Question about SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader
Recorded a viedo but can not view because 8GB PNY card is locked. unable to unlock using my laptop or samsung recorder. what can i do
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
At the side of your card is a white pin u can move that upwards and downwards, if the pin is up than its locked if its down than its unlocked
Posted on Nov 25, 2013
Locked and no software disc
Remove the SD card from the recorder and check if the write protection switch is in the locked position. Move it to the unlocked position and carefully replace it without toggling the switch. The switch is on the side of the card nearest the contacts but on the side without the angled notch.
Sometimes the lock switch can become damaged, the best thing to do in that case is to buy a new card. Since there is no data on the card, the time to make a temporary fix isn't worthwhile.
I hope this helps.
Mar 12, 2014 | Sakar Monster High Digital Video Recorder,...
Records only 7 - 9 second :--(
check the sd card on your pc/laptop make sure its in fat32 format. check record settings, on record setting (4gb and above) set it to intervals of 15min. and save setting. sd cards over 8gb are prone to over heat or not record over as it needs to be able to record over older files. 32gb type you need a high end sd card for them to last the better the quality of sd card the better they last. you can also get a corrupted data file either on the video of the format. either way the ds card will need formatting again. hope this helps.
Aug 17, 2013 | everbuying GS8000L Full HD 1080P 2.7 Inch...
I took pictures and recorded video on a (PNY OPTIM SD HC [60 HD] ) Memory Card that a friend gave to me. and it recorded fine on my camera. I use a Nikon Coolpix, but yet nothing is reading the card. I...
It could be that the devices into which you inserted the SD card are not designed to accept SD cards of that type.
There are 3 SD card types: SD, SDHC and SDXC. If the SD card size is 4GB to 32GB, the type is SDHC, and if the card is larger than 32GB, it is an SDXC type.
Newer devices will accept SDHC and SDXC cards, but older devices may not be able to read those SD card types. You should be able to check the specifications of the devices you are using by looking on the device manufacturer's web site.
Sep 25, 2017 | PNY 2GB microSD Memory Card
8gb PNY USB2 flash drive refuses FORMAT Can it
use un lockaer it wil shows were the problem is .........................
Sep 29, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
I cannot upload pictures/ videos from my PNY 8GB memory stick.
The newer large capacity cards in cameras designed for smaller capacity cards seem to have trouble interfacing with our computers. The best best is to get a high speed firewire memory card reader and attach it directly to your computer.
This should allow your computer to recognize your card and also allow you quicker downloads.
May 22, 2009 | PNY 2GB Secure Digital Memory Card
I only get 2minutes of video time after adding a 8GB SDHC card
There is small button on the card which needs to be unlocked so that the card is ready for recording. Also make sure you have changed the media from internal memory to Card in the settings section.
Thanks
Jan 25, 2009 | Cameras
I have the SD-1. It stops recording on my 8gb after only 43 min
Try formatting the card while its in the camcorder, this might sort the problem for you, also look in the camera's menu to see if its restricted to a certain amount of used memory at once, basically return the camera to factory settings.
I find a lot of camera's don't like certain SD cards anyway even if the camera says it supports them, Sandisc are making just about the best SD cards at the moment
kind regards
Dec 11, 2008 | Panasonic HDC-DX1 DVD Camcorder
Unlocking the DM-20 digital recorder
Unfortunately if you are unable to unlock using the Lock Unlock feature. You will need to format the device. This will erase all data and unlock the machine to be able to record to it again.
Nov 01, 2008 | Olympus DM-20 Digital Voice Recorder
Unable to read card
you act white go to the store and raise **** and say you sold me junk
Jun 20, 2008 | PNY 2GB microSD Memory Card
Open Questions:
See all SanDisk 8GB microSDHC Memory Card with MobilMate Questions
SanDisk 8GB microSDHC Memory Card with MobilMate Micro Media Card Reader Logo
46 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
