Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Have a HP 9205 Pavilian( Vista)& Mashita UJ-851S will not regconize blank DVD to make recovery disk.Can anyone help??
  • chevit May 09, 2009
    Hi, sodeep! Thanks for your response. I'm not trying to burn!
  • 3,267 Answers
Try to do so from Nero(ver. 8 & above) burning software and as a second thought why don't you try to do so on a CD, if it's space suffices.......sodeep
Posted on May 08, 2009
  • Sudeep Chatterjee
    Sudeep Chatterjee May 10, 2009
    Even this software helps to read any CD/DVD. Alternatively use UltraISO or Alcohol Software for reading CD/DVD..sodeep
My toshiba a215-s4807 satellite, with windows vista won't boot with my mat uj-851s cdrom drive hooked up. I had the same problem with my older version, the mat uj-850s but just figured it was brok
You can change the boot up order of devices in the BIOS. Go into the BIOS setup then to Boot up order and move the CD/DVD dirve as the first boot device and the hard drive as the 2nd boot device.
Then you boot up with a disc in the CD/DVD drive.
May 01, 2012 | Computers & Internet
My HP Pavillion dv6560oe can not install the driver for the MATSHITA DVD-RAM UJ-851s ATA device. The device has stopped functionning (code.10)
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Apr 26, 2011 | HP Computers & Internet
Cd/dvd drive stopped working - matshita dvd-ram uj-861h ata devic
Hmmmm see try cleaning the temporary files which are stored ...I mean files ready to burn to dvd .. You can find them when u click dvd drive with out any disc in it.
Create a new user account and then remove all the burning software and then reinstall it.
If still doesnt work tough luck dear .. Reformat the hdd might help.
Mar 31, 2010 | Panasonic Computers & Internet
Problem with Matshita BD UJ-220 firmware
Had same problem under windows 7. Try and run the firmware upgrade program in windows vista mode. Worked for me.
Dec 07, 2009 | Sony Computers & Internet
Matshita dvd-ram uj-851s ata device vista
Foolw the guide below, this will edit the registry, making the device visible and useful again.....
Windows Vista
1. Click Start
and then click All Programs.
2. Click Accessories, and then click Run.
3. Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
4. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5.
6. In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
7. On the Edit menu, click Delete.
8. When you are prompted to confirm the deletion, click Yes.
9. In the right pane, click LowerFilters.
10. On the Edit menu, click Delete.
11. When you are prompted to confirm the deletion, click Yes.
12. Exit Registry Editor.
13. Restart the computer.
Oct 16, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Cant burn cd - error 4450
So first off, you have a problem with your registry. This is a problem seeing as you are not an administrator and the only way to fix the registry is to be an admin. So if and/or when you are and administrator simply download the RegCure registry repair tool. also get a SpyWare scan as well and update all your system drivers. That should do the trick or just any old program off the internet that cleans out your registry really. If you want to edit the registry manually just hit start>run and type in regedit and mess with it there. unless you know what you're doing i wouldn't recommend messing with the registry though.
Jun 14, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
I need find driver on Mashita dvd ram UJ-850s on laptop Acer Aspire 3100.
http://www.driverstock.com/Acer-Aspire-3620-driver-download/4-21-12856/index.html
May 02, 2009 | Acer Computers & Internet
Matshita DVD-RAM UJ-851S
here's the fix
http://msbin.com/kb/entry/53/
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. On the File menu, click Export.
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
Note If this data type is missing, go to Method 2.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit Registry Editor, and then restart the computer.
Dec 24, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Drive cant write any disc
If the unit was working ok and suddenly the unit stop to read the blank disk, the problem could be related to a dirty lector (need to clean) or unit firmware (need to be updated)
In that case you can update your firmware here:
http://drivers.softpedia.com/progDownload/Matsushita-DVD-RAM-UJ-840S-104-Download-14615.html
Remember
1) You have to use a blank "recordable disk" to allow your drive write a disk
2) Not all disks are compatible
3) Try differents brand
4) Clean your drive lector
5) Update your firmware
Oct 24, 2008 | HP Compaq nx6310 Notebook
ERROR CODE 39
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Jul 22, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
93 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
