Question about Tablets & eReaders
How to hard reset INSIGNIA table - Tablets & eReaders
Insignia tablet will not charge
First, make sure your charging cable is not broken. Also, try plugging your charger into a different outlet. If your charging cable and outlet are not the cause, you more than likely have a faulty battery. You can try the troubleshooting page for the Insignia model. It is also possible something is bent where you connect the cable. If you rule these things out and you have visiting troubleshooting. You might try a hard reset.
Aug 13, 2017 | Tablets & eReaders
Can you connect a external hard drive to a insigna flex 8 tablet. Keep getting message running out of memory storage
Most likely yes. You will need OTG cable. You will need external hard drive with own power supply or tabled may not be sufficient to power up hard drive. It is safer to use usb stick.
Oct 15, 2016 | Insignia - Flex 8 inch Tablet with 8GB...
Can you connect a external hard drive to in sign a flex 8 tablet
How do I unlock my tablet?
You will need to reset it. Usually on Android, this involves holding the Power Button and the Volume Up button for 20 seconds. Then follow onscreen prompts for Factory Reset.
Jan 31, 2016 | Insignia - Flex 8 inch Tablet with 8GB...
Will not turn on
If it is not down to a dead battery, (many batteries show that they charge full but they cannot hold that charge so they no longer switch on,) I would search on line for a method to hard reset the device. Remember that if you do go down that road you may lose any data stored on your device.
Try the battery first.
GOOD LUCK CARLOS
Nov 05, 2015 | Insignia - Flex 10.1" Tablet with 16GB...
How can i recalibrate my tablet
This unit does not have a screen calibration app.
Recomend returning the unit to exchange for another.
Apr 27, 2014 | Insignia - Flex 10.1" Tablet with 16GB...
Need to hard reset insignia flex
There are two options for resetting the Insignia FLEX:
1) Insert a straightened paperclip into the reset hole on the side of the unit.
2) Hold down the volume up or down key while pressing the POWER button.
Dec 09, 2013 | Insignia - Flex 10.1" Tablet with 16GB...
How to reset insignia flex 10.1
Basic reset or complete "back to original out of box"?
Basic resets are by either inserting a straightened paper clip into the reset hole on the side of the unit, or by pressing the volume up or volume down button AND the power button.
Back to out fo box is going into settings - backup & reset, and choosing factory data reset. This will wipe out your account, data, apps, everything...just like you took it out of the box the day you got it.
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
