Question about Sony Nwz-e464 8 Gb Walkman Mp3 Player blue
Sony nwz-e464 data recovery
Data recovery
Is it possible to replace the battery in my Sony MP3 Walkman model NWZ-E464
From the user guide:
  • When usable battery life becomes half the usual time, even after charging the battery fully, the battery should be replaced.
  • Consult your nearest Sony dealer.
This would lead me to believe the battery is replaceable.
Jan 08, 2015 | Sony Audio Players & Recorders
Walkman NWZ-E464 How do I change the battery
Here is a you tube video only problem it's in Spanish. But You should get the general idea. Once you get the battery number search ebay for a replacement.
Como abrir un mp4 Sony NWZ E443
Jul 12, 2013 | Sony NWZ-E464 8GB E Series Walkman Video...
I accidentally deleted the PICTURES file on my Sony nwze340 mp3 player!
There is a way to you may get back those deleted picture files from your MP3 MP, BUT it is just possible. Because if those deleted files has been overwritten by new files you saved in, then there is no hope. However usually overwritten cases are hard to happen as long as your MP3 has enough volume.
Then, take so called data recovery program to handle the issue and see if you can grab some or all of the deleted files back. Have a try of Wondershare Photo Recovery. with both Windows and Mac versions provided.
If you are running Windows, go to video photo recovery program.
If you are using Mac OS X, turn to Mac photo video recover software.
You should take care - before your files are recovered, do not save more files to your MP3 in case overwritten situation will happen.
Nov 20, 2010 | Sony Walkman NWZ-S616F MP3 Player
I downloaded songs onto my mp3 but they wont play
Here is the info from Sony:
Is it possible to drag and drop music from the Apple® iTunes® software to the portable player using the Content Transfer Application? Solution
sp.gif sp.gif Yes, if you have iTunes software installed, you can transfer music and playlists from iTunes software to the Walkman® player by dragging and then dropping the files to the Content Transfer application.
NOTES:
  • The Content Transfer application supports data transfer from iTunes software 7.6 or 7.7 to the Walkman player.
  • The Content Transfer application supports data transfer from iTunes software 8.0. However, for playlist transfer from iTunes software 8.0 to the Walkman player, make sure you are using the latest version of the Content Transfer application. The latest version can be downloaded from the Sony Support Web Site at http://esupport.sony.com
  • Digital Rights Management (DRM) copyright-protected files are not supported. iTunes music files may be able to be upgraded to iTunes Plus music files, which do not contain DRM.
  • Do not disconnect the USB connection during data transfer.
  • If there is insufficient free space on the portable player, the data cannot be transferred.
  • The Content Transfer application is included with most newer Walkman Video players. It also is available for additional models in the NWZ-A, NWZ-E, and NWZ-S series. Some models may require an update to be compatible. Additional model-specific information can be found in the Drivers & Software section of the Sony Support Web Site at http://esupport.sony.com.
Jan 26, 2009 | Sony NWZ-E436F MP3 Player
Sony Nwz-e464 8 Gb Walkman Mp3 Player blue Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
