I have a Roper Model RTW4440VQ2.
The water fills up to the desired level, but the cycle won't start. In short, the machine is not cycling through at all, and it's making a humming sound.The humming sound comes from behind the cycle switch.( meaning the the round knob that you chose which cycle to put it on.)
    Genius:
  • 1,198 Answers
If you can rotate the timer to different places and the machine agitates and spins but the timer doesn't advance on it's own, then the timer motor is not engaging the timer, may have a bad gear. Usually you have to buy a whole timer to get a new motor and gear.
Check Repairclinic.com to see what's available.
Posted on Nov 26, 2013
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: roper machine issues
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
Roper washing machine does not fill for rinse cycle. Goes directly to rinse agitate without water.
Without Model number I am only guessing but I suspect you have a blocked sensing tube that travels from the Level selector switch to the side of the tub somewhere. It is possible for this plastic tube to become partially clogged and not allow trapped air to vent when tub is drained of water. Usually this problem manifests itself as an overflow of the tub. Check the full length of this clear hose and see if the end nearest the tub looks like it may have debris or dirty detergent clogging it.
This hose is pushed onto a nipple mounted to a reservoir on the side of the tub. Push a thin copper wire 4-5 inches into the those after removing from nipple and also down into the nipple an inch or two before reinstalling the hose to the nipple. You MIGHT even blow into the hose while you have it off and you SHOULD hear a clicking sound coming from the level selector switch body.
Good Luck. Come back with Model number under lid if that doesn't help.
Nov 28, 2015 | Roper Washing Machines
Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Nov 11, 2011 | Samsung Washing Machines
My washer fills and doesn't stop. I try to advance it to the spin cycle but none of the cycles work. I changed the lid switch because it wouldn't fill at all. Now it fills and nothing else. Tested...
The fill switch is bad. That's the only "safety" on the washer that will shut the water off after reaching desired depth. To test it, run your machine on the various water levels. For example, start out on the low setting. If the water doesn't shut off after the tub is half full, then it's the fill switch inside the unit next to the tub.
Sep 13, 2011 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
I have a Roper top load washer. when i start it, it automatically starts on agitiate. It skips the filling cycle. model# RTW4100SQ1
It sounds like you have a bad water level switch.The switch is the one you turn to set the water level.
Jun 24, 2011 | Roper RTW4100SQ Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Low Water Level in Roper washing machine
You need to check the pressure switch which is also called the water level switch. There is a small tube attached to it and it may have a blockage or a hole in it. You can find this behind the control panel to the left of the timer.
Nov 14, 2009 | Washing Machines
Water runs contiuously... tub never fills...cycle doesn't start.
Hi, You need to reset the drain hose. It needs to be over the water level in the machine. If you have it in a sump pump, it needs to be out of the water in the sump. If I can help you further, please let me know
Thanks
Vic
May 16, 2009 | Roper RTW4100SQ Top Load Washer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
