Question about Canon ImageCLASS MF5950dw Toner Cartridges
Error message reads prepare toner cartridge but it is new
4 Suggested Answers
SOURCE: toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Posted on Mar 19, 2008
spinal
  • 287 Answers
SOURCE: Clear Error Message
Hello Bruce,
I want to help but I am a bit confused. First of all just to provide you with additional info, there are basically three criteria that cause a need to replace the drum. One ,as in your case,is when the waste toner level reaches a level that the waste toner sensor gets covered with toner and it gives you the prompt you received. What happens is that despite the fact that in an ideal world ALL of the the image that is formed on the drum to be transferred to the paper actually does transfer completely and therefore no waste. Real world is that a small portion of the image remains on the drum and is cleaned off and deposited "into" the cavity of the drum where the waste toner receptacle resides and the waste toner sensor does as well. Once the waste toner sensor sees an excessive level it generates the prompt you received and the cpu begins to count pages (and I'll be d$%&ED if I can find the exact number) and if the drum is not replaced the device will give an error code and shut down. We will return to this topic in a moment as it is truly the source of our dillema. The second reason to replace the drum is that copy quality has turned to ****. The 1023 drum is good for........laugh with me as to how they determined this number, 26,900 copies. Not 26k. not 27k. Collective ROFL. This second criteria manifests itself in just crappy looking copies, and the end user calls for copy quality problems. The third reason is the abstract. For example a foreign object damages the drum. This includes the human hand.LOL.
So, after all that hot air I just expelled I am at a loss as to why you are still getting an error message. The new drum should have satisfied all the requirements as the waste toner sensor is happy now, and there is no counter that needs to be reset. I am sorry that I could not be of more help. I know you will cuss me for saying this, but, power off and power on and see if that helps. And we cannot eliminate the fact that the waste toner sensor that resides in the drum unit is bad. Entirely possible.AND...remember that the cpu is counting only sheets of paper not toner usage. So if the copier thinks the waste toner is full, and it does not "see" that everything is ok now, it will give you an E-19 error code after so many sheets of paper pass by. I looked in the service manual and could not find a finite number of copies after the waste toner sensor gets pissed. Then the machine goes wheels up. If I can help further(like I helped alot this time) let me know. ...........SPINAL.......
Posted on Jul 19, 2008
SOURCE: Canon ImageClass MF 6550 Error Toner Low- Prepare New Toner
There are two contact on the right wall off the printer cartridge chamber area. They can get pushed in causing the printer cartridge to not read correctly. Take a small Flathead screwdriver and bend them up so the cartridge ink level can be read.
Posted on Apr 26, 2011
Canon lbp7660cdn
Carol, Did you remove the sealing tape? There should be a small orange tab on the left side of the toner. Its integrated with the toner cartridge and easy to miss. Flip that tab over and pull. It will pull out the protective tape.
Aug 05, 2014 | Canon Imageclass Lbp7660cdn Laser Printer...
Prepare toner cartridge message
I believe it's a counting sensor ( or something like that) look up your model on google, and 'reset counter', should have instructions might be as simple as taping over a lever inside printer
Oct 31, 2013 | Canon Laser imageCLASS MF4880dw Wireless...
Red alarm light flashes..Reads ...prepare a new drum
your drum unit is near end of life.
you will have to buy something like this
http://www.dura-toner.com/canon-ep87-drum-unit-cartridge-imageclass-mf8170c-mf8180c-drum-ep87dr.html?AdID=352--EP87DR-R
i am showing you just for example, search local stores for cheaper.
you can also give it for recycle, just find some toner refilling company near you.
Sep 19, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Error: "Toner Low prepare new
Hi
May be u can;t use the original cartridge please buy the Canon Center and try again
May 05, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Cannon ImageClass mf6590 toner cartridge issue
I have the same question. If you get an answer please send me a reply. aste2426@aol.com Thanks!
Sep 22, 2009 | Canon ImageClass MF5770 Laser Copier...
Dec 17, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Toner not set insert toner message
Nov 06, 2007 | Canon imageRUNNER 400S Copier
Canon image class mf 8170 problem
its mean that change new drum cartridge
Oct 17, 2007 | Canon ImageClass D880 Copier
Canon ImageCLASS MF5950dw Toner Cartridges Logo
89 people viewed this question
old marine
old marine
