Question about Posiflex Computers & Internet
Dark screen Hi! I'm having a problem with this terminal. It works and at some point there is a black screen. I can't see the icons at the desktop. After a few seconds it's fine again. I tried to connect an external monitor and everything is fine at the second screen. When it's black and I touch the screen I hear the sound of touch. It might be a problem with inverter or the backlights? Please help. Regards
  • Lukasz Nowak Nov 25, 2013
    It's a touch terminal Posiflex Jiva TP-8415 model
    After few times when the image on the screen has switch in to a dark and again in to a normal the operating system just freezes out
  • Posiflex Master
  • 17,326 Answers
IT is the inverter. The backlights usually turn the screen orangish color before they fail.
Posted on Nov 25, 2013
  • 287 Answers
SOURCE: my hp vs15 lcd monitor
It does sound like a back light issue. Not under warranty?
The fact that it does light up suggests it may be a heat induced fault? May be just a simple dry solder joint. Although you cannot rule out the CCFL (Cold Cathode fluorescent lamps) being faulty either. A quick check with a meter may tell you if it is the light source or the driver cct that is at fault.
If its the lamps, salvaging some from another LCD may be a good cheap altenative.
Usually there is a simple fault (failed FET/Transistor) causing these problems so if you are good with a soldering iron and can work thru the cct to locate the offending FET/transistor it will be a relatively cheap and easy fix.
Posted on Jul 02, 2008
  • 26 Answers
SOURCE: My 21inch Samsung monitor screen keep turning black
try another monitor to make sure that the problem is not as a result of there being no output from the system unit
Posted on Dec 22, 2008
pankaj_dic
  • 1252 Answers
SOURCE: My Mag LT926wb shuts off after a few seconds Works fine for a few seconds then click and the screen go dark.
chech the power supply of your system
Posted on May 31, 2009
  • 173 Answers
SOURCE: My dell desktop screen says AutoAdjust and then
install graphic drivers from following link
then cherck ,.
If you still face problem then when you power up the computer pressF8 key then enter in enable vga mode. then change screen resolution to 1024*768
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8300&os=WW1&osl=en&catid=&impid=
Posted on Jun 25, 2009
insomaniac
  • 178 Answers
SOURCE: monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Posted on Jul 07, 2009
My screen is black on my gateway w340ui what needs to b repaired n how much?
Screen is black? Does it look like the computer booted up all the way, if so maybe your icons are on the desktop.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 16, 2012 | Gateway Computers & Internet
Gateway 5150 - computer screen stays black, screen works fine, just very very dark - can't seem to adjust luminosity?
Apr 09, 2012 | Computers & Internet
Hi, I have a T400 and when I trun it on the Thinkpad black screen appears and does not change. Please can you help
Does it seem like the laptop is running except the display is black? Do you think it booted all the way except the screen is black? Do you hear fans running, disk drive spinning?
Screen is too dark
If you can see the icons but the screen is mostly black ( you have to look real close to see the desktop or windows logo) most likely you need a new lcd inverter. I repaired a 1300 series laptop, that had a dark screen, not black, just darker, and the fix was a new motherboard. That would be the second option if replacing the lcd inverter doesnt work. Lcd inverter is about $10 Motherboard is around $50-65 for that model on ebay.
Oct 08, 2011 | Dell Inspiron 1300 Notebook
This solution did not work for the HP dv6000. The screen is black.
Have the lamp checked out on the screen. Also make sure that the dark and light key is not set to dark. Press the fn on the keyboard hit the sunny icon.
Jan 16, 2011 | Computers & Internet
Hard disk icon disappeared from desktop
To add the hard disk icon back onto your desktop, first click the "Finder" button in the dock. It is the dark and light smily face icon at the end of the dock.
Next, click the "Finder" menu item at the top of the screen and then "Preferences". In the "Finder Preferences" window that opens, click the "General" button. From there you can select what system items appear on your desktop. You can click "Hard disks" to re-add the hard disk icon.
Oct 21, 2008 | Apple iMac 24" Desktop
Vista problem
select on the keypad the 'Fn' button, keep it pressed then normally on the lower right of the keyboard there will be keys marked with as olid star shape or an empty* shape or similair, while pressing the Fn key press one of the star iconed keys to up the brightness.
If still dark then the backlight on the screen needs replacing by a qualified repair shop
Aug 29, 2008 | Microsoft Windows Vista Ultimate Edition
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Feb 12, 2008 | Cameras
Colour adjustment
hi try lighten up the whole screen - its the "sun" icon and raise the contrast - its the half black hlaf white circle icon if it dont work , give us more details hope i helped
Feb 23, 2006 | CTX Professional PureFlat PR960FL 19...
Computers & Internet Logo
107 people viewed this question
Top Posiflex Computers & Internet Experts
Will Halftowaite
Andre Fourie
Level 1 Expert
Are you a Posiflex Computer and Internet Expert? Answer questions, earn points and help others
