Question about Saws
Stilh ts800 saw cuts out after 2 minutes wont start again till cool
  • 14 Answers
SOURCE: 95 gmc runs fine till i shut it off then wont start till its cool
sounds like a crank shaft sensor
Posted on Dec 24, 2008
efs_perpends
  • 1996 Answers
SOURCE: WHen cutting a 2x4 the chop saw will cut 1/2 the
Is the blade secure on the arbor, or is the motor itself bogging down?
If the motor is bogging down, make sure you let it come up to speed before making your cut...then let the blade do the cutting, instead of forcing it through the material. Also be sure the material is securely resting against the fence and the base of the saw, so as not to pinch in the middle of a cut.
Make sure you have a good power supply to the motor, and not a long skinny extension cord or the like.
I guess it's possible, if the saw is older or has been under heavy use, that the brushes are worn out and need replacing, but it's also possible the motor is just worn out. (Altho I have rarely if ever seen this occur.)
If you rule out operator error and power source, and the brushes are good, and of course the blade is sharp and clean, the I guess the motor must be at fault, and should be checked at a local service center.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 04, 2009
jingB
  • 19 Answers
SOURCE: Engine cuts out and wont restart for maybe 20/30 minutes
honestly, I've not seen an alfa romeo here in the philippines but i think you problem is partly electrical and the electronic side of the car. something on your car is heating up so much that it cuts the power to the ignition once it has. it is a possibility that a damaged ignition coil or a faulty computer box(if your car has one) or the control system that regulates the spark distribution system or the injectors(if your car is fuel injected type).
Posted on Apr 14, 2009
roniecon
  • 6826 Answers
SOURCE: renault megane 1600 cuts out after 10 minutes and
replace module
Posted on Jul 01, 2009
  • 491 Answers
SOURCE: my honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
Posted on Sep 06, 2009
89 f250 460 engine starts but when u drive it it cuts off like not getting fuel then it wont start , but after waiting a few minutes it starts , then cuts off again after a few minutes, is it a fuel...
it sound like the coil get hot it will cut off till it cool down ,it is possible that it is a fuel filter ,it has only one unless someone has added one
Oct 21, 2013 | 1989 Ford F 250
Husqvarna 455 rancher chainsaw - you can start the saw run it for 3 mins it then cuts off and then wont start back till cooled off. whats the problem?
check the ignition module. as the saw heats up it causes the inside of the module to expand which causes it to stop producing spark. when it cools off it makes contact again and starts working right
Oct 17, 2013 | Garden
My chainsaw poulan p3314 will run fine for about five minutes, then cuts out and wont start until it cools down....???
Sounds like the engine is overheating and seizing. Most of the time this is a cooling or oil problem. Check the cooling fan for debris. Make sure you use the right oil mix.
Sep 16, 2013 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Stihl carb diagram
Here is the two types of carb fitted to the TS700/TS800
May 17, 2013 | Stihl 43991 - TS700 & TS800 Cut-off saw...
Poulan 18" wildthing chainsaw (model
This could be a couple of things, if the fuel tank brather is blocke the tank will vacume, to test this try slackening off the fuel cap when the saw starts to die, if it picks up again it is a fuel tank braether issue, the other possibility is a bad ignition unit breaking down, the only test for this is to replace the unit and try again.
Sep 19, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Car cuts off with out no warning and wont start for about 20 minutes then will start again
Most probably cause over heated check the radiator water but
DO not open its cap while engine running
or hot wait till vehicle cool down and also check the engine oil as well good luck
Oct 05, 2010 | 2002 Hyundai Accent
Hot chain saw wont start
When it won't start, remove the spark plug, lay the base on engine metal with the wire on, and pull through. The spark should be blue and snappy. If nothing, try a fresh plug. If still nothing, the ignition module may be failing with heat. Try blowing out sawdust from the engine and case with compressed air to improve cooling. Does the engine 4-stroke when not cutting, but immediately 2-strokes when cutting? Check the air cleaner and muffler for plugging. Make sure the carburetor fasteners are tight. Hope some of this helps!
May 01, 2010 | Garden
Saws Logo
23 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
