Question about Fuji FinePix A350 Digital Camera
A340 camera how do I initialize a new memory card
  • ajonesmic2 Jan 26, 2008
    Hi I have the same problem but do not have the cd rom that came with my camera anything i can do ? mine is A340 model
Update Firmware.
I went to fujifilm website and followed the instruction they provided there. The new XD card worked after I installed the new firmware.
http://www.fujifilm.com/products/digital/download/index.html
Good Luck
Posted on Nov 02, 2007
6ya staff
SOURCE:
Display says card not initialized when a new xd picture card is inserted in the fuji fine pix A340 how do i initialize or format the card
the camera cannot use XD picture card and multimedia card (MMC). SD and SDHC can be used. for compatibility check this http://www.fujifilm.com/products/digital_cameras/accessories/card/a/ you might need to update your product depending on your serial no.
to format the card, press menu to display menu setup, press right to move to setup 2 (3rd tab) you will see Format. click Format to format the memory ("SD" is displayed if memory card is inserted and "IN" (internal memory) if no memory card. hope this helps
Jul 08, 2009 | Fuji FinePix A340 Digital Camera
I am getting a message that reads "card not initialized". It is a new XD picture card. How do I initialize the card?
To initialize the new XD card, you go into the camera's setup menu and navigate to the format function. Format the card and you might be ready to go. If your new card has an "M" or an "H" preceeding the XD, your camera will need a firmware upgrade before it will recognize the card. Here's a link to the firmware upgrade procedure. http://www.fujifilm.com/products/digital/download/a340/fupd.html
Jun 15, 2009 | Fuji FinePix A340 Digital Camera
FINEPIX A340
the only wayi found to make the card accepted is to upgrade the firmware software, this can be downloaded from fuji website, and extract the file and copy it in the initial memory card supplied with the camera, then put bnewly charged batteries or ac adapter and on the camera holding the disp/back button. then it will show the option for the update, and then click ok . after installing ne firmware switch of the camera and put the new xd card on the camera and format the card. this will enable you to shoot inthe new card.
Aug 30, 2008 | Fuji FinePix A340 Digital Camera
Initialize disc
If you have version 1.00, then you will need to upgrade to 1.22 in order for this camera to read an xd type M or H picture card. I believe this is your problem. Go to this link on Fujifilms site for specific info: http://www.fujifilm.com/products/digital/download/a340/fupd.html
Hope this helps!
Aug 04, 2008 | Fuji FinePix A340 Digital Camera
Memory card
press menu and go left or right to setup. Scroll down to format and follow along to format (initialize) your new card. If that new card has an "H" or "M" before the size printed on it, it may not be compatable with the A340 unless an upgrade is performed (firmware upgrade). This can be done by Fuji, or you can do it with help from their website, under the support section.
Jul 27, 2008 | Fuji FinePix A340 Digital Camera
Fuji A340
I had the same problem and downloaded a firmware upgrade from the Fuji web site and it now works in the camera.
Jul 18, 2008 | Fuji FinePix A340 Digital Camera
Fuji finepix A340
a340 needs a firmware update from fuji to work w/xd cards that have a h or m on card-should work ok w/older cards-check mem card and update camera from website to make compatible w/new type card
May 21, 2008 | Fuji FinePix S5000 Digital Camera
Fuli A340 memory card problem
Try opening your My Computer screen, connect the camera to the computer and watch for the new removable disk to show up. Depending on the camera there may be two that show up. Right click on the removable disk/disks and choose format, click start and click okay. This should fully reformat the memory and you'll be able to take pictures again.
May 03, 2008 | Fuji FinePix A360 Digital Camera
Formatting a memory card
simple. use an card reader and format the memory card from windows through your system. now insert it in your camera and format again. now it wil be fine for using
Dec 24, 2007 | Fuji FinePix A340 Digital Camera
Fuji FinePix A350 Digital Camera Logo
127 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
