Question about Proform 625 Front Roller Model Pftl62510
I have a Proform 625 treadmill that I had to move. I unplugged the unit, slid it to where I needed it to go and plugged it back in. When I did so, the console powers on, but the display flickers and the lights around the LED track light up randomly. When I insert the key, nothing happens. I have tried unplugging and replugging and I have cheked to make sure that the circuit breaker is on. I havn't seen any other info. describing this problem anywhere, any thoughts would be greatly appreciated :)
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
You can try the following:
a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet (see page 9). Use only a single-outlet surge suppressor
that meets all of the specifications described on page 9. Important: The treadmill is not compatible
with GFCI-equipped outlets.
b. After the power cord has been plugged in, make sure that the key is fully inserted into the console.
c. Check the circuit breaker located on the treadmill
near the power cord. If the switch protrudes as
shown, the circuit breaker has tripped. To reset the
circuit breaker, wait for five minutes and then press
the switch back in.
d. Check the on/off switch located on the treadmill near
the power cord. The switch must be in the on posi-
tion
Posted on Nov 25, 2013
4 Suggested Answers
SOURCE: Treadmill LED Track does not go to start with key inserted
I pulled the safety switch out, and the elevation is stuck on 10 degrees
Posted on Jan 24, 2010
maxtreadmill
  • 832 Answers
SOURCE: power stopped while using treadmill
May be the Motor Control Board that gave up the ghost go to iconservice.com go to click on replacement parts input manufacturer and brand name look for controller click on it it will tell if it is in stock and how much
Posted on May 14, 2010
  • 15 Answers
SOURCE: belt won't move
does is just not move when you're standing on it, or not even move when you're not standing on it. It may be a simple belt adjustment or if the motor is running but there's no track movement you may be looking at a loose/broken drive belt. Take the cover off, start it up and look at the motor/drive pulley assembly. If the motor turns and the front roller doesn't, tension the drive motor by moving it back. If the front roller turns but the track doesnt, do a track adjustment as per your users manual.
Posted on May 27, 2010
I have a proform 505cst. When I push start, the motor seems to short out. The motor controller LED blinks four times.
Customer Reviews: Proform 505 CST Treadmill (2014 Model)
www.amazon.com/Proform...Treadmill.../B0048HS02...
Amazon.com, Inc.Start here. ..... I was worried it would fall out with the vibration but, as I mentioned earlier, ... The 10% incline and the max speed on this unit more than serves the need ...The sound from the belt and motor is very acceptable (but then its only been .... This morning i was using it for the first time and this treadmill seems great.
Amazon.com : Proform 505 CST Treadmill (2014 Model ...
www.amazon.com > ... > Cardio Training > Treadmills
Amazon.com, Inc.Start here. ..... The ProForm 505 CST Treadmill is designed to get you moving. ....This morning i was using it for the first time and this treadmill seems great. ... I would suggest for anyone that gets this to open up the motor cover and take a look at ...graphics on the instruction manual and figure out what piece went where .
505 CST ' Proform
Jan 11, 2016 | Proform 505CST Treadmill Walking Deck
Proform tredmill starts runs 10 sec and beeps twice and stops
I would suggest unplugging the unit from the wall and waiting 30 second and plugging it back in. Then go to where the AC cord enters the machine and look for a reset button or switch. Put it in the reset position and see if this solves the problem. Depending on model the reset may be on the bottom of console.
Dec 15, 2013 | Proform 520 Trainer Folding Treadmill...
Proform crosswalk, the walking belt will not go no matter what speed its turned to. It will move if i pull it and register speed on console but will not go by itself.
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console.
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_15_2011_8_35_57_am.gif11_15_2011_8_36_26_am.gif
Sep 15, 2011 | Proform Crosswalk 500 Treadmill
I have a proform 730 siteline, model PFTL 70070 and the electronic display is malfunctioning. Shuts machine off, sometimes it resets itself, etc. I've checked power supplies, motor control board, etc....
Optical Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
Sep 14, 2011 | Proform 730 Folding Treadmill Model...
I have a proform 730 siteline, model PFTL 70070 and the electronic display is malfunctioning. Shuts machine off, sometimes it resets itself, etc. I've checked power supplies, motor control board,...
Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk. 11_10_2011_6_11_10_pm.gif11_10_2011_6_11_30_pm.gif
Sep 10, 2011 | Proform 730 Folding Treadmill Model...
None of my keys in my proform 500i woek excep the 3mp and the 9 mp no even the start works
aFTER YOU TEST THE SENSOR DETERMINE IF THERE ARE FAULTY AND REPLACE.
Mar 19, 2011 | Proform Crosswalk 500 Treadmill
My treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 08, 2010 | Proform Crosswalk 500 Treadmill
Incline goes up and down constantly. Console doesn't work
It sounds like it's in calibration mode and you need to let it go all the way up and then down and set itself. If you have done that and it keeps going into that mode then you probably pulled or moved some wiring while moving it.
Sep 15, 2017 | Proform iLog 750 Treadmill
Treadmill will not maintain the correct speed.
You can get a book by calling 1-800-999-3756. The treadmill you are usine in a cheaper model. the motors on those units are not that strong. when you incline your unit gravity make the belt move faster. Remember incline put a lot of pressure on you lower spine. This can cause injury for some.
Jan 29, 2009 | Proform XP Weight Loss 620 Treadmill
Proform 625 Front Roller Model Pftl62510 Logo
154 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
