Recently my LG mini split stopped heating. The inside fan will continue to run, but with no heat. The outside unit comes on for about 3-5 minutes before shutting off, while the inside unit continues to run. There are no error codes on the outside unit board, and I replaced the thermistor over the summer when I was having an issue with cooling. The filters are clean, the outside unit is clean, and there isn't any ice on the unit whatsoever.
If the air conditioner compressor runs all the time the main control board might be defective. The main control board provides the voltage to the fan motor and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
SOURCE: I have a 18000btu LG
Hello.I think they are on to something with shortcycling on temp sensor.I think it should be sampling the return air instead of (inside coils ?).A 2*f dead band use to be built in (factory installed) to thermostats to prevent on/off, but not sure in this case.Try a new sensor location(return air) and see if anything changes.
