Question about Sharp Notevision PG-C30XE Multimedia Projector
Sharp Notevision PG-C30XE problem with computer display
I tried with 3 different computers (Asus, Medion, Toshiba with Win7 and Win8) and 2 different vga-cables connecting the projector with the computer. Every time the display lacks the green color. The display shows only magenta and red but no yellow and green. I connected the projector in both of the inputs. The Video input of the projector however is working perfectly, full color, no problem.
  • Hein
    Hein Nov 28, 2013
    From the Sharp company in Holland I just got the suggestion that "the VGA input was set on YPrPb instead of RGB". So I looked in the menu of the projector and with the first entry "Picture" where you adjust the different colors there was a setting at the bottom of the list: "signal type" - and then a choice: "Computer/RGB" or "Component". It appeared to be set on 'Component' instead of 'Computer/RGB' It was difficult to see the difference. So I put it back to 'Computer/RGB' and the problem then was solved! Bright colors again! The previous setting on "Component" does not make sense to me at all because I always use this projector with a computer (in the RGB mode) and I am the only one who is operating this projector. But OK, problem is solved! Thank you for the replies!
  •  John
    John Nov 29, 2013
    HURRAY!
  • 794 Answers
There are 3 different types of analog video signal ports on your projector; s-video, composite video, and RGB. Which one of the three are you using to connect your PC to?
The projector's resolution rate is XGA [1024 x 768]
If you are using a VGA cable designed and capable of handling 640 x 480 resolution; then it will not support XGAs 1024 x 768 signal. On the other hand, if the coaxial cable you are using is a multi band one that is capable of supporting VGA and XGA resolution signals, most likely the problem is not with the cable- although I have come across brand new cables that are defective.
Please let me know if this helps or else we'll try another approach :)
Posted on Nov 25, 2013
Testimonial: "Thank you for the detailed answer! I'll clarify what I did: I connected the Notevision via input1 and later via input2. Both are apparently designed for the computer ('computer'is being printed on the back of the projector at these inputs) The s-video or the RS232C input I didn't use yet. The input3, the audio-video input, I connected with a DVD player (3 cables with tulip- or sony connectors for left-audio, right-audio and video) and that works excellent! The computer cables I use have connectors with 3 rows of 5 pins (total 15 pins) at both ends. I have been able to connect XGA monitors (1024 x 768) through these cables with my Asus and Toshiba computers, no problem there. So I still don't understand why the display is purple-red. Is some circuitry damaged? Could I use Input 3 for the computer? (after transformed the signal from RGB to ... But perhaps (hopefully) the solution is in a different direction."
  • 2 more comments
  • Hein
    Hein Nov 27, 2013
    After an hour the comment I made is still loading, so I copied my comment in the next "add comment":
  • Hein
    Hein Nov 27, 2013
  •  John
    John Nov 27, 2013
    Hein, I have a complete copy of your projector's operation manual open in front of me. Let's take it 1-step at a time. You have an Asus computer that you hook up to your projector. 1.) What type of video cable are you using? 2.) What input port are you using for this hook-up? 3.) Does it work properly?
  • Hein
    Hein Nov 28, 2013
    Thank you John for your efforts! And for the start to systematically solve the problem. I was happy with the answer from the Sharp Holland company, although they were mentioning the YPrPb mode, which I didn't understand. I went to search in the menus and found at the bottom of Picture settings a menu item Signal Type. There it appeared there was a choice between Component and RGB. And indeed the menu has shifted towards Component and as soon as I put it back to RGB the display was bright and colored and sharp! Thank you again for youir assistance
projdoc
  • 2237 Answers
SOURCE: connecting my xbox 360 to a sharp projector
video plug to yellow video in jack, audio to red and white.
Posted on Jul 29, 2009
projdoc
  • 2237 Answers
SOURCE: projector problem
if it is only when the computer is connected, replace the cable.
Posted on Aug 04, 2009
projdoc
  • 2237 Answers
SOURCE: Video input won't accept signal.
if the video signal is HD, the projector can't read it.
Testimonial: "Thanks. Hopefully this will help others. Since the input was not HD, it didn't solve my issue, however."
projdoc
  • 2237 Answers
SOURCE: I have a Sharp XG-E690UB, which works perfectly
go into the menu and into the video options. there should be an option for black and white or color. if there isn't, reset the settings to factory default.
Posted on Sep 10, 2009
projdoc
  • 2237 Answers
SOURCE: Input Screen shows a permanent image
resolution issue. reset the settings to factory default. if that doesn't solve it, make sure the resolution on the projector matches what is on the computer. and it should take mac ok. also check the cable.
Why is my Sharp PG-D2510X Projector keep saying that there is no signal? It worked up until yesterday.
Check both input selections on your computer and your projector. They both need to be set on the same input to work. For example, if the computer is set at 1080 and the projector is set on 720, it wont work. They need to match. Good luck!
Apr 13, 2016 | Sharp PG-D2510X DLP Notevision Multimedia...
Connect Sharp PG-A320X Notevision Projector to MacBook Pro computer
well if its the newer Macbooks you will need a thunderbolt to whatever your projector accepts (vga or dvi) so can find those cables at any computer store.
Dec 02, 2014 | Sharp PG-A20X LCD Projector
Y, pb, pr no signal
you need to be sure the computer resolution is 1024 x 768 be sure the projector is set to rgb or vga input signal type.
Dec 21, 2012 | Sharp Notevision Pg-m10s Dlp Projector...
My sharp PG 10s Notevision comes on. However, is not projecting my computer images on the screen
Make sure the connection from the pc to the projector is secure, also make sure the display settings on the computer are set to extend the desktop onto the projector, and that the projector is set to pc mode.
May 12, 2011 | Sharp Notevision PG-B10S Multimedia...
I replaced bulb for Notevision PG-C30XU but how do i reset the lamp timer?
hi,
Do the following for reset the lamp hour
1.Plug the power cord into the AC socket of the projector.
2.While pressing down arrow, right arrow and ENTER on the projector a , then press POWER ON on the projector.
3."LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Feb 10, 2011 | Sharp Notevision PG-C30XU Multimedia...
The letters are grainy using the data projector
Try changing your setting s on your computer to match the resolution to your projector. Change display settings to 800x600, 1024x768, etc. with your mouse right click on your screen, click properties, at the display properties dialogue box click the settings tab you should see the screen resolution.
May 31, 2010 | Sharp Notevision PG-B10S Multimedia...
Help Screen says No Signal on Input #2
Adjust the screen resolution down a notch or two in the display preferences. The computer is most likely set at 1280x800 pixels at the High (32bit)color. You may even want to drop the 32bit down to Medium (16bit)
Feb 10, 2010 | Sharp Notevision PG-B10S Multimedia...
Projector problem
Aug 29, 2008 | Sharp Notevision PG-B10S Multimedia...
Unit turns on briefly and projects the startup screen, but then turns off.
Do you have fans running ? Would you consider an overheat situation or a resettable fuselink blowing-cooling resetting etc. Sharp Tech Support would know all about this,
Jul 10, 2007 | Sharp Notevision PG-C30XU Multimedia...
Sharp Notevision PG-C30XE Multimedia Projector Logo
91 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
