Question about Sub-Zero Refrigerators
What hp is the compresser on the freezer side of 590 ??
  • 175 Answers
Never seen a HP rating on one, but I think most of them are around 1/3 to 1/2
Posted on Feb 27, 2014
Why is my sub zero fridge model 590 warming up?
Hi fridges will warm up on the outside as they remove heat from the inside. excessive heat with not extreme cooling inside the fridge indicates a possible degridation of coolant fluid or a leak. as the motor tries to cool the fridge the thermostat inside stays on as the tempreture inside has not been reached. if you hear the motor/ pump continually running this will indicate a cooling problem.
May 28, 2014 | Sub-Zero Refrigerators
What is causing my sub zero moled 590 , made in feb 93 to gradually warm up?
yeah vacuuming behind the fridge is a good start this will help the fridge preform better as when dust builds up on the condenser it will cause the discharge to be hotter than it should be making the cooling in the case not as efficient. i would start by removing the pannel in the fridge and seeing if any ice is on the evaporator
May 22, 2014 | Sub-Zero Bottom Freezer Refrigerator
I have the samsung upside down fridge 590 litre freezer is great but the fridge is showing it is set on 3 degrees but inside the fridge it is 7
For starters, Get a second thermometer to check against those two.
Also leave the freezer closed to several hours and see what the difference is in temp.
I would expect that the inside temp would mostly be warmer than the 'set' temp., as the latter is always trying to catch up every time the freezer door opens.
Oct 24, 2013 | Samsung Refrigerators
I have a 12 year old sub zero 590 side by side. The freezer is not working well.ice is fine but ice cream is very soft. Meats and others are not so hard either.
Jai,
If the ice is still frozen after any time the temp is below 32. But thats not cold enough as you know. Target temp in such a freezer is between +10 to 0 F inwhich ice cream is good and firm. BTW many restaurants and food pro's set and judge the freezer temp by the firmness of ice cream! A twelve year old Sub Z should not be having such problems and causes could be numerous. Lets talk about what you can do. This is a built in unit correct? Ok, get your step ladder and remove the cover above the doors and look for a dirty coil, a failed fan, or both. If the coil is dirty enough to restrict air flow or fan not blowing this IS a problem! One that will cause such problems and is my bet to whats going on.
Oct 13, 2013 | Refrigerators
My Frigidaire Model # FRS26LF7DS7 is not cooling!
Could be a few problems. What I would do is check to see if the compresser is running by pulling out the fridge and pulling the back panel off and putting your hand on the compresser. If it Is vibrating then it is running. If it is not vibrating but very hot then the compresser is dead and needs to be replaced. If the compresser Is cool and not running I would say the thermostat inside the fridge is dead(bad contacts in the control). If the compresser is running but no cooling, the cap tube which is the metering device for the refrigerant into the freezer evaperator could be plugged off. Or if none of the lines off of the compresser are hot or cold then the valves inside the compresser are gone and compresser needs to be replaced hope this helps
Sep 06, 2012 | Frigidaire FFHT1817L Top Freezer...
I have a Sub zero refridgerator 590, the refridgerator side is not getting cold, and it's icing up inside where the fresh foods are stored, yet the freezer is working fine. Please help
The freezer coils are iced up and that is blocking the sir flow to the fridge.... You have a defrost problem and that is causing the refrigerator to be warm...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Lg side by side refridgerator ice maker
you can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Dec 10, 2009 | LG LSC27931S Side by Side Refrigerator
Sub zero #590
Have a small water leak up top on left hand side and looks like it could be a small plastic hose?
Dec 25, 2007 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Refrigerators Logo
47 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
