How to create, 230v ac normal power to 220v dc.
  • 2,113 Answers
You can hook a dc generator to an ac motor using a coupler. You can build a wheatstone bridge using 4 diodes and maybe a large capacitor. You could buy a rectifier that does most of that but it would be pulsating dc without a capacitor
Posted on Nov 25, 2013
Hello what kind of voltage use the power adapater?
The power adaptor has normally two voltages.
One is primary (Input) which is 110V AC in USA. 220V in UK and others.There are now a days Adaptors which accept both 220V and 110V. However the Adaptor pin will differ. It will be Flat pins for 110V and Round pins for 220V.
The other voltage is the Output which is fed to the Equipment and is Equipment specific. It can be 18V to 5.2 Volt DC. It varies equipment to equipment.. If a wrong Adaptor with output Voltage not matching with equipment requirement is selected, it may damage the equipment. Be careful.
May 21, 2015 | Sport & Outdoor - Others
Fan runs but will not strike a arc
The fan should be running on 120v, or one leg of the 220v. Something could be wrong with the other leg of the 220, short, bad contact, etc.
Jan 02, 2014 | Hobart Stickmate Ac/dc Welder Lx235 230v,...
How to install 12 volt led light bulbs in the 220v Power Supply
Buy a lamp holder and 220V AC to 12V DC power supply, power supply should exactly be connected with the positive and negative holder, plug in the power, 12 volt led light bulbs can be used.
Dec 01, 2011 | Cars & Trucks
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
Philips norelco G370 charger Not working(Light is not glowing, Power socket is working for other charging) what should be the output Voltage , Mine is 230V in India . Should i use any adapter, It was...
Hi, do not experiment with other chargers (its not worth, because of price for new one), the cheapest one (with most positive reviews from buyers) is Amazon com PHILIPS NORELCO G370 charger . hope this was helpful.
Aug 04, 2010 | Philips G370 Hair Trimmer
3-phase recty fier not output voltage 230V 10V
What is the type (input, output, power) of the rectifier.
If controllable - may be the control PCB or thyristor.
If not controllable - 10 V DC instead of 230 V DC is hardly believable.
In this case the rectifier may be OK, but the input - low.
If you have a voltmeter, check the input AC and the output DC if the output has about 200 V AC you may have shortened diode.
Jul 02, 2010 | Electric Measuring Tools & Sensors
My 2270 jambs paper from tray one every time. I changed the pickup rollers still no help. All my other trays feed properly even the stack bypass
Hi mate,
Prior to your issue i may enlighten you with this source.
Technical Infomation 0105/0101/0102/0103/0201/0202/0203/0204 Jam Code: Paper lint adheres to surface of vertical path roller
Description
Since a type of paper that can easily generate lint was used, the paper lint adhered to the surface of the vertical path roller and decreased the paper feed performance of the roller, causing the jam code "0105."
Depending on paper sources, the following jams occur.
- Cassette 1: 0105 (registration sensor PS9 delay)/0201(cassette1 retry sensor PS10 stationary)
- Cassette 2: 0101 (cassette 1 retry sensor PS10 delay)/0202(cassette 2 retry sensor PS11 (cassette pedestal) delay)
- Cassette 3: 0102 (cassette 2 retry sensor PS11 delay)/0203 (cassette 3 retry sensor PS1 (cassette pedestal) delay)
- Cassette 4: 0103 (cassette 3 retry sensor PS1 (cassette pedestal) delay)/0204 (cassette 4 retry sensor PS2 (cassette pedestal) delay jam)
To prevent this, a vertical path roller to which paper is hart do adhere was used for the following machines (the color of the roller was changed from black to gray).
- iR2230 120V THF03592 and later/120V TW SHD00033 and later /220V CN SHC01553 and later/230V EUR THG02606 and later /230V THH00339 and later
- iR2270 120V SLH28893 and later/120V TW KJN00097 and later/ 220V CN KJL00763 and later/230V EUR KGL54733 and later/230V KGM03613 and later/230V CA SLF02281 and later
- iR2830 120V THK01045 and later/220V CN SHE01035 and later
- iR2870 120V SLG13303 and later/120V TW KJR00054 and later/220V CN KJP00589 and later/230V EUR KGD13135 and later/230V KGE00333 and late/230V CA SLD00411 and later
- iR3530 120V THL01319 and later/120V TW SHK00085 and later/220V CN SHH00829 and later/230V EUR THM01596 and later/230V THN00209 and later
- iR3570 120V SKV61037 and later/120V TW KJU00760 and later/220V CN KJS00928 and later/230V EUR KFW21901 and later/230V KFX02555 and later/230V CA SKT01761 and later
- iR4570 120V SKU23728 and later/120V TW KJX00122 and later/220V CN KJV00690 and later/230V EUR KFQ15439 and later/230V KFR02186 and later/230V CA SKQ01030 and later Field Remedy
When the symptom occurs with the machine without the foregoing serial numbers, replace the vertical path roller.
Kindly rate me !!!!!!!!thank mate.
Sep 23, 2009 | Canon imageRUNNER 2270 Copier
4600 dell power supply
If you travel to Europe you might need to change your power settings here in the USA we use 110-120v for most household items . Things like AC,ovens,and dryers. use 220v. Larry
Mar 08, 2009 | Dell POWER SUPPLY Power Supply
Change 120v chager to run on 240v
all you needs is a step tranformer from 110v to 220v ac
Nov 13, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
