Question about Dryers
The machine won't turn on (no power light even). Trying to find the reset button. Where the cord enters the machine on the back ( top left) there is a a plastic cover housing the cord. I cannot see
Not switching on no power, have checked plug fuse and socket work with other items!
    Scholar:
    New Friend:
  • 81 Answers
Sounds like you have a bad door switch. Check to make sure there isn't a broken switch in the door housing. If not, this unit has a belt switch on it. Try spinning the drum by hand. If it's really loose and not tight, you need a new belt or the machine wont start.
Posted on Nov 27, 2013
4 Suggested Answers
Rotu
  • 175 Answers
SOURCE: Dryer Won't Run
There is a little button on the back of the dryer that needs to be reset. It looks like a little black circle, just push the center and you should feel it click. Once you have the dryer running, go outside your house and check that air is flowing freely from the exit. If it is not, you have a clog in your venting or inside the machine itself, and that has caused it to overheat and trip that protection switch. Also, make sure your lint filter is VERY clean. this sounds dumb, but these askos are very picky about that. Take the screen and scrub it with a soft nylon brush with some soap and water. Also, don't use dryer sheets in these as they tend to clog up that screen with an oily residue. If you must use dryer sheets, at least clean that screen with soap and water on a regular basis. If the vent is not clogged and the screen is clean and the flap on the outside of your house is clear, then the machine needs to be disassembled and cleaned out internally if ti keeps tripping that switch. Hope This Helps!
Posted on Dec 17, 2006
  • 131 Answers
SOURCE: Drum light works - contol lights don't/can't start dryer.
Either the machine control, or the user interface. Further diagnosis isn't possible. I'd try the machine control first. It's just under the top panel, along the left side.
Posted on Mar 10, 2008
wayneard
  • 1901 Answers
SOURCE: Dryer wont work!
A couple suggestions: (1) The switch in the front may be bad. It's the switch that turns the dryer off when you open the door. (2) Make sure the door latch keeps the door shut. If it is worn and the door isn't shut tight, the switch will not let it start. Hope this helps.
Posted on Oct 15, 2008
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Ran over power cord and now won't start with new cord.
did the breaker on the plug your using trip?do you have a gfi outlet that tripped?
Jul 01, 2012 | Garden
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
My fridgedaire window unit A/C and heat won't come on. I had replaced an outside light fixture a couple of weeks ago and had turned off the circuit breaker that affected this unit too. Now the unit...
Plug a light into the outlet used for the A/C, if the light does not come on when reset then the circuit breaker that provided the power to the outlet need to be reset or replaced.
May 22, 2011 | Frigidaire FAS257S2A WallWindow Air...
My ricoh aficio mp 2000 have the error sc 542 what i can do to sorve this.
Reset the code via SP Mode (I will not tell you how to enter SP Mode, you must research that). Once you are in SP mode enter System or Copy SP and turn off the machine to reset.
The code is actually referring to a thermistor problem in your fuser, regardless, if your machine is under maintenance request service (obviously, I do not think it is under maintenance or you would not be asking). Other than that, once this thermistor completely flakes out your machine will be rendered useless.
P.S. ALWAYS GET MAINTENANCE ON YOUR COPIERS, quit being cheapskates.
Source: Ricoh's Tech Support Goose Guide. Ricoh Qualified Copier Technician.
May 02, 2011 | Computers & Internet
Bought new power supply, no difference power button will not even go on or light up ; however small green light on mother board lights up. als accidentaly disconnected the switches wiring to the mother...
The green light just show that the motherboard is getting power.
The power button of the front of the case is connected to the mother board, not to the power supply, usually in the extreme lower left corner along with the with the HDD and Reset Button cords; Power button wire are labeled and usually red/black.
If all wired correctly, possible bad or stuck power button or reset button.
Hope this helps.
Please rate this answer by check rating "Hands"
Feb 08, 2011 | E-Machines T3958 (827103050974) PC Desktop
Set Date
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left ] or [ right ] to select <USER SETTINGS>.
3. Press [OK] two times.
4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
5. Press [OK].
6. Press [Stop/Reset].
Sep 13, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Need help
the pin arrangement is 4 pins and pins.
From left top row (4 pins) first 2 are power led, next 2 are power switch, next 1 is empty
from left bottom row ( 5 pins ) first 2 are hdd, next 2 are reset, next 1 is empty.
The connectors for the power led and the hdd produce a light, if they don't produce a light, power off your pc and switch the cables round the other way and power on again.
Oct 30, 2008 | E-Machines (308714) Motherboard
Dryers Logo
93 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
