Question about Paragon Lock & Safe SureDrop 7875 Digital Keypad Depository Safe
Resetting combination on Paragon 7875 Depository Safe?
How do I change the combination to the Paragon 7875 Digital Keypad Depository Safe?
When I close the safe it doesnt stay locked when i close the door
heres a copy of the manual for this safe , but if it wont lock back its probably telling you the battery's are low
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Jan 08, 2016 | Paragon Lock & Safe SureDrop 7875 Digital...
How do I change the combination on I have a paragon digital lock & safe
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
Set combination for paragon lock & safe
3. Immediately enter your new pass code (3-6 digits long)
4. Immediately after entering your new pass code, press the "A" or "B" button on the keypad. Your new user pass code is now stored.
NOTE:
This safe stores up to 2 pass codes (a user code and a manager code). Entering a third code will erase the
first pass code entered.
SETTING UP OR CHANGING A MANAGER PASS CODE
1. Open your safe with the pass code you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user pass code.
New user pass codes may be 3-6 digits long.
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
NOTE:
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
Trying to open the safe, it's not opening and keep beeping?
you only get three chances to enter combo correctly then you must allow it to rest for 30+ minutes (even if you have correct combo)
Sep 18, 2013 | Paragon Lock & Safe SureDrop 7925 Digital...
Common Issues with Mesa Safes MFL2014E Safe Depository Safe 09 Cubic Feet
The most common issue with the MFL-2014E is the keypad. We have 7 of these safes in our company and I had been replacing the keypads all the time. Which wasn't too terrible while they were under warranty but if I remember correctly they want $60 for a replacement keypad out of warranty.
I started replacing the electronic lock and keypad with Sargent and Greenleaf models. S&G 6120-305 or S&G Titan 2006-108 and haven't had problems since. Mesa said they had an engineer team from overseas go over their keypads to figure out what the problem was. The feedback was their design was fine but the components were cheap and under par. I still had a problem with their resigned keypads however.
The only other problem I have had is the bars getting bent from people shutting the door on them and bending them. This can be fixed by taking the panel off the door and bending the bracket back flat with your hand. The metal there in a bit too flimsy in my opinion.
Mar 04, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
Changing Combination of Bunker Hill digital floor safe
there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
Aug 06, 2009 | Check Point Network Adapter
Paragon Lock & Safe SureDrop 7875 Digital Keypad Depository Safe Logo
311 people viewed this question
Top Paragon Lock & Safe Home Security Experts
Lawrence Oravetz
Are you a Paragon Lock & Safe Home Security Expert? Answer questions, earn points and help others
