Question about MSI Computers & Internet
Ram enquiry my ram in my motherboard H55M-E23 is not operating well so i want to buy Kingston Hyper X Blu 4 GB 1600MHz DDR3 Non-ECC CL9 Desktop Memory (KHX1600C9D3B1/4G),i saw that it is Non-ECC Unbuffered 1866MHz CL9 240-pin DIMM type,i want to know if my motherboard can support it
  • MSI Master
  • 7,993 Answers
Kingston has a memory finder. You enter the details of you computer and the site brings up the memory modules that are compatible with your computer. Here is the address of the page.
http://www.kingston.com/us/memory/system_specific/desktop_notebook?gclid=CKu5qsv-gLsCFQpgMgod0nYAkw
Posted on Nov 25, 2013
2 Suggested Answers
  • 343 Answers
SOURCE: my 880GM-E41 motherboard says my
You are actually running at 667 x 2 =1333. You multiply the number by 2 because of the dual channel DDR 3 ram. You would need to go into the bios and change the 667 to 800 (800 x2= 1600 ). You may have to increase the voltage to the ram and change the memory timings to what your ram is specked at. You most likely will not notice the difference in the speed, if you can not get it to change. I have attache a link to read what other owners of this board have done. The second link is for the memory.
http://www.newegg.com/Product/Product.aspx?Item=13-130-295&SortField=0&SummaryType=0&Pagesize=100&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=1#scrollFullInfo
http://www.newegg.com/Product/Product.aspx?Item=20-104-173&SortField=0&SummaryType=0&PageSize=100&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
Posted on May 14, 2011
Does Intel DH61BF motherboard supports 4GB 1600Mhz RAM ?
OK, I was looking for a solution, but hardly got anything that clarify if it's compatible or not. But what I did find out is that if you install a 1600MHz memory stick, this one will clock down to 1333MHz in order for the MB not to crash. Here is a C/P.
Part #: 2xCT102464BA160B • 16GB (2x 8GB Kit) • DDR3-1600 - 1600Mhz - PC3-12800 • CL11 • Dual Rank • Non-ECC • Unbuffered • 1.5V • 16-chip 512Mx8 • Lifetime Advance Replacement Warranty • This 1600 MHz module is programmed to clock down to 1333 / 1066MHz where the system requires it.
Mar 04, 2015 | Intel Computers & Internet
Can i install 4 GB RAM for acer G41T-AD V:1.0 motherboard?
Yes. The specs are
2 x 240-pin DDR3 DIMM slots Supports Dual Channel DDR3 1333/1066 MHz non-ECC, un-buffered memory (Max 4GB)
Jan 07, 2015 | Acer Computers & Internet
Memory population error for DIMM 3
if there are 4 ram slots you have to pair them up or have only 1 mems stick
Aug 26, 2014 | Dell OPTIPLEX 980 SFF Desktop Computer...
Ram
Nov 25, 2013 | MSI H55m-e23 Military Class Motherboard,...
CAN I REPLACE THE MEMORY WITH A 4 GIG STICK
this will depend on your motherboard
whether you can install a 4 gb module of ram
you will need to select your motherboard from a dropdown list
also on the left will be types of ram ddr2 ddr3...... you will need to select which type you have
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
NON-ECC/Non-parity - Most desktop and laptop computers take NON-ECC or Non-parity memory.
ECC/Parity - ECC or parity modules look for errors in data and are most often found in servers and other mission-critical applications used by large networks and businesses.
Unbuffered - Most PCs and workstations use unbuffered memory which is faster than registered memory.
hope this helps you
Oct 12, 2011 | Computers & Internet
Does the Intel MB DG41TX work with the Intel 7300 processor and a single 4GB memory module (Kingston KVR1333D3N9/4G)?
maximum memory for this motherboard 4 GB not sure about a single 4GB module
Max Supported Memory 4 GB
  • Supported RAM Technology DDR3 SDRAM
  • Supported RAM Integrity Check Non-ECC
  • Two 240-pin DDR3 SDRAM Dual Inline Memory Module (DIMM) sockets
  • Support for DDR3 1333(OC)/1066/800 MHz DIMMs
  • Support for up to 4 GB? of system memory
  • hope this helps
  • Sep 03, 2011 | Intel DG41TX Motherboard
    Installed additional RAM on HP P6531p desktop, computer freezes on start-up. Using Kingston DDR3 SDRAM DIMM PC3 10600 @ 1333mHz 2GB. Computer starts and runs fine with 2 sticks installed, but freezes with...
    You may have tried to put too much memory (RAM) onto it.
    That models maximum spec is:
    Memory upgrade information:
    • Four DDR3 DIMM (240-pin) sockets
    • Supports 1 GB, 2 GB, and 4 GB DDR3 DIMMs per socket
    • Supports Dual channel memory architecture
    • Supported speeds
      • PC3-10600 @ 1333 MHz*
      • PC3-8500 @ 1066 MHz
        *DDR3-1333 modules run at 1066 MHz if three or more modules are installed.
    • Non-ECC memory only, unbuffered
    • Supports up to 16 GB on 64-bit PCs (DIMMs run at DDR3-1066)
    • Supports up to 4 GB on 32-bit PCs
    You can find the specs and troubleshooting help files here
    Jul 20, 2011 | HEWLETT-PACKARD Pavilion p6531p-b...
    My 880GM-E41 motherboard says my Kingston HyperX 8GB (2x4GB) 1600MHz DDR3 Non-ECC CL9 DIMM XMP X2 Grey Series is running at 667 mhz or somthing, but i know it can be overclocked to 1600mhz, how is this...
    Rather than '1600' Mhz, it's capable of using DDR (Double Data Rate) RAM at '800' Mhz.
    The "double" rate provides 2 bits per cycle, resulting in a rating of 1600 for the RAM.
    The RAM that you're currently using is '667', not '800' Mhz, rated.
    Buy RAM that is rated at '800'.
    May 14, 2011 | MSI 880GME41 AM3 AMD 880G HDMI Micro ATX...
    I have a m4a78lt-m motherboard will kingston ddr3 1600 4gb khx1600c9d3b1k2/4gx memory work with 32bit os I am putting a system togather have purchased the mother board and memory now i am questing if it...
    This motherboard uses DDR3-SDRAM, ECC and non-ECC, unbuffered, PC3-10600(1333mhz) or PC3-8500(1066mhz), dual channel architecture (two sticks at a time), and a max memory of 8Gs.
    This are the specs for your ram: 4GB 1600MHz DDR3 Non-ECC
    (Kit of 2) Intel XMP HyperX = DDR3-1600
    Default = DDR3-1333 CL9-9-9-27
    CL9-9-9 1.65V
    1.5V
    In other words, Yes! This should work just fine. The ram will just run at its default speed of 1333mhz.
    Jan 28, 2011 | ASUS M4A78LTM LE Motherboard
    I just purchased and attempted to install G.SKILL DDR3-1600 PC3-12800 4GBx4 CL9-9-9-25 1.5v into the 4 slots on the motherboard and the reboot would not proceed past the "LOADING ASUS EXPRESS...
    Memory
    -4 x DIMM, Max. 16 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    Memory- Dual Channel memory architecture
    *Due to OS limitation, when installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Install a 64-bit WindowsWindows® OS when you want to install 4GB or more memory on the motherboard.
    Memory- *Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
    Dec 17, 2010 | ASUS M4A77TD Pro Motherboard AM3 AMD 770...
    Computers & Internet Logo
    96 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    David
    David
    Matthew Spark
    Matthew Spark
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
