Question about Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum
Hot Smell when I run it
I have a Hoover Fusion Cyclone vacuum that's only about 2 years old. Just this week when I turned it on it started to smell really hot, so I decided to check the belt. It looked fine but there was a ton of junk all around it so I cleaned it out. I thought that solved the problem but after about 2 minutes the smell came back. I'm not sure if it's the motor or what. Any help would be appreciated.
    Master:
  • 492 Answers
Check to make sure there is no hair on the ends of the axel. Hair will sometimes wrap up around the axel and make it hard to turn. Cut off with razor and place a drop of oil on the ends.
Posted on May 08, 2009
Motor issues
A faint burnt plastic smell is actually normal for these when brand new, but that normally disappears after a week or so. As for sparks, a thin trail of blue sparks trailing along the commutator (the uppermost part of the motor that can be seen rotating) is normal. However, if there are blue, orange sparks flying out of it its toast. The motor is dying in that machine.
Nov 23, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
I've had the Hoover Windtunnel for a couple years now. Its starting to smell when you vacuum. Why and how do I fix it???
I was experiencing the same problem right after changing the belt for the first time, as my Hoover is just a few months old. I am assuming what you are smelling is burnt rubber, like your belt, right? Well, if you have changed your belt recently, make sure you are using the right one. If you're not using Hoover's authentic belts and you're buying it from Wal-Mart, make sure it's the correct one, otherwise it won't work right and/or it will give off a burnt rubber smell. One other thing you could try doing first, is raising the carpet height adjustment up a notch or two. If you have it too low and your beater-bar/brush roll has to work too hard, it will start to smell also.Good luck!
Aug 07, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Dc 14 animal emits a terrible smell after about ten minutes of us
You can take a Febreze sheet and put it into the canister/dirt bin where the dirt spins around. It'll spin around whilst you vacuum your house and it'll spread the fragrance through the vacuum and hopefully get rid of the smell for you.
You can also blow out the cyclone with an air compressor or a leaf blower by opening the bin door on the bottom of the dirt bin and blowing up the cyclone in the middle - perhaps there is something lodged up there that is causing the foul odor.
Mar 21, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Mar 13, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover U5344-950
Is it a rubber smell or an electrical smell, If it is a rubber type smell then maybe the belt or brushroll has a problem. If is a electrical smell, then would be coming from the motor. How long have you had this? Hoover has a one year warranty, so if it less then a year, take to a shop that does Hoover Warranty. You can call theur 1-800 number and they can tell you where you can take it. The number is on the metal tag where the model number is.
Jan 22, 2008 | Hoover U5344-900 WidePath Vacuum
Hoover empower
Don't ignore your instincts. If you think it smells like a scorching belt, you're probably right. Check that the pulley the belt is meant to spin is free to turn. If it isn't, find out why and then sort that out. A.
Feb 24, 2007 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Hoover Fusion Plus Cyclonic Upright Vacuum Vacuum Logo
181 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
