Question about Daewoo Washing Machines
Washing machine wont wash
The washing machine will begin to wash and then stops by itself and would not continue none of the automatic functions
    Genius:
  • 1,198 Answers
Sounds like the timer has failed.
Posted on Nov 26, 2013
dididsaythat
  • 291 Answers
SOURCE: washing machine gone crazy
Does the timmer advance at all? Timmer motor. on timmer if timmer not advancing.
Posted on Sep 11, 2007
SOURCE: Washing machine wont stop filling up
check hose to water level switch, if it has had an out of balance situation it can loosen or detach hose. replace hose firmly back on switch or replace hose if that doesn't work.
Posted on May 29, 2008
SOURCE: washing machine overflows
sorry in advance for the lack of appropriate terminology. my "solution" comes from a mother with no mechanical experience point of view.
i had the same problem with my washing machine overflowing. I opened up my machine, found the clear hose that went from this little square box on the side of the tub up to the switch for the "load size" knob. i pulled the hose off the square box and saw that there was a piece of paper in it. i pulled it out, scraped the scum out and reconnected it. started the machine. - that didn't work.
so, I got the thinnest pipe cleaner i could find pulled the tube from the little box, and stuck the pipe clearner down the pipe of the little square box. pulled out a bit of scummy lint, then I blew in the tubing. I heard a "click", I thought.. okay maybe that's it. reconnected everything, started my machine.. and now it works :)
This probably wasn't the proper thing to do, but it worked and saved me from the cut throat washing machine mechanics in this area.
Posted on Jun 22, 2008
  • 662 Answers
SOURCE: wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Water continues to run into
Hi Welcome to FixYa I am Kelly. You have debris inside your water inlet valve. You can try to clean it by doing the following:
- First remove both hoses from the water inlet valve and remove the inlet screens of the water valve.
(Use a knife blade on the outer part of the screens to remove them from the water valve)
- Connect both hoses to the water inlet valve without the inlet screens.
- Connect ONE hose to the wall faucet
- Place ONE hose in a bucket
SELECT WARM WASH and start wash fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your trying to free the debris from the inlet water valve diaphram)
Stop Fill
Reverse Hose connection at the wall.... i.e. hook up other hose and disconnect the one you had connected. Place the hose you disconnected from the wall into the bucket.
START warm fill
Water should flow into the washer and the bucket. Use the handle of a screwdriver and tap the hose connections of the inlet water valve for about 20 seconds. (your STILL trying to free the debris from the inlet water valve diaphrams)
STOP FILL
- Connect hose to wall connection
- WASH the inlet screens under slowly running water until both sides are clean
- Remove hoses from the water inlet valve and install the inlet screens.
- Reconnect hoses and turn on water supply
TEST HOT and COLD fill
Turn off machine.... IF the debris was freed the water flow will stop when the machine is turned off.
If this flushing attempt does not correct your constant water flow the remedy is to replace the water inlet valve on your washer.
I can help with locating parts ON-Line but will need your model number to help you should you require a water valve.
Hopefully you are able to clear the debris by doing the above. (50 - 50 chance of it working)
Thanks for Choosing FixYa,
Kelly
Posted on Dec 17, 2010
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Super general washing machine (SGW 5800) front loader wont stop
Do an extra long rinse with no load, make sure door sensor in pushed in properly, then module should sort out itself
Apr 29, 2014 | Washing Machines
My washer machines door is locked wont open. And won't wash the clothes in them
  • Unplug your Maytag washing machine for 30 seconds.
  • Plug your washing machine back in, and after 30 seconds, push the "Pause/Cancel/Stop" button two times. Choose a wash cycle.
  • Press the "Start" button until the wash cycle begins to ensure that the washing machine is functioning properly
  • Nov 09, 2012 | Washing Machines
    We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
    We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
    We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
    The last load of washing was still saturated when we managed to open the door.
    Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
    I have a problem with my hotpoint wf340 1400 spin when i put it on it washes but wont come off the wash cycle and will continue washing unless i stop it manually i then have to select pump out and then a...
    it is either a broken wire to your heating element or the element itself is open circuit. when the water does not heat the machine will not move onto next stage of wash.
    Feb 20, 2011 | Hotpoint Washing Machines
    Whirlpool WW1206
    WW1206 Whirlpool Washing Machine CONTINUOUS WATER PROBLEM.
    Water is continuous once the system says it to open, thus the program stops there and no more spinning. Water level setting is not functioning. Water inflow stops only when pressing the pause position. Even if the water supply is cut off, no spinning is experienced. The program still continues and waits for the automatic water supply cut off as programmed, but the water level indicator does not work. rince and spin programs work because there is no supply of water in the program.
    PLEASE KINDLY ADVISE
    Jan 17, 2011 | Whirlpool Washing Machines
    My Whirlpool washer (Ultimate Care II) stops at
    This is probally the lid switch. You can check this by checking for continuity. You should have none with switch open and some continuity when switch is closed if yours has continuity when opened you will need to replace. There is a video at www.appliancehelponline.com/servicemanual.html that can walk you thru the replacement.
    Mar 28, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Model no wa80b3 samsung washing mashine
    My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
    May 02, 2009 | Washing Machines
    Indesit W123 washing machine
    it maybe your brushes are worn out, on alot of machines these days if the brushes wear the machine wont fill , or your motor itself could be faulty or your board. Unplug the machine , take the back off , get yourself a test meter disconnect the motor and put the probes from the meter and put it across the tags, if the motor is wrong you wont get continuity between 2 tags normally 1 and 5 looking from the top of the block going down
    Mar 31, 2008 | Indesit W 123 Front Load Washer
    Laundry washing machine
    Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
    Rate me pl.....if helped.
    Jan 26, 2008 | Washing Machines
    Washing Machines Logo
    Top Daewoo Washing Machines Experts
    Owen Barnes
    Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
