Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Toshiba 4hl196 screen turns blank on setup scan
Screen turns blank on setup scan at 85% and goes blank above channel 14-5
  • 115 Answers
Check aft circuit
Posted on Nov 26, 2013
Trying to add an additional computer to the router: used the cd to add computer and ithe screen comes up and option add computer is hit, a message comes up that says it will need to be reboot after...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network on all your computers ( Wireless )
Let me know if it works
Regards
TOM
Dec 24, 2010 | Belkin (54G F5D7230UK4) Wireless Router
I have a cable coming from the wall, and when I hooked it up to my TV Panaconic 42'' viera Just bought the TV today. . the screen is black and keeps saying No signal.... what could the problem be? Just had...
You either set the options incorrectly when running the "First Time Setup" or you skipped the first time setup entirely. Even though the cable works with your older TV, you still need to setup your new TV correctly to receive the cable feed.
The quickest way to do this is run the setup manually from the menu as follows:
1. Turn the TV on
2. Press the "MENU" button on the remote
3. Use the DOWN arrow key to highlight "SETUP" (the arrows are the big ring button around "OK")
4. Press "OK" to enter the SETUP MENU
5. Use the DOWN arrow key to highlight "PROGRAM CHANNEL"
6. Press "OK" to enter the PROGRAM CHANNEL MENU
7. Use the LEFT/RIGHT arrow key to ensure "CABLE" is highlighted
9. Use the DOWN arrow key to highlight "AUTO"
10. Press "OK" to enter the AUTO SCAN MENU
11. Highlight "ALL CHANNELS" using the UP/DOWN arrows
12. Press "OK" to start the AUTO SCAN
The scan may take several minutes to complete.
13. Highlight "APPLY" using the the LEFT/RIGHT arrow keys.
14. Press "OK" - all of the scanned channels will now be saved.
The TV should now return to viewing mode and you should be able to watch cable on your new TV. If the TV does not automatically exit the menu, simply press the "EXIT" key on the remote, next to the MENU button.
Please run through the above steps and if you are still unable to get the cable channels on your new TV, please post back for further assistance.
Regards,
BElectric
Dec 16, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Looking for remote code for toshiba SD-P4000
Hello
Four digit Toshiba remote codes are
[0159 _ 0178_ 0109_ 0120_ 0181_ 0105_ 0049_ 0095_ 0170_ 0260_ 0358_ 0394_ 0924_ 0012_ 0095_ 0117_ 0141]
Three digit Toshiba Universal Remote Codes are
[013/ 049/ 089/ 105/ 109/ 117/ 118/ 120/ 159/ 178]
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Nov 19, 2010 | Toshiba SD-P4000 14 in. TV/DVD Combo
Somebody logged into my belkin router and now my belkin name router changed to toshiba pc (the pc used by guest) and i cannot connect to my wireless anymore. thank you
Step 14 : Now Scan and connect to this network ( Wireless )
Sep 13, 2010 | Belkin (F5D5231-4) Router
White/Grey screen with non-HD channels
I removed the HDMI cable and connected with component video and rca audio. No more white screen.
Picture quality looks good. I don't know if it's as good as HDMI, but then I don't need to reboot the TV three times to get to teh on-demand menu... Grrrrr....
I am trying to contact Toshiba on this as well. I have seen several reports of this problem on the web.
Dec 04, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
Magnavox tv has cable channels 2-13 only. Lost original remote. Using a universal remote. Tried to auto program. It started scanning but when channel 14 came around, just fuzzy snowy picture all through...
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Nov 12, 2009 | Televison & Video
I lost my remote and only need it to set the TV to channel 3 for cable. Is there any way to do this manually?
If you are able to access menu and channel setup, you can go into autoprogram and it will scan all available channels and store them.
Otherwise you can get a cheap universal or even original replacement remote
Oct 22, 2009 | Toshiba MD14FN1 14 in. TV/DVD Combo
Scrren Goes Blank after the booting
Hello. Put your primary boot to hard disk.
Feb 22, 2009 | Toshiba Satellite M115-S1061 Notebook
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
35 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
