Question about Samsung Digimax S500 Digital Camera
Camera will no power up
My camera makes 3 beeps and does not power.Can you please tell me the reason why this is happening.
YEAH!  I too had the same beeping problem and the lens was stuck so I pulled on the silver part a bit around the glass and it opened and works now.  Thanks!
Posted on Oct 31, 2007
Is the foces lens pulling out if not turn it on and pull it out manuely that should work
Posted on Oct 21, 2007
I had the same problem and even sent the camera out to be repaired. It worked for about 2 weeks and then the same thing happened. I was looking on the internet for help and someone said to pull on the silver part around the lens because when it shut off this part was still sticking out some. I pulled on it a little bit and the camera started working again.
Posted on Oct 19, 2007
Shutter button does nothing when pressed halfway, will not focus automatically. It doesn't make the beeping noise, no green box, nothing happens! I can press it all the way and take a picture, but t
Please check if yu did set the camera in AF mode continuous. In that mode, the camera is focusing on whatever is aimed at. Even when the shutter button is not pressed, allowing you to shoot without missing opportunities.
The mode where you see the camera focus when the button is pressed half way, is called single. This setting will conserve battery power.
Look in the manual under Switching between Focus Settings. I can't tell you war page that is for your camera, in mine it is page 100.
On the last pages in the book are all settings for each shooting mode.
Dec 01, 2013 | Canon PowerShot SX160 IS Digital Camera
When the power is turned on, the lens stays in the camera, it starts beeping and it tells you to turn the power off and on again
1) Remove SD Card.
2) Remove Battery.
3) Hold power button for 10 seconds.
4) Install Battery.
5) Attempt to power on.
6) If works, reinstall SD Card and you're ready to go!
Thanks and please rate if this helps you!
Mar 29, 2011 | Sony Cyber-shot DSC-N2 Digital Camera
Dropped Samsung S630 digital camera. Lens was extended and after hitting hardwood floor became bent. Is bent slightly and stuck in out position. Camera makes 3 loud beeps when powered on and immediately...
This exact thing happened to me. The 3 load beeps is the camera warning that the lens has not been collapsed. Unfortunately in these little cameras everything is so tightly fitted and assembled that your best bet is to either replace the entire lens assembly or the camera itself. A quick search on eBay turned up no results for replacements parts so unless you have warranty, you may need to replace the camera. :(
Feb 01, 2018 | Cameras
My Camera Won't Charge!!!
Your batteries are dead. You can buy them buy doing a search for your model number on your camera, and it will tell what batteries to use.
Nov 30, 2009 | Oregon Scientific DS6310 Digital Camera
My camera will not immediately take a picture.
The beep and no shutter action is usually because the auto focus is not focused. If you are using a zoom lens try backing up or unzooming a little.
Dec 20, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Samsung digimax s700
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Samsung Digimax A400 Digital Camera
Samsung S750 makes 3 beeps
Try Removing the Memory Card and Batteries For Ten or more Minutes, this should fix the problem
Cheers,
Mack
Apr 14, 2008 | Samsung Digimax S630 Digital Camera
Switches off when try to take pics
i came to know the reason why this happens. the CCD is damaged. It will take around Rs2000 to repair the cam if you are in India.
Apr 18, 2007 | Fuji FinePix F401 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Samsung Digimax S500 Digital Camera Logo
87 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
