer to cook.
May 15, 2015 | Ovens
Why can't i set the temperature on my frigidaire oven model # FFGF3053LSC? Burners work. I have unplugged it and plugged it back in. I have checked the circuit breakers. It still does not work. ...
Good Afternoon Annette,
I see that you are having trouble setting the temperature on your Frigidaire oven, model# FFGF3053LSC, even after resetting it by unplugging it. First I would make sure that you are able to set the clock as well. Try setting the clock by pressing the clock button and then pressing and holding down the up or down arrows to change the time. If you are able to do this and not set your oven, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why you are unable to set the temperature for your oven. Hope this helps.
-Best Regards-
WP
Apr 25, 2014 | Frigidaire Ovens
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
I can't get my Siemens oven self cleaning feature to work. I first set the dial to the cleaning position. I then try and set the temperature dial. As soon as I turn the dial the beeper sounds with the...
You have to take everything out your oven all the removables , then turn knob to pyrolyse and the other knob to 1 for mild cleaning 2 for medium and 3 for heavy cleaning
Jan 10, 2011 | Siemens Ovens
Manual for HB56m550B Siemens Double
http://www.espares.co.uk/part/cookers-and-hobs/siemens/hb56m550b/01/p/1092/161/0/657527/766592/instruction-manual.html
you can buy a manual from the above link, costs less than £10, sorry couldn't find a free download
Dec 05, 2009 | Siemens Ovens
Ovens wont heat to temp
The reason to this problem can be due to the faulty
thermostat.
Sep 02, 2009 | Lincoln Conveyor Oven - 1133-000-A
Ovens Logo
100 people viewed this question
Top Siemens Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Siemens Oven Expert? Answer questions, earn points and help others
