Question about Coleman Heating & Cooling
I have a dgat056bdd unit and everything work good ,it fires up for about 5 seconds then flame out,,,it does this twice then shuts off giving error code of one blink what is this ??
My dgat056bdd unit is acting funny it worked fine last season but first fire up this one and the furnace wont stay lit,,it is an electric ignition gas furnace when it does this it gives an error code of one blink,,
  • Coleman Master
  • 15,557 Answers
The flame detector is dirty. Look for a wire that pokes out into the area where the flame would be. Clean it off.
Posted on Nov 25, 2013
WebTeligent
  • 42 Answers
SOURCE: No heat, trouble shooting light has continious flash.
There is a vacuum sensor on most units tied from the exhaust gas fan to the sensor. Does the unit try to start? If the unit's exhaust fails to pull the switch it will turn off after about 30-45 sec after starting. "IT" thinks it's not exhausting and stops to keep from overheating. Do you have this exhaust fan and rubber hose to sensor? Can you see if that fan is turning on start?
Posted on Nov 10, 2007
  • 96 Answers
SOURCE: furnace is not staying lit
if the main burners are firing but goright out it could be the flame sensor which is a straight wire with one wire going to it you can clean it with steel wire or fine sand paper if not check the flashing code on the control board
Posted on Dec 25, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: my heat n glow fireplace comes on fine with all
You may have a few sensors, one may be a thermopile that energizes the pilot. It is a very thin but long bulb located in the pilot flame. Then you may have something called a thermopile which is also located in the pilot flame that energizes the main gas valve. It is a larger diameter bulb and will have metal wrapped wireg going to the gas valve. If the pilot stays on but the flame goes out under the logs, change your thermopile and look for a bad connection at the gas valve or switch. If both the main burner and the pilot goes out you may have a gas valve problem or a plugged vent pipe. If the flame just disappears it is most likely a gas valve. If the flame changes colors and lifts from the burner, that is a sign of a plugged vent. Good luck.
Posted on Nov 05, 2009
  • 288 Answers
SOURCE: Goodman furnace burner ignites then shuts off in about 10 seconds
if you have replaced the flame sensor and it will not stay lit, the draft safety switch may be opening. It works on positive and negative pressure created by the inducer fan motor.You may have a restriction in your heat exchanger or if is a high efficiency furnace, it may not have the drain tube installed properly with a trap. The trap works just like the trap under your sink and if water isnt in the trap, the pressures can be effected enough to open the draft switch(some call it an air pressure switch)
Posted on Jan 07, 2010
  • 39 Answers
SOURCE: I have a Rheem Criterion II Gas Furnace that has
Turn off the power to furnace.
on the last burner to light there is a small metal rod in front of the burner. This is a safety called the flame sensor. It is dirty. Unscrew it from the bar ( 1 Screw) unplug the connector wire from it and clean it with steel wool. it will be kind of burnt. Plut back in place and turn on the furnace to cycle.
Posted on Apr 04, 2010
Pool heater comes on and gas enters unit for about 5 seconds and then the gas shuts off. natural gas
This could be the flame sensor. If you can look into the firing chamber there should be a steel rod about 5" long that dangles into the gas fire jets. Turn off the unit. If you take the fire sensor out and gently rub it with steel wool and replace it, it may start working again. If it does, great, but order a new fire sensor and replace the old one when it comes in. They are very cheap.
May 05, 2017 | Pool & Spa
Working on a Kenmore 110.79902890 gas dryer. Unit has intermittent heating. Setting doesn't matter. I have metered the fuse, flame sens., hi limit therm., and replaced the coils on gas valve ... Everything...
I know of a place that offers <a href="http://www.quality-appliance.com/Services/">dryer repair in Nampa, ID</a>. I would try contacting them. I'm sure they could help you out.
Oct 05, 2013 | Dryers
Heater fires and shuts off repeatedly. reads CHF. Has good flow.
error code should be inside heater make shure you have adequate gas pressure also sounds like bad flame sensor when flame sensor doesnt sense flame it will shut off after 7 seconds
Oct 02, 2013 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Ov300g flame no call for heat
The ignition module could be faulty, could be a loose wire, bad control board, bad temp probe, this is something you'll want a technician to take a look at, you'll spend more money trying to fix it yourself.
Feb 24, 2012 | Baxter OV300G Stainless Steel 27817 Watts...
Furnace will start and then shut of and will come back on a second time and then go out.If I shut down thermostat and turn themostat back on it will do the same thing over again but will not continue to...
If this is a gas furnace it sounds like you have a polarity issue (line and neutral swapped) or you do not have a good ground to the unit. The newer units 1998 on up are polarity sensitive and require a good ground for its controls and safeties for continuous operation. Checking these things should resolve your problem. After it tries to fire twice without the flame sensor sending back a flame sensed flame signal it will lock itself out until the call for Heat is not present which will reset the control board.
Sep 23, 2011 | Heating & Cooling
Rheem RTG-64DVN model, brand new unit installed during the weekend. fired up but shout down automatically within about 5 seconds. showed error code 12.
contact your gas company if the error code is "12," indicating that the gas supply was interrupted.
have a good day !! In LP models, the 12 error code may also appear if the LP gas supply has gotten low. To clear the code, replace or refill the LP gas supply.
go here for a list of codes for rheem tankless water heaters-- www.ehow.com/list_7833182_error-rheem-gas-water-heater.html
May 09, 2011 | Rheem Tankless Hot Water Heater...
Paloma (Rheem) tankless water heater 7.4 gpm 199,000 btu outdoor unit. Red light is blinking on pc board. unit fires up for approx 2 seconds then shuts off, then cycles once more for 2 seconds and shuts...
i think your flame sensor is bad but you will need to confirm that with rheem i am unsure what the c7 is for but code 12 is flame failure and there could be carbon build up on the flame rod...
Aug 06, 2010 | Rheem Tankless Hot Water Heater...
Minimax NT Heater will not fire. Everything about the unit seems to be running fine but it simply will not fire. The blower continues to run even though it does not light. No error codes are shown....
Check the limit switch. It may be stuck open. TAP the cover with a screwdriver. If the unit starts, the limit will be the problem. You should also check the flame sensor. The unit may try to start but the flame sensor doesn't see the flame, the unit shuts off..Good luck...Lee
Nov 05, 2009 | Pentair Minimax NT Heater
Minimax NT 400 TSI Heater problem
I bet that your 15 seconds of flame are more like 7 seconds. The time is very important. If the flame is not recognized after a specific time the valve is shut off. If the flame sensor is GOING bad but still make some rectification then you may get the issue you are having. I would start with the flame sensor and work from there.
May 03, 2017 | Pentair MINIMAX NT TSI IGNITER
Kenwood AR 404 burning w/ open flame.
You are literally playing with fire. Obviously the unit is in dire need of service! Please, take unit in for check out by a pro/tech
Apr 27, 2008 | Audio Players & Recorders
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
