Computers & Internet Logo
Posted on May 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Letter key on our keyboard doesn't work when you type on it
I have a letter key on our keypad that doesn't work when you type on it. Is there anything I can do to get this letter key to work when I type on it. Please help
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 225 Answers
  • Posted on May 08, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
225
Questions
Helped
103218
Points
560
Good morning! possibly the letter key point terminal is stuck, please try to invert the keypad up & then tap it downward as it may loose the key point terminal, then try to use it again, if still the problem exist, then I suggest to try to use another keypad, as previously used keypad is defective. best regards
Anonymous
Level 2:
Sergeant:
  • Expert 190 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
190
Questions
Helped
95660
Points
571
If handy with tools you can open KB an check all traces are good
if not need to use a HB pencil to re-trace grid @ non-working key
2answers
How to type degree symbol on mac
There are a few different ways to type the degree
  1. Use the keyboard shortcut: Press and hold the Option key, then press the letter K on your keyboard. This will insert the degree symbol.
  2. Use the character viewer:
  • Go to the Edit menu and select Emoji & Symbols.
  • In the search field, type "degree".
  • Double-click the degree symbol to insert it into your document.
  1. Use the ASCII code:
  • Press and hold the Option key and the Shift key.
  • Press the number 8 on the numeric keypad. This will insert the degree symbol.
I hope this helps! Let me know if you have any other questions.
2answers
Want to make german Umlaut symbols on keyboard
Every so often you may find you need to type a character on your computer that is either foreign or just not available on a standard keyboard.
The German umlaut is once such symbol.
Used in the German language to indicate a change in sound, the umlaut can sometimes be found in names and words we use in the United States as well.
The literary Bronte sisters, for example, use an umlaut over the E in their last name.
Umlaut's can be found over the vowels A, E, I, O, U and Y in both lowercase and uppercase forms
Hold down the alt key on your PC.
The next step depends on the vowel and case you want for your umlaut.
If you want a lowercase A with an umlaut, type the numbers 0228 on the keypad while holding down the alt key.
If you want an uppercase A with an umlaut, hold down the alt key and type 0196.
Hold down the alt key and type 0235 for a lowercase E with an umlaut.
Hold down alt and type 0203 for an uppercase E with an umlaut.
Hold down the alt key and type 0239 for a lowercase I with an umlaut. Hold down alt and type 0207 for an uppercase I with an umlaut.
Hold down the alt key and type 0246 for a lowercase O with an umlaut.
Hold down alt and type 0214 for an uppercase O with an umlaut.
Hold down the alt key and type 0252 for a lowercase U with an umlaut.
Hold down alt and type 0220 for an uppercase U with an umlaut.
Hold down the alt key and type 0255 for a lowercase Y with an umlaut.
Hold down alt and type 0159 for an uppercase Y with an umlaut.
Typing an Umlaut on a Mac
Hold down the option key on a Mac computer and press the letter u.
Then release both keys and type the letter for which you want the umlaut.
For example, if you want a lowercase A with an umlaut, you would hold down option and u, release, and then type the letter a.
If you want an uppercase A, you would hold down option and the u key, release and then type the letter A.
Hold down option and u, release, and then type the letter e for an umlaut over a lowercase E.
If you want an uppercase E, you would hold down option and the u key, release and then type the letter E.
Hold down option and u, release, and then type the letter i for an umlaut over a lowercase I.
If you want an uppercase I, you would hold down option and the u key, release and then type the letter I.
Hold down option and u, release, and then type the letter o for an umlaut over a lowercase O.
If you want an uppercase O, you would hold down option and the u key, release and then type the letter O.
Hold down option and u, release, and then type the letter u for an umlaut over a lowercase U.
If you want an uppercase U, you would hold down option and the u key, release and then type the letter U. And for an umlaut over an uppercase Y, hold down option and u, release, and then type the letter Y.
For a lowercase Y, hold down option and u, release, and then type the letter y.
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
2helpful
2answers
I password my laptop (samsung R510) and one of the key I used is not working and I got an external USB keyboard by the keyborad is not working with, what will I do to used the external keyboard
your USB keyboard may not work because your laptop has not got to the point of initiating USB at the point of booting to password.
You could try using ascii codes to eneter the key
at the point where you need to enter the key that doesnt work press your numlock button this will turn some of your letters into numbers...they should be written on the keys in a different colur...the laptop Im looking at at the moment has 4 on U, 5 on I 6 on O, 1 on J etc...
hopefully these are not the broken key..
if you look here you will see the chart that says A=65 B=66 etc in order
http://www.asciitable.com/
find the letter you need eg v=118 in lower case
type in your password till you get to the v (if thats the broken letter)
press and hold [ALT] button with num lock on and on your newley formed number pad type in the number thet represent the letter in this case 118 when you release the [ALT] key it will insert that letter.
however this only works with an extended keypad (like a full size keyboard) where the numbers are seperate not your top row numbers which is why you need your numlock on.
HTH
Richard www.2pages.co.uk
if it does then work maybe you could go into your bios and turn USB legacy support on...which may then help your full size keyboard to work too.
Hi I have a 1500 and I am having trouble figuring out how to change back and forth the keys with letters and numbers. Thanks....Lee
These keys with numbers and letter have been placed to avoid having a separate number keypad as you have on a PC keyboard. There is also an led that glows when you press the Num LK (for Number Lock) key. When the led is glowing, you will get numbers and letter if it is not glowing. This arrangement has been made to save space on the laptop. You get a separate number keypad as an add on for those who need to use both hands typing numbers and letters simultaneously.
When typing regularly each letter gives a differ letter thats on the keypad.
First check to see if the LANG is lit on the display, if so Code "L: will turn it off. If that is OK then Press coce and "L: key, release the code, type 001, release the "L" key. This will set the keyboard to USA standard. If this works your keyboard is failing. Contact
George Beyers Co. @1-800-392-8085 for a keyboard rebuild.
DickyO
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
The letter L key is not working
You have a faulty keyboard. Need to change the whole keyboard since you cannot change just only one letter key.
Note: If machine is under warranty no need to pay for the repairs.
Grand Canyon Tech
Grand Canyon Tech
