Question about Hitachi 57G500 57" TV
Trying to swith to cable mode
I have no manual or orginal remote how can I get a menu screen to appear?
Lift lid on front of tv just above the red power light. press the far right button labelled select. press exit to remove menu. use up and down arrows to navigate. you can download user manual from hitachi.com website.
Posted on Dec 17, 2007
SOURCE:
Emerson mdl#ewf2703, do not have the remote, need to swith mode to video
As there is no "Menu" button to this set at its front panel, you must have its remote control to select inputs.
May 20, 2012 | Emerson EWF2703 27" TV
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
How do I adjust the screen to the TV - I've looked in the MENU options and can not adjust the height of the screen. In other words - I can not read the score ticker on the bottom of the screen
Your sanyo tv may have service mode adjustments. It can be taken according to the sevice code options, which can be get from service journals available in the market. no menu adustment is there to adjust the picure linearity, height , subbrightness control so on. All adjustments are coded and have critical measurements which can be adjusted through service mode with the help of remote control. The remote control should be orginal to access service mode. Duplicate may not work properly.
Oct 14, 2010 | Sanyo DS24425 24" TV
The word "Factory" has appeared on the screen in red
Hi.
Factory on screen means that the TV is stuck in service mode (Durabrand and more). The problem is fixed accessing Service mode and resetting to factory default settings.
On Durabrand TVs problem is fixed using a programmable remote, entering service code on remote, and accessing service menu.
Procedure is listed on TV service manual.Most durabrand use Menu and key combination 683 to access service mode.
If that does not work, calll manufacturer number to get the key sequence to enter factory menu.
Jul 06, 2010 | Televison & Video
I cannot program channels past 35? there is no menu to allow the TV to search for other cable channels. I have a new remote control, but the menu screen does not seam to have anywhere to program...
If you have no remote for this TV that is orginal then it will be hard to get to the menu there is no shortcut to the menu on fixya.com however there are remotes that do get you to the menu and websites sale them www.remote.com look for you model number tv and blam order it and you will reep the benifits of full blown programming. Otherwise rent a box from the cable company if you do not want to pay for a $14.00 orginal remote. Rulds2008 Rate me!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 05, 2009 | Televison & Video
No orginal remote
Did you try the differnt TV mode buttons? Thats what i do on my tv to change from video.
Feb 07, 2008 | Sanyo DS27800 27" TV
26PF5521D wont show menu after reseting factory defaults
Switch the TV to analogue mode (if possible)
Press and hold the "MENU" button on the side of the TV. The settings menu should appear. Continue to hold the menu button until this menu disappears. (If you let go before the menu disappears, start again)
The TV should now go blank for up to 2 minutes, and then revert to factory settings and intitial installation screen.
Procede as per original installation.
Oct 26, 2007 | Philips 26PF5521D 26 in. HD-Ready LCD...
Black square in middle of screen about 25in X 25 in
If a black square appears on the screen and you can see the picture around the edges, it means that the closed captions are on and set to "TEXT". Go into the TV's menu, navigate to the closed captions page and set the captions to OFF.
Aug 10, 2007 | Mitsubishi CS-27407 27" TV
Menu
THIS IS JUST A SUGGESTION .... PLEASE I HAVE A TOSHIBA AND I AM NOT AN EXPERT ON TV REMOTES!!! MY ORIGINAL REMOTE HAS A SWITCH ON THE TOP LEFT HAND SIDE OF THE REMOTE. IT HAS TV, CABLE,VCR, AND AUX. MAKE SURE YOURS IS ON "TV".(IF OURS ARE SIMULAR) IN THE MIDDLE OF MY REMOTE THERE IS A LARGE ROUND BUTTON WITH "ENTER" ON IT. PRESS THAT ONCE AND ALL THE MODES SHOULD APPEAR ON THE SCREEN. USING THE 4 ARROWS AROUND THE "ENTER" BUTTON YOU CAN CURSOR TO THE OPTIONS FROM MODE TO MODE. AND USE THE "ENTER" OR "EXIT" TO SET IT IN THE ADJUSTMENT YOU WANT. MY TOSHIBA IS A PIP "PICTURE IN PICTURE MODEL". MY CABLE REMOTE COMMANDER DOES NOTHING BUT WORK THE TV'S ON-OFF, CHANNEL, AND VOLUME. UNIVERSALS WILL NOT OPERATE THE REST OF TOSHIBAS OPTIONS ... THAT I HAVE FOUND ANYWAY. LIKE I SAID ... I HAVE A TOSHIBA AND HOPE YOUR TOSHIBA REMOTE IS SET UP THE SAME AS MINE OR SIMULAR TO HELP YOU OUT. I WISH YOU LUCK. JUST TRYING TO HELP.
May 02, 2007 | Toshiba MV20FM4 20 in. TV/VCR Combo
Channel reception
What you need to do is go into the menu and go to channel programming and switch the TV tuning mode to cable and it will scan and recive all the channels. Good luck
Aug 20, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Hitachi 57G500 57" TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
