Question about Kyocera Office Equipment & Supplies
Only 6030 codes
What does code c04120 mean in kyocera 6030 copier
  • Kyocera Expert
  • 337 Answers
C4120 is a laser unit failure.
Posted on Nov 30, 2013
4 Suggested Answers
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
  • 126 Answers
SOURCE: error code C 6400
This code is a fuser problem code. Follow the procedure below. If the code does not reset or comes right back then: you will have to check the thermistor, thermo fuse and fuser lamp. If 1 or more are defective then replace. After you replaced the defective part you will have to clear the error code again.
Here's the way to reset that fuser code;
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
Posted on Jan 28, 2009
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
Posted on May 26, 2009
How to remove C6400 error in kyocera km 6030
http://www.copytechnet.com/forums/kyocera-mita-copystar/11146-kyocera-km-4050-c6400-error-codes.html
Dec 02, 2016 | Kyocera Office Equipment & Supplies
How to solve the km 6030 machine error code c7200
Hi Farid,
Error Code c7200 means : Broken internal thermistor wire • The thermistor output value is 4.5 V or more.
Because of : Poor contact in the connector terminals. Defective developing humidity sensor.Defective engine PWB.
Need to replace the defected part. please visit to the nearest service center.
Thanks
Aug 18, 2015 | Kyocera Km-6030 With Feed, Finisher, Bank,...
Km 6030 all codes solution
there is a problem with me code of 6030.what,s wrong there?
Jan 11, 2014 | Kyocera Office Equipment & Supplies
Kyocera error c7200
km 6030 machine have a code on screen c7200 so how i solve it
Dec 18, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
Error 6030
fuser failure. firmware upgrade
Jul 07, 2013 | Kyocera Office Equipment & Supplies
KYOCERA 6030 ERROR CODE C0220
Try reset this code by entering on the panel: 1087 1087this will take you to service modehit 906 then hit Start keythen on the screen highlight execute and hit start key.
the machine is going to reboot and this will take care of your problem.This is a board error but can be fixed by updating the machine firmware.
Dec 17, 2011 | Kyocera Office Equipment & Supplies
Any clue what error code 6030 is?
I had the same problem. Pull the Fuser and check Conector.Sometime pieces of paper inside the Conector raises an error.
Please Rate .
Jan 11, 2008 | Kyocera FS-2000D Laser Printer
64 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
