Question about Apple iPad 64 GB 3G Tablet PC
Where is the sleep and home buttons on my ipad
  • 52 Answers
Hold your iPad with the button at the bottom. That front button is the Home button. The button on the top right edge is the sleep (click) or power (hold) button.
Posted on Nov 27, 2013
Can't get my iPad to turn on! Have tried pressing the button for a long time, still not turning. What else should I do to get started?
In order (stop if one works):
1. Recharge at least an hour from power adaptor rather than USB computer lead.
2. Reset by holding down Sleep/Wake button on top right of tablet while at the same time pressing down home button. Keep both depressed 15 seconds. If slider appears or screen dims, keep pressing till Apple appears.
3. Restart (display not working) by pressing and holding Sleep/Wake button till power off slider appears. Drag slider to right. Wait 2 minutes. Press and hold Sleep/wake button till Apple appears.
4. Recovery Mode. With device powered down, hold sleep/wake button down and drag slider to off position. Then plug USB into a computer (do not have usb cable connected to iPad yet) running latest version of iTunes. Hold down Home button while plugging USB cable into iPad. Keep Home button down until Connect to iTunes appears. If does not appear, start Recovery Mode procedure again. When Lightning cable, arrow, and iTunes appears, release Home. Click OK to restore to factory defaults (erases data). Restore data from earlier backup. (Summary of method from Phone Cruncher site.)
Aug 28, 2017 | Tablets & eReaders
After charging my IPAD says IPAD is disabled and underneath it says connect to iTunes. what do I do?
Try putting it into DFU mode which is
-hold sleep/wake and home button untill it turns off
-let go of sleep/wake button still hold home button for about 10 seconds
-plug it up to iitunes
-and it should be there
Dec 30, 2015 | Apple iPad Air 9.7" 32 GB Wi-Fi Space Gray...
Sound effects icon on iPad won't go away
try this steps:
Restarting, resetting, or Force quitting the apps.
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPad. To turn iPad back on, press and hold the Sleep/Wake until the Apple logo appears.
Force quit an app: Press and hold the Sleep/Wake button on top of iPad for a few seconds until a red slider appears, then press and hold the Home button until the app quits.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
Reset iPad: Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Jan 18, 2015 | Apple iPad Tablets & eReaders
Ipad 2 will not power off with power button or home buttons pressed
Press and hold the Sleep/Wake button on the top of your device until the red slider appears. Then drag the slider to turn your device completely off.
After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
You should reset your device as a last resort and only if you can't restart it.
To reset, press and hold both the Sleep/Wake and Home buttons for at least 10 seconds, until you see the Apple logo.
Sep 14, 2014 | Apple iPad2 WiFi 64GB
How to reset apple ipad
Hi Anonymous,
I think this may help you,
  1. Make sure the iPad battery is charged above 20% ( we would recommend at least 40 - 50 %). If you are not sure charge you tablet for at least 30 -40 minutes.
  2. Make sure iTunes is not running on your computer but is ready to be run.
  3. Temporally disable firewalls and other security software to prevent interference with iTunes.
  4. Make sure your tablet is disconnected from the dock or USB data cable that equips the gadget . Nevertheless USB cable must be plugged into your PC or MAC.
  5. Make sure your PC or MAC is awake and its screen saver is turned off.
  6. Simultaneously press and hold down the Wake/Sleep button and the Home button and wait until "slide to power off" screen appears. Don't do anything after its appearing, just keep holding Wake/Sleep and Home buttons until Apple tablet will power off.
  7. Release the Wake/Sleep button once Apple tablet is off , but continue to hold the Home button
  8. Holding the home button, connect the USB data cable to iPad. When you reconnect the USB cable, tablet should power on and you should see a message on your PC/MAC display saying that iTunes has detected an iPad in Recovery Mode
  9. After you detected this message, release the home button and press OK on iTunes pop-up to confirm the restore option.
  10. Do not touch iconic tablet and you computer while iTunes downloads and installs the fresh copy of firmware on your iPad. You will be notified by iTunes when iPad is successfully restored, but... in a while, you will get an message saying that the iPad isn't recognized. Don't panic. This is because all user content on iPad including activation status was erased during restoration.
  11. Disconnect iPad from iTunes ,unplug from computer and turn off.
  12. Turn iPad on and using iTunes activate it on any computer you have. Apple currently allows up to 5 computers to be authorized for each iPad.
Aug 11, 2014 | Apple iPad Tablets & eReaders
How do I unfreeze my Apple ipad air ?
It's actually very easy, once you know how to do it. Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom).
Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
May 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Feb 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My ipad is dead how do i restart?
for Iphone ,ipad, ipod
Step One
Open iTunes and connect the iPhone to your Mac or PC.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
restor it.
May 07, 2011 | Apple iPad 64 GB 3G Tablet PC
IPAD is disabled
you need to DFU restore your iPhone. Hope you got a backup, because you're losing the stuff on it. with iPad plugged in, hold down the sleep wake switch, and the home button for about 10 seconds, until the iPad turns off. Once the screen goes black, continue holding, count to 8. Release sleep wake switch, continue depressing home button. Wait for iTunes to recognize, and you'll be prompted to restore.
Feb 07, 2011 | Apple iPad 32 GB 3G Tablet PC
Apple iPad 64 GB 3G Tablet PC Logo
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
John mullen
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
