Question about Uniden SMU250KT (99 Channels) 2-Way Radio
Programming what cable is needed for programming
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 36 Answers
The same as you use for data transfer
Posted on Dec 03, 2013
How to program
You will need the programming cable and a computer. The cable is a USB serial interface lead that plugs into the speaker microphone socket. You will need to get familiar with a program called CHIRP.
REMEMBER, PROGRAM ONLY CHANNELS YOU HAVE A LICENCE TO TRANSMIT ON (CLASS LICENCE FOR UHF CB) OTHERS CAN BE PROGRAMMED FOR LISTENING ONLY.
Sep 10, 2014 | Radio Communications
What software is required to program a motorola cp125
Motorola programming software is proprietary to them, radio dealers must pay for a subscription to each software. You would need a programming cable, radio interface box (RIB), and RVN4196 software subscription. Your radio should be programmable at your local dealer for a reasonable fee.
best regards
May 22, 2012 | Motorola Radius Cp125, 4 Ch, W Chargers,...
I cannot briing in a picture. Upper left corner of picture says it is on channel 4...upper right corner "no programs availab le"How do I program TV to bring in a picture.; I am on Insight Cable.
Typically the cable box is the source of your channel programming. If you're getting the "no programs available" you need to find if that notice is from your TV or your cable box. Check the connections from your cable source to the cable box and from the cable box to your TV.
Make sure that your TV is set on the proper source selection. Most Projection TV's have several (ant, cable A, B, DVD etc) check your on-screen menu for which one and make sure the cable is connected to the proper input ports on the back of your TV.
If you disconnect the cable between the tv and cable box and still get the "no programs "...then it's your TV.. but if you lose that warning, then it's coming from the cable box... If after checking your connections, disconnect the power to your cable box and let it sit for 5 minutes and then reinsert the power to the box and see if you get a reset with signal...... If nothing after all this, contact your cable provider to check their signal to your house and also the cable box.... Hope you have quick success on this!
Dec 17, 2009 | Televison & Video
Cannot get the cable to show on this tv
If the TV is connected to a cable box using 1 solid cable (RF ANT) your needs to be on either channel 3 or 4.
If the TV is connected to a cable box using 2 or 3 RCA cables, your TV needs to be on AV 1, 2 or 3.
If the TV is connected directly to the cable, go to MENU set the TV to cable and program channels.
Good luck
N Sabre
Nov 07, 2009 | Quasar SP-3234 TV
Need directions 4 rca rcu 800b [rcu800-or rcu403 to program code
RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
RCA Cable Box Codes: 000,027
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
Special Notes:
RCA, GE and Proscan Brand Devices:
Many of these devices (TV's and VCR's) will not need to be programmed. In the event that programming is required, the code search method is suggested.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Sep 07, 2009 | RCA Universal Remote Control
Programming cable
The photo of the GP328 resembles the HT750 offered in the USA. If they use the same programming cable/equipment you would need the AARKN4074 Programming Cable, which requires a RIB (radio interface box) RLN4008.
OR you can use the RIB-less cable RKN4075. There is also a cloning cable available, part number RKN4073.
All of the above are offered on the assumption the GP328 and HT750 radio take the same cables. You might check with your local Motorola dealer to be certain.
May 31, 2009 | Radio Communications
Timed recording with cable (new)
If you're referring to programming your VCR for recording, that works just like it did before the cable box was installed, but with two major differences.
The first difference is that the VCR must always be programmed to record on the converter box output channel. Usually this is channel 3, but may also be channel 4. The cable box selects the channel from the cable system, but it's always outputting to your TV on the same channel. That channel is what the VCR needs to record from.
The second change to programmed recording is that you can't program your VCR to record programs on different channels. The reason is because, as mentioned above, the VCR is actually recording from the cable box which is always on the same output channel. Unless you are home to change the channel on the box, you're stuck. For example, if you want to record a show at 10PM on channel 8 and another at 11 on channel 26, those are the cable channel numbers. The box output is channel 3 (or 4) in both cases. The VCR can't switch the box for you. It's only going to record the program on the channel you selected before you left home. You also need to leave the cable box turned on, but the TV can be off. This is probably the thing most people find confusing about dealing with a cable box.
Now having said all that, some brands of cable box do include a timer feature of their own that allows you to program the box to switch channels. This feature is used in conjunction with timer recording on the VCR. You still always program the VCR to record on channel 3 (4), but now the box can be programmed as well to switch to the channel on the system you want to record. This allows you to get around the limitation described above. If your box offers this feature, it will be accessed through its setup menu using the remote control. Ask your cable company if this is available if it's not clear from the setup menus or instructions the installer left you with.
May 12, 2009 | Emerson Televison & Video
How to program a motorola gp328 vhf 2 way radio?
i have program kit and software i need program for emergency siren what i have to do
Jan 04, 2009 | Motorola Radio Communications
Program satelite or cable
you are not specific as to programming cable or satellite .if you have cable tv with a cable box there is no need to program tv channels.the tv should be left on channel 3.check the back of the cable box & tv it may also be connected thru rca/s-video or componant cables meaning the tv should be on a line in/source ,or video input. for a tv without a cable box
you can do the auto or manual programming. no need to be on channel 3. if you have satelllite tv you need the box to hook up to your tv.you cannot bypass this box unlike cable tv.also check the back of the box for the other possible connections
good luck
wg
Jan 28, 2008 | JVC AV-27D202 27" TV
I need to program my tv is cable ready
plse help, i have a cable ready tv hooked up to the coax out of the wall directly to tv and only get 1-13 channels??????
Sep 11, 2007 | LG 42LC2D 42 in. LCD HDTV
Uniden SMU250KT (99 Channels) 2-Way Radio Logo
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
