Question about Motorola Mobility RAZR V3
Can't receive and make calls
Started by saying there was no service. After removing and replacing Sim card it would work for a few days. Eventually it was impossible to receive calls or make calls. When trying to make calls it would try but then you'd get the message that the call failed.
  • 425 Answers
Hi
try resetting your fon to its orig settings if still no network then you may have a hardware prob...
have it repaired to technicians...
Posted on Oct 16, 2007
SOURCE:
Why am I sometimes receiving and not receiving calls on my Sim2 ?
Posting this query in a forum dealing with portable communication devices may result in helpful responses, as it does not appear to be a query relating to cameras.
Jun 28, 2017 | Samsung i9082 Galaxy Grand Duos Dual SIM...
My samsung SGH-A847M will not receive calls when phone lock is on. Tried the sim card in another phone like it and same result So my service p
You either have to call customer service to get your phone disconnected from the network and put back on. In your case since you tried multiple phones with the same sim even though the sim is not locked, they will have to replace the one you have no since it is faulty
Sep 02, 2017 | Cell Phones
I cannot send nor receive calls, nor send and receive text messages as of yesterday, April 18, 2011... I am currently using a postpaid SIM... thanks
there are several factors why you are unable to send and receive messages and make outgoing calls and receive incoming calls.
network issue: are you the only one experiencing the problem? try to check with someone who is on the same location and is using the same network as you if he or she is experiencing the same problem as you. if yes, then it may be a problem with your network.
make sure that you have good signal and contact your service provider too and ask them if they have an ongoing maintenance in the area and ask if the sms and calls services are activated on your account
phone issue: if you have a good signal and still can't send, receive text messages, do and receive incoming, outgoing calls, try to do these: call the service provider and ask for the default network pin, then go to the settings of your phone, call settings, call barring, deactivate all barring
try inserting your sim card to another phone and try to send an sms
turn off your phone, remove battery and sim card and then wait for a few seconds, then put back the sim and battery and turn on the phone then try to send an sms
Apr 19, 2011 | Cell Phones
Iv am using nokia n79 for smore then an year. Out of the blue it has stopped sending text messages, I turned it off, removed battery and sim card, replaced them and it started to work properly again then...
the message center number must have been tampered with.call your service provider customer care line for this number.then go to message>message setting>text messages>message center now click to enter the given numbers
Mar 06, 2011 | Cell Phones
I have a samsung jet jet s8000,today i cannot phone out saying emergency calls only.
This is a simple issue don't worry.First please remove the battery and remove the SIM card and see weather it is being damaged or you can see scratches on the gold plating.Take some cotton and dip it on kerosene and clean it nicely on the edges of the gold plating of the SIM card..Now place it correctly and switch on the phone.Some time loose contact may cause this problem and scratches too....If still the problem persist check with other Sim card of your friends or family members..
If other SIM card is work's fine then it your SIM card must be replaced by your service provider.Ask him for a free replace..else the Sim card connector is damaged you have to solder or replace it.If you don't have any hands on,take it to nearest service center.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Sep 01, 2010 | Samsung Jet S8000 Cell Phone
I have nokia n70 but i cannot received and sent text messages nor cannot make a call keep saying network busy. please help me this.
1. Turn the mobile phone off for a second and turn on, check if you have network signal. If still not working, try #2
2. Turn off the phone and remove the battery and sim from the phone for a couple of second. Return everything and turn on the phone. If still no network or no signal from you network provider, try #3
3. Turn off the phone and remove the battery and sim from the phone, insert the sim card to your other phone and check if you can make and receive calls and text messages.
4. Insert a your other sim card from your phone and check if you can do the same.
**With this, you can identify what needs to be repaired or replaced. (Sim card or Mobile Phone). If you cannot make and receive calls and text messages using no. 3 method, it is the sim card that has the problem and needs to be replaced. But if with #4, the phone has the problem and not the sim card. You need to contact your Service/Network Provider from technical help.
Thank you.
Aug 10, 2010 | Nokia N70 Cellular Phone
It just says sim blocked emergency call
Aug 01, 2010 | Cell Phones
My sellphone get block and now said insetrt sim but the card is there an dstill said the same thing?
First, make sure you have the SIM inserted in the phone correctly. If you do - and the phone still doesn't recognize the SIM card - you may need to replace the SIM card.
This is a common problem with some phones especially when the SIM has been transferred from one phone to another.
Just about the only way to correct it is to replace the SIM card with a new one.
You can purchase one on eBay for a few dollars instead of paying $25 at a retail outlet. Once you receive it, carefully pop it out of the card it is attached to and correctly insert it into your phone.
Put in your battery and turn your phone ON. You should see a 'No Service' message on the screen. If you do, then your phone can now recognize the new SIM card.
Look on the larger card you removed the SIM from and get the SIM number from the card. Then call your service provider and inform them you have replaced a defective SIM card with a new one in your phone. Give them the new SIM card number and in less than 1-minute your phone will be working again.
When it does, the message on the screen will change from 'No Service' to the name of your cellular provider.
Apr 01, 2010 | Pantech C300 Cellular Phone
Phone says insert sim card with sim card already inserted
Mar 29, 2010 | Samsung Beat SGH-T539 Cellular Phone
Motorola Mobility RAZR V3 Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
