Question about Whirlpool RBS275PD Electric Single Oven
BAKE & CLOCK BUTTONS DO NOT REGISTER WHEN PUSHED- CLEAN & BROIL BUTTONS ARE REGISTERING
    Prodigy:
    An expert who has answered 500 questions.
  • Whirlpool Expert
  • 650 Answers
If your oven is a touch pad model then the pads are bad. the touch pad assembly will need replacing. Sometimes you can remove the ribbon cable and reinsert it. It sometimes will make them work but not very often. Make sure the power is off first. Remove the control panel. You will see the ribbon cable. There will be small tabs on each side of the connector plug carefully unclip these and remove the cable and reinsert it. Be prepared to replace the panel.
Posted on Nov 26, 2013
SOURCE: Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Posted on Feb 17, 2008
Fixe_You
  • 1800 Answers
SOURCE: Display is in LOC but door is not locked. Can't set temp. to bake
check if u can find any reset procedure.
alsio u can let it with no power for 30mi that will reset it Int.Memory.
Posted on Feb 16, 2009
SOURCE: used the auto clean feature on my oven. now the
sorry idk
Posted on Nov 21, 2009
SOURCE: I have an RBS275 built in electric oven and when
My builtin whirlpool oven makes a humming noise all the time. It sounds like a fan is going on.
Does anyone else have this problem?
Posted on Jan 24, 2010
heatman101
  • 43501 Answers
SOURCE: After using self clean oven will not heat
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 11, 2010
Why does only broil come on when i push the bake button?
Bake and broil elements can be tested with an ohm meter for continuity. There is a relay in control / clock for both bake and broil elements. If elements test good, then those relays need to be tested for voltage.
Sep 16, 2017 | Ovens
Bake, broil & clean buttons do not function, all others (timer, cook time,end time, clock) work fine. Therefore I cannot light the oven. The stove burners work fine.
check the main power terminal block and make sure the power is correct.if the power is correct then you will need to change the main control board.how ever unplug the unit and check all the wiring to the control board and the bake and broil elements.if the unit is gas then you may need to replace the ignitor unit if it does not draw enough power during the light up it will not open the gas valve.replace the main main control board still applies if the other items check out fine.
Nov 03, 2010 | Kenmore Ovens
Self Cleaning Amana wall oven installed in late 1999 Has worked very well until recently when buttons are pushed to do bake, broil, time etc it won't work when time button is pushed to start. What is...
TRY THIS... If the buttons are "stuck", the glass panel may have shifted to the right or left causing the holes in the glass (through which the button protrude) to rub against the glass. VERY CARFULLY try to shift the glass so the buttons are centered in the holes.
Oct 31, 2010 | Ovens
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Bake and Broil Elements not working, all top elements are O/K and Elerctronic read out also O/K
Hi
Thanks for using FixYa. If neither the bake nor the broiler heating elements heat, but the range burners still works, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for manual", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Kenmore Ovens
CPS227W Dacor double wall oven from 1995. Problem is common to both upper and lower ovens on any cooking mode (broil, bake, etc). Turn on, set temperature, hear a relay click on, then about 15 seconds...
I have the same problem, however I found that if I just hold the Bake, Broil.ect button in until you hear the relay click then the oven functions normally.
Sep 26, 2009 | Ovens
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
Feb 16, 2009 | Whirlpool RBS275PD Electric Single Oven
Instructions for Frigidaire oven missing.
I found the manual online. Apparently my unit is malfunctioning and should work by just pressing bake temp and then selecting the temp...
Dec 02, 2008 | Frigidaire FEB27S5A Electric Single Oven
Can't turn off my Kenmore 47833
check to see if the connections are good on the back of the control board and if they are good then you need to replace the control board (clock) assembly let me know how you make out
Sep 01, 2007 | Kenmore 47834 / 47832 / 47839 Electric...
Whirlpool RBS275PD Electric Single Oven Logo
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
