Question about Car Audio & Video
Got a hifonics( brutus) bxi2008 mono !! Want to hook it up to 2- jlw6'10'S andd got.got a kickercomp pvx and pvr12's that im going to hook p but i wired the kickers to 2 oms. And the w6 to 1 ohm will they sound good to gether??? If i'M doing something wrong plz tell me !!!! Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
No ohms too low series them
Posted on Jan 20, 2014
robotek
  • 1512 Answers
SOURCE: can i hook up my sub if it's wired to a 2 ohm and my amp is 4 ohm
Hi martineztag
You should never connect a load of an impedance less than the min the amp is able to drive. This can have disastrous consequences that may easily result in failure of the amps output stages. You need to use a different configuration that does not overload the amp in this manner for safe operation.
regards robotek
Posted on Jan 19, 2010
Testimonial: "Thanks for the help should i just leave it 4ohms how do i wire it like that? "
SOURCE: i have 2 15'' CVRs and a 1200w amp
1 OHM...ONE... sheesh now thats a low resistance for anything... If they are only 500 watts and they are in parallel, series well NO.. your amp puts out wayyyy too much for those speakers.. 1200w versus 500 watts by 2... srill NOT enough "Head room" for it to be safe... about half is all you could expect before Pop.. sound is heard.
Posted on Mar 05, 2010
  • 44 Answers
SOURCE: i have 2 kicker l7 wanting to wire to best olm
the best way to wire it is @ 1 ohm, but your amp has to be a 1 ohm stable amp. i'll attach some pics for you. this wiring depends on what ohm your subs are.
Option #2
2_2ohmdvc_2ohm.gif Wiring Option #3
2_2ohmdvc_8ohm.gif Option #2
Posted on Mar 15, 2010
  • 62 Answers
SOURCE: Hi, I have a hifonics
run it all series and bridged
Posted on Sep 13, 2010
  • 63 Answers
SOURCE: i have 2 12 inch
Short answer: NOPE!
The Hifonics Brutus 2100 is stated to produce 2100 watts RMS @ 1ohm load. Most amplifier manufacturers overstate their claims. The 2100 watt output is most likely at 14.4 volts and not the 12.6 volts your car will actually be providing the amp.
But, even if the actual output was 2100 watts that would be 1050 watts to each 12w7. The 12w7's are rated at 1000watts RMS and 2000watts peak. As a MECP certified installer, any system I have done using 12w7's have had a MINIMUM of 1000 watts being provided to each speaker. My personal preference is to run 1500 watts each and keep the gains adjusted lower on the amp. Thus allowing the amp to run cooler and allow the additional headroom for those "show-off" moments!
Posted on Dec 22, 2010
"Hi I'm planning to install aftermarket stereo system on 2004 Nissan Maxima 3.5 SL ..Kenwood KDCX997 eXcelon ..Hifonics ZRX600.4 Car Amplifier for kicker 6.5 ..Hifonics BRX160.2 Brutus  for 2 8" inch...
If you have enough room on the outside edge of your battery's post to fit the ring terminal from your new fuse holder, and an additional 7mm nut, then just do that. If there's no way for it to fit, you can purchase an aftermarket battery terminal that has a separate post for mounting aftermarket accessories to. That would be the second option since it would require more money and effort. Below is a link for a few different battery terminals that should be able to use for your car. I haven't looked under the hood of 2004 Maxima since probably 2003 or 2004, but I hope this helps.
2004 nissan maxima battery terminals Google Search
Jun 24, 2017 | Car Audio & Video
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
Will hilfonics brutus 2010d mono work??
Well with the correct powering system, heaps of paralleled 12 volt Batteries, & a Beefed up Alternator to charge them, I guess so, BUT it is only Mono, so you will need TWO to provide stereo output
Mar 06, 2010 | Hifonics Brutus BX 1605D Car Audio...
How do i run a dvc sub with 2 mono amps? I have 2
each amp has + and - and will go to one of the voice coils , for the other voice coil use - to + FROM THE OTHER AMP , SET GAINS TO FULL COUNTERCLOCKWISE SO U NCAN LEVEL MATCH AMPS TO HEAD UNIT . REASON ONE VC IS WIRED "OUT OF PHASE IS SO THE CONES PUSH AND PULL WITH EACHOTHER
Oct 25, 2009 | Car Audio & Video
Illuminating the sub
i would assume hooking it to the remote and ground of the amp
Apr 24, 2009 | Hifonics Brutus BX12D4 Car Subwoofer
Hook up my 2 sub and my 2 amp
wire the subs at 2 ohm each. red to red and black to black and then to the amp. if thay are a dual 4 ohm sub. dual 2 ohms will need to be wired red to black on one coil and the other conected to the amp.
Apr 09, 2009 | Danby DDR601 Dehumidifier
2 4ohm dvc subs to a bxi 608 ( 600watt mono)
take the positive on the sub and run a wire to the other positive the run a negative to the other negative then to your pos and neg on the box do the same on the other side then tie your two positives and two neg together and you got 1ohm and that amp willl handle it all day
Jan 29, 2009 | Hifonics Brutus BXi 606 Car Audio...
Hifonics bxi 1206d
make sure you have a 40 amp fuse in it
im going to try to describe this to you
to bridge a amp this is for 2 ch AMP
I 2 2 I
I 2 2 I
I I 22
I I 22
I I 22
I I 22
#1 SPEAKER #2 SPEAKER
WIRE WIRE
ONE GOES ON THE POSIVE OF ONE SIDE AND THEN THE NEGATIVE OF THE OTHER
HOPE THIS MAKES SINCE
PLEASE LEAVE MY RATING
Feb 11, 2008 | Hifonics Brutus BXi 1206D Car Audio...
Car Audio & Video Logo
61 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
