Explain the different unit of temperature and give the relation between them
  • Computers & ... Master
  • 7,993 Answers
You have the Celsius Scale characterized by
Freezing Point of water :0 deg C
Boiling point of water : 100 deg C
The Fahrenheit Scale characterized by
Freezing Point of water :32 deg F
Boiling point of water : 212 deg F
If F is the value of a temperature on the Fahrenheit scale, the corresponding temperature on the Celsius scale is given by
C= (5/9)*(F-32)
If C is the value of a temperature on the Celsius scale, the corresponding temperature on the Fahrenheit scale is given by
F= 32 +(9/5)* C
Posted on Nov 25, 2013
Is it normal for my 2005 1.4 utility to take so long to reach normal working temperature? I drive 30km to work every day and the gauge only lifts up an inch
The answer could be one of many. You may have a thermostat that opens at relatively low temps. Or the temperature sender is getting ready to fail (this was my problem). So long as there is no indication of coolant loss or signs the engine is running hot, I wouldn't worry. My temperature gauge has been sitting rock bottom without movement for some time (a couple years). Parts store keeps giving me the wrong one. My truck still runs fine. And since the idiot light is on a different conduit, I'll wait till I can leave my truck sitting for a bit, remove the offending sending unit, and take it to the parts shop to show them just what it is I need.
Jul 09, 2014 | 2005 Opel Corsa
Cooling fan wont turn on
you are expecting the wrong temperature unit to control the fan. The temperature sender unit controls the temperature gauge and the temperature sensor unit controls the fan operation. It allows current to go to the ECM and when a pre set temperature is reached the ECM activates a relay and the fan starts . Two completely different units to do two different jobs so if it is doing what you say then there is a possibility that the wires are crossed or shorted.
Jun 20, 2014 | 1993 Dodge Spirit
What if code sf and h5 comes up
The two may be related? If the right problems are present...
HS = High Limit Sensor
SF = Temperature Sensor or Thermistor
Heaters Maximum Water Temperature has been Exceeded.
Heaters Set temperature not in line with actual water temperature.
A few reasons this occurs...
  • Low water flow thru heater, check :
    • Dirty Filter
    • Opened By Pass Valves
    • Plugged pump impeller
    • Dirty/Full baskets at skimmer or pump
    • Anything that may reduce water flow
  • Sensor could actually be doing its job, in a different aspect, Thermostat failure, and water is overheating in spa or pool?
But anyway, your heaters fault code you asked about is does not necessarily mean they failed. They are informing of a problem.
May 25, 2014 | Hayward H-series Electronic Gas Pool...
Unit not cooling house below 80 HELP ME PLEASE
It's 98 outside ... that says a lot. The gurgling is an indication that you are getting a lot of water out of the air (dehumidifying). If the unit is sized just right, or just a little too small, it may be working perfectly well.
You don't say where you are, geographically, but much to the US has an air conditioning design temperature of 95 degrees F. That means at 95 degrees, the unit will run continuously. With a 50% outside air relative humidity, it should keep the occupied space at about 75 degrees F. The more humid the air, the more the unit works on dehumidifying and less on cooling.
Give it some time, wait unti the weather breaks and see if it doesn't run just like it used to. If you chose to call a technician, have him/her take temperature readings of the condenser entering and leaving air, the suction line temperature, the liquid line temperature, the inside supply and return air temperature (dry bulb and wet bulb) as well as high and low side refrigerant pressures. Before they make ANY changes to the system (refrigerant charge) have them explain what they found wrong and make sure you understand what they are talking about. Adjusting the charge under these conditions, will mess up your operation under normal conditions.
Jul 20, 2010 | Whirlwind FH-778 Air Conditioner
Out of 48 PTACs why only one is releasing too much water
There may be a breeze or draft near it. The wall or something around it may be damp. Maybe alot of human or animal activity near it. There can be many causes for humidity. Then again, the unit may just run better then the rest and removing more moisture.
Aug 11, 2009 | Amana PTH153B25AJ Heat Pump Air...
Help me with death problem error code error code E000001-0002
this error is related to fixing unit problem try this press * with head 2&8* with head on the LCD panel press Copier>function >clear>err> ok Switch off/on the machine or check the main AC supply if it is stable or not. hope this helps
Aug 10, 2009 | Canon imageRUNNER C3200 Copier
Principle of speed control on treadmill motors
Different manufacturers may employ different speed control techniques, related mostly to accuracy and cost. However, this link is probably representative of many PWM (pulse-width--modulated) controls. There are other ways to control speed and torque.
May 07, 2009 | Heating & Cooling
Undependable freezing - sometimes will, sometimes won't!
High room temperatures will throw this unit off BIG TIME. Just to give you an idea how sensitive the freezer bowl is - if you run cold water along the freezer bowl before putting your ingredients in, the COLD water is enough to unfreeze the bowl! Don't remove the freezer bowl from freezer until you are immediately ready to begin mixing - not 5 minutes earlier.
-Tha Mp3 Doctor
Nov 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
What is the Dry setting on air conditioner?
Hi, I know this question's been up a while and I'm not sure if you care anymore but here goes anyway.
Most air conditioners are reverse cycle, so they can heat the air in your house or cool it down. What we are concerned with is the cooling side of things. So in this mode a working liquid is sprayed into the evaporator and cools its immediate surroundings. air is blown over the evaporator which cools the air. The local temperature around the evaporator is very cold, (how cold exactly I'm not sure) so the air in this region has a very poor ability to hold water and so (especially on a humid day) water condenses out of this air on the surface of the evaporator, is collected and drained away. The cooling function and dry function both use the "cooling" mechanism of the air conditioner. Both extract water from the air in this way but the primary purpose of the cooling function is to cool the air whereas the primary function of the dry setting is to dry the air... obvious I know.
Now in the dry setting the compressor will run with fan going at I imagine a relatively slow speed to chill and extract as much water from the air as possible and to minimise circulation. After a short time the compressor and fan will cut-out and then after a short interval start up again (I'm not really sure but I assume this is either controlled by a humidity sensor OR the temperature sensor monitors for a small change in temperature and shuts off the compressor and fan when it detects this). Now in cooling mode (depending on what temperature is set) the compressor will run for longer and more frequently and therefore remove more water. So why have a dry mode if cooling mode removes more water?... Well that really has the same answer as the question "when do I use dry mode?"
Well on a particular day where the temperature would normally be considered comfortable but on this day it is unusually humid, your body will find it difficult to radiate heat via sweat because of the already high RH (relative humidity) making you uncomfortable and feel "hot". Using dry mode will reduce this RH without adjusting the temperature by much, but you will perceive an ambient temperature drop due to your body being able to discard heat more easily... hence making you more "comfortable" in same way you would normally feel at that temperature.
On the contrary if you were to use cooling mode (which is regulated by temperature) you would have to set a temperature lower than ambient so that the compressor will "kick-in" rather than the air conditioner just running its fan...agree? So that means the air conditioner will reduce RH (which we want) giving you a perceived temp drop but it is also chasing the temperature which you set which will give a REAL temperature drop. So anyway the point is; if it was an unusually humid day on what would otherwise be a comfortable temperature, using cooling (remember the temp has to be set lower than ambient) instead of dry would result in you feeling cold very quickly due to the perceived AND real temperature drop.
So really the dry setting is for days which aren't too hot, but are humid.
I think my logic makes sense.
cheers Matt
May 30, 2008 | LG L1204R Air Conditioner
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
