Question about HP LaserJet Pro 100 color MFP M175nw - multifunction printer / copier / scanner color
Imaging Drum HP CE314A has less than 10% remaining
4 Suggested Answers
  • 6 Answers
SOURCE: Imaging drum LED stays on continuously
When the Imaging Drum LED stays solid on, it means your imaging drum is running low and will soon need to be replaced. You can unseat, then reseat it and see if that solves the problem.
If everything is printing fine, don't do anything until the LED starts flashing. HP will tell you to replace the drum immediately, but mine was on for a year, with moderate printing, before going to the flashing, "empty" state. This is the same advice as for toner cartridges, which are sometimes as much as 50% full when the light comes on.
However, I suggest sourcing a new drum so you can be prepared for when the existing one goes out. Also, despite HP's warnings of gloom and doom, aftermarket products work acceptably.
Posted on Jul 24, 2009
Testimonial: "This was very helpful. Thanks"
brett207
  • 231 Answers
SOURCE: HP 2550n -rotating the imaging drum backwards?
There is a locking mechanism that actuates when the front door is opened. This is a safety device, and should only be tampered with if you know what you are doing. Also, make sure you unplug the mains power before proceeding.
Having given you air warning, proceed at your own risk...
If you look up near the RHS door hinge there is a slot for the safety interlock. Use a small screwdriver to push the locking lever toward the rear of the device. The Carousel should now rotate by hand
There is a fairly common fault with this model involving this mechanism. It may need the lock and associated mechanism replaced
Be careful and Good Luck...
Posted on Dec 08, 2009
Testimonial: "Thank you, got it fixed!"
brett207
  • 231 Answers
SOURCE: HP 2550n laser - black "toner" on imaging drum.
try replacing your Black toner cartridge first
repost here if it doesn't fix it.
Posted on May 06, 2010
How do I reset the CE314A HP imaging drum chip?
The chip would need to be replaced. Usually if you have some type of refill kit it would come with a chip. You can usually find them on ebay as well.
Feb 14, 2015 | HP LaserJet Pro CP1025 CP1025NW Laser...
Removing a error message on a samsung CLX MFDevice
Hello.
Causes :
  • The remaining life of the imaging unit is less than 10% of its life.
  • The remaining life of the imaging unit is less than 0% of its life.
solution:
  • Replace the Imaging unit (Toner). remove the old toner and replace it with a new one, look in the user manual for detailed steps.
Additional help :
if you need further assistance on how to replace the Toner, please give me the Printer's Brand and Model and i will provide you with detailed steps.
Thank you.
Aug 29, 2012 | Samsung CLX-3185FW MFC / All-In-One Color...
Hi, we have the hp color laserjet 2840 series and we are getting a supply error (10.1004). The picture shows that there is a problem with our imaging drum. We bought a brand new imagind drum and it is...
Reseat the toner cartridge. Turn the printer off, and then back on again. You may want to try a new cartridge, but if that does not eliminate the error, call your HP support line. If the imaging-drum light is still blinking but the Attention light is not on, you must replace the imaging drum before the printer can continue printing. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition. The printer has determined that it cannot read or write to the e-label on the imaging drum.Reseat the imaging drum, and then power cycle the printer. If this does not work, replace the imaging drum. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on. If the problem persists, replace the imaging drum E-label reader. The imaging-drum light might be blinking by itself or at the same time another light is on or blinking. If another light is also on or blinking, turn the imaging-drum light off in the simulator and turn the other light on or blinking to isolate the condition.
If Hope that this helps,, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks,Joe
Feb 04, 2011 | Office Equipment & Supplies
How to remove the cause of a black line a HP Laser Jet printer model 4250 has produced down the center of everything printed for a long time? Thorough cleaning has had a very little effect.Last week I...
In cases of print quality issues you should always start with the imaging drum. In this case the toner cartridge. Make sure it is not a re-manufactured or refurbished toner cartridge. A lot of times when someone refurbishes the cartridge they don't replace the imaging drum (the blueish green drum under the shutter). Check for toner stuck or burned on the drum. If there is you need to replace the toner cartridge
If there is no toner stuck or burned on the imaging drum then you more than likely you will need to check or replace the Fuser in the back of the machine. The back door of the machine comes out easily enough and the fuser clips into place. **Be careful it doing to be hot.** Remove the fuser and check the rollers inside for burned toner or damage. If so replace the fuser .
You can purchase a Fuser Kit from HP or find a refurbished fuser from Depot America or OrionMarket.com for a lot less.
Aug 16, 2010 | HP Office Equipment & Supplies
May 05, 2010 | HP Office Equipment & Supplies
Hp deskjet 1513 all in one
Great you changed the toner cartridges but you may also need to do the following as well.
Imaging drum is low Light pattern c00189128.jpg Description The imaging-drum light is on. The printer continues to print without any action required until the imaging drum is empty. Action Order a new imaging drum. Have a good day
Jun 18, 2009 | HP Office Equipment & Supplies
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
Apr 27, 2009 | HP Color Laser 2550N Printer
Apr 22, 2009 | HP Color LaserJet 2550n printer + HP Color...
Replacement drum for Q3964a
HP Color LaserJet 2820 and 2840 AiO Series Products - How to Replace the Imaging Drum Replace the imaging drum
  1. Push the scanner-release button to open the scanner assembly. Figure 1: Example of scanner release button location c00364331.gif
  2. Open the top cover. Figure 2: Example of top cover being opened c00364332.gif
  3. Grasp the imaging drum handle, and then rotate the drum until the handle is at the top.
    NOTE: The drum may be a snug fit. If needed, gently apply some force while rotating and removing the drum. Figure 3: Example of imaging drum rotation c00364333.gif
  4. Lift the imaging drum straight up to remove it from the device. Figure 4: Example of imaging drum removal c00364334.gif
  5. Remove the new imaging drum from its packaging.
  6. Place the imaging drum on a firm surface, and then pull the orange rings to remove the shipping pins. Figure 5: Example of shipping pin locations c00364335.gif
  7. Remove the orange shipping lock on each end of the imaging drum, and remove the two orange shipping spacers. Figure 6: Example of shipping lock and spacer locations c00364336.gif
  8. Remove the orange cover from the imaging drum. Figure 7: Example of orange cover location c00364337.gif CAUTION: Do not touch the surface of the roller or expose the roller to light for an extended period of time. Doing so could cause print-quality issues.
  9. Align the arrows on the side of the imaging drum with the arrows inside the printer. Figure 8: Example of arrow location c00364338.gif
  10. Lower the imaging drum into the printer, and then press it firmly into place. Figure 9: Example of imaging drum installation c00364339.gif
  11. Close the top cover and the scanner assembly.
Feb 27, 2009 | HP LaserJet 2840 All-In-One Printer
Samsung CLP 510 Imaging Unit
The Imaging unit needs to be replaced when the drum fills up with waste toner. That's what triggers the message.
Feb 02, 2009 | Samsung CLP-510 Laser Printer
HP LaserJet Pro 100 color MFP M175nw - multifunction  printer / copier / scanner   color Logo
99 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
