Question about Swintec 7040 Typewriter
Swintec 7040 Printing disc is incorrectky aligned. what is the reset?
  • Swintec Master
  • 3,594 Answers
If you mean that it types the wrong letters check the pitch slide switch on the left of the ketboard. it should be in 10 or 12 not in PS.
DickyO
Posted on Nov 26, 2013
  • 3594 Answers
SOURCE: Swintec 7040 Typewriter
First check check the pitch selector switch to be sure it is not in proportional spacing. if it isn't push down on it and see if it goes away, if is goes away the keyboard needs repaired.
DickyO
Posted on Feb 22, 2008
  • 3594 Answers
SOURCE: swintec 7040 typewriter ribbon feed.
Try code . or , or / one of these should reset the ribbon feed to full spacing
DickyO
Posted on Mar 10, 2008
  • 3594 Answers
SOURCE: swintec typewriter-7040
Be sure that the ribbon L/O and P/W are properly installed, move the slide switches back and forth a few times, check that no keys are stuck down, With the machine off see if the carrier will move back and forth. If not a littlt WD40 on the silver shaft it slides on will help.
Good luck
DickyO
Posted on May 21, 2009
  • 19 Answers
SOURCE: when turned on - a beep is all i get-keys won,t
Sounds like a broken wire attached to the carrier motor. If you remove the shell from the typewriter you can see the wiring inside. I suspect one of the wires has come disconnected or broken. Replace the wiring assembly or you can try to strip the two ends of the broken wire and twist them together, then use some electrical tape to secure.
Posted on Feb 19, 2010
  • 3594 Answers
SOURCE: Swintec 7040 typewriter - what is the code key and mode key for
The code key works with all the keys in the top row to set up those functions, bold, underlind, KDII, etc. The function allows you to type on the display befor printing.
DickyO
Posted on Apr 26, 2010
How to reset the swintec 7040 back to factory settings
Turn off, hold down on the MR (margin release key) and turn on, machine will print some numbers and then print lines of types, let it print a couple lines then turn off and turn on.
Oct 23, 2013 | Swintec 7040 NEW Electronic Business...
What do I press to set my left and right margin on the swintec typewriter 7040
Go to the margin you wish to change, PRESS BUT DON'T HOLD the MAR REL key space or backspace to the desired location press L. or R. mar key.
DickyO
Feb 18, 2012 | Swintec 7040 Typewriter
My Swintec 7040 when I type a letter or word only write a half of the letter or the word and when I try to erase a letter or word the typewriter erase this but the erase ribbon stay in the same position...
There are a few possibilities. If only the tops are printing Press down on the platen to be sure it is fully seated in the side frame. The T/W may be in the overstrike ribbon mode Code period, comma or slash will get you out of that mode.
DickyO
Oct 11, 2011 | Swintec 7040 Typewriter
DickyO
Apr 23, 2010 | Swintec 7040 Typewriter
Purchased used Swintec 7040 typewriter. Looking for a user manual for same.
Swintec was made by Nakajima, If you call Nakajima @
800-809-7138 they may be able to help you.
DickyO
Feb 03, 2010 | Swintec 7040 Typewriter
Swintec 7040
If what you are saying is that you get 2 vertical lines instead of a letter start with a new printwheel, what you are seeing is the hammer face when it misses the printwheel.
DicktO
Aug 30, 2008 | Swintec 7040 Typewriter
Typewriter - Swintech 2640
Sounds like you need a new ribbon or you are using non-Swintec compatible ribbons that are not properly aligned to your ribbon feed. Try using Swintec brand ribbons and see if this still occurs. Worst case scenario, you need to have your ribbon feed adjusted at your local dealer.
Jay @ www.granadahillsbusinessmachines.com
Aug 08, 2008 | Swintec 7040 Typewriter
DickyO
Feb 21, 2008 | Swintec 7040 Typewriter
Swintec 7040 & Spellcheck
If it has spellcheck hold the code key down while pressing the (spell) button
Feb 19, 2008 | Swintec 7040 Typewriter
Swintec 7040 typewriter ribbon feed.
The typewriter is supposed to automatically adjust itself to the type of ribbon you have installed. Have you tried a different ribbon?
Feb 11, 2008 | Swintec 7040 Typewriter
Swintec 7040 Typewriter Logo
76 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
