Question about EdgeStar Portable Air Conditioner Heater
The red water light and the word "stop" flashes on display when i try to turn edgestar ap14000hs on. what does this mean?
    Master:
  • 613 Answers
Empty the condensate (water) bin.
Posted on Dec 08, 2013
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Why does my em69 coffee machine red light stay on?
There is most likely a problem with the magnet in the water tank and the machine thinks it is empty. New magnets are available in eBay for around $10.
Jul 08, 2014 | Sunbeam Cafe EM6910
The bottom plastic panel of my EdgeStar AP 14000 HS is cracked and leaks water. It is still under parts warranty so I expect a free replacement panel to be provided by EdgeStar. Question: how do I install...
I just replaced this pan on my unit. I have to admit it was more of an issue than I predicted. You need to remove the screws from the back cover of the unit. Then you can swing the back cover up like a hinge until it is sitting upside down on top of the front cover. Be careful not to damage the wires connecting to the circuit board. You can then remove the circuit board. After the circuit board is removed, you can remove the screws and the front cover. (note, you will have to spread the front cover to get the tabs on the center mounting locations to pop over the frame. After the front cover is removed you will see several things mounted to the base. I removed all of the fastners including the large nuts holding the compressor down. Then with some help,from a second person I lifted the unit and pulled the base away. I had to remove the yellow ground wires from the compressor in order to remove main unit. you will notice now that there are a few pieces attached to the base. I removed each piece and reinstalled it on the new base. then I assembled the entire unit in reverse.
Jul 10, 2010 | EdgeStar AP14000HS Portable Air...
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
Bottom left lights. when i turn on tv red light flashes what does mean
bottom left lights. when i turn on tv red light flashes what does mean
Jan 02, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Stopped pumpin heat displays E7
Follow the link below to find the information about your unit. Also, if you can't find the information that you need then they will have a way to get you the tech support that is brand specific.
http://www.edgestar.com/support/portableac.htm
Mar 20, 2009 | EdgeStar AP410HS Portable Air Conditioner
Edgestar AP550Z won't heat, goes into some sort of alert mode
http://edgestar.com/ownersmanuals/AP550Z_wire-fix.pdf
This could apply to at least one of your units. Apparently these models have had some trouble with the compressor capacitor wires coming loose. If they're barely touching they could cause the compressor to run intermittently and possibly overheat. The compressor runs in heating and cooling mode.
Dec 04, 2007 | EdgeStar Portable Air Conditioner Heater
EdgeStar Portable Air Conditioner Heater Logo
146 people viewed this question
Top EdgeStar Heating & Cooling Experts
John Tripp
John Tripp
Gene Tuck
gbob59
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
