Question about Mackie SWA1801 Subwoofer
The power has just gone off on my swa1801
It was working and then not!
Both my 1801s gone over xmas..fuse at bottom of board popped when swiched on, replaced fuse but no sound now although LEDs are on?
Fuses blow because of an overload. In this case it will be a shorted semi-conductor. Most likely in the main amp section. Maybe the main amp itself. It might be attached to a heatsink.
Jan 24, 2013 | Mackie SWA1801 Subwoofer
Hi. I have problems with my SWA1801. When I try to start the amp, the Thermal light goes on. Even if the amp is cold ! What can it be? I have turned down the gain on the back and have good cables to the...
Power it ON, without anything connected to the input.
If it powers On without the thermal light, then rejoice,
If it powers On with the thermal light it means something...
Oct 23, 2012 | Mackie SWA1801 Subwoofer
Components Q12 & Q13 (2N 3906) PNP transistors fried. Would there be anything else blown?
It is sad your having a problem with Q12 and Q13, check the regulator
that supply voltage on the transistor 's your referring to.
Q13= 2SA1478 for Mackie SWA1501 Active Subwoofer
the supply is about +15V and -15V
Aug 20, 2012 | Mackie SWA1801 Subwoofer
Model swa 1801 Fuse 240V 4A burned out ! I replaced it but still get no power (any led stay off) What can it be ?
check for integrity of the main amp and the torroidal transformer.
here is a guide , how to check for transistor
if there is a continuity on the primary terminal of the transformer.
Have a tech to guide you , should you need to DIY.
Sep 17, 2011 | Mackie SWA1801 Subwoofer
No power
There are about 6 fuses on the inside. check them but the amp is probably blown
May 26, 2011 | Mackie SWA1801 Subwoofer
The thermal light comes on on my swa1801 and lose all audio what could be causing this to happen?
make sure its plugged into a large circuit over 30AMP! Turn down the gain on the back. They can't take too much punishment so turn the bass down on the eq. Get a stronger sub
Jul 01, 2010 | Mackie SWA1801 Subwoofer
How do you get to the ac fuse on the SWA1801 ?
There are 4 allen-head screws that hold the amplifier assembly in - two on top and two on bottom. Remove these and the entire thing slides out the back. There is one fuse near the power switch and two on the power supply board inside. Be sure to use the correct value.
May 13, 2010 | Mackie SWA1801 Subwoofer
Mackie swa 1801 power amp R7 100 ohm resistor smokes when powered up..
You likely have other parts blown as well, but Q3 (MJE15033) AND/OR r8 (1 OHM/0.5 Watt) are blown. I suspect that Q3 has a base-collector short and you will find several of the output transistors are fried as well Q4, Q5, Q15, Q16. I suspect that the Zeners D14, D25 may be blown.
When restarting this, put a 100 Watt lampin series with teh 120 volt power to limit current and avoid destroying freshly repaired parts due to a few bad ones not found.
Aug 17, 2009 | Mackie SWA1801 Subwoofer
MACKIE SWA1801--Sound quality is not same
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
Mackie SWA1801 Subwoofer Logo
56 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
