Question about 3Com (3CRUSB10075) 802.11g/b Wireless Adapter
3CRUSB10075 win xp - 3Com (3CRUSB10075) 802.11g/b Wireless Adapter
3crusb10075 driver for win 8
If you post the Make, Model of laptop it would be helpful.
Mar 11, 2013 | Computers & Internet
My win 7 os cannot recognized the crusb10075 3com adapter.
1. Don't plug your WLAN USB adapter until setup finish and reset the computer
2. Download XP driver from 3COM in below link... make sure to select the correct one depending on the serial number of your adapter (starting with 0100/0200/0300)
http://www.wireless-driver.com/3com-officeconnect-wireless-54mbps-11g-compact-usb-adapter/
3. Double click and it will automatically unzip and may ask you again after unzip use recommend settings and click yes to use recommend settings and click yes to all to overwrite again the folder unzipped again but if didn't ask it is OK.
4. In the unzipped folder right click on the setup file and click properties then go to Compatibility tab. InCompatibility mode click "Run program in compatibility mode of" then chose Windows XP (Service Pack 2) and OK.
5. Click setup now and after installation finish restart your computer.
6. After reset plug you USB adapter and will take some time to install the driver.
Apr 20, 2011 | 3Com (3CRUSB10075) 802.11g/b Wireless...
Wont work on win7
http://webprd1.3com.com/swd/jsp/user/index.jsp?id=WUSB5
This link is for the vista driver and it is confirmed to work in windows 7. Per the link on a forum im going to add below this.
http://kampiabareh.blogspot.com/2009/11/download-driver-3com-3crusb10075-for_17.html
Mar 08, 2011 | 3Com (3CRUSB10075) 802.11g/b Wireless...
Will Win 7 support the 3com 3crusb10075 drivers
No win7 will not recognize the xp drivers.... you need to download the latest drivers for win7 from the 3com support site...
Aug 10, 2010 | 3Com (3CRUSB10075) 802.11g/b Wireless...
Security for 3CRUSB10075 802.11g/b Wireless
I did not solve the problem. I chose an easier way. I just replaced the 3Com Wireless Adapter with a NetGear USB adapter for which I have security instructions.
Kind regards,
stigfred
Oct 12, 2009 | 3Com (3CRUSB10075) 802.11g/b Wireless...
3COM Office Connect 3CRUSB10075
are you using windows xp? vista? 98?
I'll guess at xp.(and that you're using the windows software to connect)
Double click the wireless connection icon in the bottom right (the one that flickered when you're online.
Click 'view wireless connections'
click 'change the order of preferred networks'
Now select everything on the list and delete it apart from your own.
Now click 'advanced'
make sure 'automatically connect to non-prefurred networks' is NOT ticked.
Click close, then ok.
You should be ok now.
Regards
Tony
Feb 28, 2008 | 3Com (3CRUSB10075) 802.11g/b Wireless...
Wireless 3crusb10075 problem
Sounds as if your router may need to be set to enable wireless connection and enable DHCP, this alocates your wireless adapter an I.P Address automatically. If this is alraedy the case, check the properties of your adapter to see if it's set to recieve I.P address automatically. If still no joy find your routers I.P. address and DNS address (this is what you type in your web browser to set it up). If your router is 192.168.2.1 or similair, set your adapter at 192.168.2.2 and the same DNS address normally 255.255.255.0. Restart both pc and router and try again. Also make sure network sharing has been set up via the XP wizard.
Dec 14, 2006 | 3Com (3CRUSB10075) 802.11g/b Wireless...
3Com (3CRUSB10075) 802.11g/b Wireless Adapter Logo
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
