Question about Ruud Central System Air Conditioner
On hot days when a/c is turn on and 10 minutes have passed the main circuit breaker will trip and would have be reset
  • Lee Glascock May 11, 2010
    does it trip, turn off. how long dose it take after reset
    Problem Solver:
  • 5 Answers
Commpressor has gone bad are you have wiring prob! note do votage check by an electrican.
Posted on May 08, 2009
HotSprings hot tub trips circuit breaker
Could be a wrong breaker for that circuit or a problem with the tub.
• first see if there are other lines on that circuit- should be only the tub.
• Check the specs for the tub that the circuit is the correct amperage.
• if clear on those items, there is a problem with the unit and that's another question.
Aug 16, 2014 | Electrical Supplies
My hydropool spa is tripping the circuit breaker. I moved my hottub off the deck onto a concrete pad next to the deck last summer. No problems, then over the first winter I went out one day and the...
it sounds to me like your hot tub has bugs take the control panel apart and clean the bugs out of it. if you have ants in the area they will get into the controls and cause it to trip out. i had similar problem with apump until i found the ants
May 19, 2011 | Heating & Cooling
My 200 amp braeker(main is tripped and wont reset. What should the incoming voltage be???
Don't mess with main breaker if you're not qualified.
Wires on main breaker are Hot even when main is turned off.
The only way to turn off main is to pull meter.
1) There are 2 Hot wires that connect to main breaker.
Each wire is 120Volts, and each 120V line is 'out of phase' with the other.
Two out of phase 120V lines create 240Volt circuit when they are wired together.
Read more on links below.
2) It sounds like your main breaker needs to be replaced, unless total of all circuits exceeds 160 amp. Turn off small circuit breakers and try main breaker again. If main resets, then turn small circuits back on one by one. Your main may still be bad.
http://waterheatertimer.org/How-to-replace-main-circuit-breaker.html
3) Here are more links that explain electric wiring.
http://waterheatertimer.org/B220C.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on breaker or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 21, 2011 | Cutler Hammer 200 Amp Circuit Breaker...
One of the breakers assigned to our Hot wtr htr has been tripping recently leading to loss of hot water. This has happened twice in the last month. After resetting the breaker things have worked fine,...
Breaker could be bad.
Let's do a quick check and save you money.
Open top cover on water heater and push in red reset button that might be tripped.
If reset is tripped, water heater should turn ON.
If reset will not reset, then replace upper thermostat:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If reset is not tripped out, then it is OK, so test two top wires on upper thermostat.
Use cheap multimeter from home center, and set dial to 240-250-277 VAC.
Test across top two screws on upper thermostat to see if you have 240Volts.
To do full troubleshoot on ordinary tank electric water heater takes 30 minutes and multimeter
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
If water heater is not receiving 240V, then the breaker is suspect, or a wire between breaker and water heater is loose.
See basic water heater circuit
http://waterheatertimer.org/240-v-water-heater-circuit.html
Now let's look at circuit breaker:
Mark suspect 240V breaker.
Identify all your breakers, and also mark another 240 Volt breaker that is same amperage as water heater 240V breaker.
Turn off main breaker.
Take front panel off breaker box.
The wires and lugs on main breaker are HOT, so stay away from that area.
Suspect breaker has 2 wires coming from breaker.
See if one or both wires are loose, and then tighten.
If wires are tight, then move these wires to the other 240V breaker that is rated for same amps as water heater.
Now turn on main breaker.
Put ear against water heater tank to hear bubbly fizzing sound.
This will identify if circuit breaker is bad, or if water heater needs a full troubleshoot.
It is not a good idea to run two 240V appliances on same 240V circuit breaker, so you may have to decide one or the other appliance until you can replace breaker.
Instructions to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
For a price, fixya expert speaks with you over phone while you work on water heater circuit.
Jan 07, 2011 | Water Heaters
Circuit breaker trips after 10 minutes
could be a weak breaker,or poor high resistance connection from panel to dryer plug, then have someone check the current draw on the dryer while operating and see if it's within specs of the machine tag, if it's higher than that you may have a defective motor or heating element to case causing a higher than normal current draw
Nov 09, 2009 | Maytag PYE2300AY Electric Dryer
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Ruud Central System Air Conditioner Logo
61 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
