Question about Kettler treadmill Pacer
Lubrication error reset kettler - Kettler treadmill Pacer
I have Kettle pacer treadmill,when I press start button the display shows error DC 6 and belt does not move
have you kept the belt regularly lubricated ?
can't find this error code in manual
Nov 25, 2014 | Kettler treadmill Pacer
Kettler crosstrainer UNIX PX error e2
intl.sport.kettler.net/service.../error-messages-troubleshooting.html
https://www.kettlerusa.com/manuals
Sep 09, 2014 | Sport & Outdoor - Others
Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 28, 2012 | Kettler treadmill Pacer
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
I have a Kettler Condor Elliptical and when I use it I am getting a squeeking sound from around the wheel area (like a belt is misaligned??). Any ideas? I am afraid of taking anything apart, so at this...
Do you still have your manual? I kind of remember running into this, I think it was something simple( sorry I can't recall!) like lubrication or uneven alignment (fixed by adjusting the feet). I don't see the condor on the kettler USA site, but they still may be able to help.
Feb 02, 2011 | Kettler Exercise & Fitness
MY TREADMILL STOPS JUST A MINUTE AFTER STARTING.
Try Lubricating the belt with silicone spray.
Probably the resistence from the belt scraping over the ground board is too high, forcing the machine to switch off in order to prevent damage.
Jul 24, 2009 | Kettler Exercise & Fitness
Kettler treadmill "silikon wartung"
Hi eirik,
Your treadmill needs lubricating.
Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
That should do the trick.
Mar 29, 2009 | Kettler Exercise & Fitness
Kettler treadmill Pacer Logo
Top Kettler Exercise & Fitness Experts
ray gallant
Steven Brandon
Steven Brandon
todd
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
