Keeps turning on and off and blowing cold air
  • 499 Answers
See the wiring diagram below,Kill power 1st, remove the Red and White wires from the thermostats sub base after you have removed its cover.
connect the red to white and restore power, this effectively removes the thermostat from the equation. If it still cycles note the diagnostic code on the furnace.
Keeps turning on and off and blowing cold air - 05882599-0f03-493a-b83b-14aff9c407bb.png
Posted on Dec 16, 2013
Carrier apu blows cold air for twenty seconds and fan quits engine keeps running and fan starts again but only blows cold air for another twenty seconds
Have you tried rebooting the system? Just turn off the breaker for a few minutes.If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 07, 2017 | Carrier Heating & Cooling
Blows cold air turn heat on
Search Results
    07 Tucson heater blowing cold air - Hyundai Forum - Hyundai ...
    www.hyundaiforum.com > ... > Vehicle Line Up > Hyundai Tucson
    Dec 16, 2009 - I have a 2007 Tucson, when you turn on the heater it only blows hot air... Join Date: May 2005 ... a low coolant level will exhibit the first stated symptoms of no heat/low heat at idle and increased heat at cruise due to an air ...
    Denlors Auto Blog » Blog Archive » Car Heater Blows Cold ...
    www.denlorstools.com/autoblog/.../car-heater-blows-cold-auto-service-ti...
    Oct 10, 2009 - When a car heater blows cold air, there are several possibilities that should ...... On my Dodge Neon when I turn on the heat it blows out cold air.
    Heater blows only cool air...even w/ defroster on : Buick ...
    repairpal.com > Problems > Buick > LeSabre
    ... Cadillac, Chevrolet, Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer,Hyundai, Infiniti, Isuzu, Jaguar ... I'll turn up the temp on the dual control to get heat,
Jan 28, 2016 | 2005 Hyundai Tucson
Heater keeps cycling from hot to cold. tried to calibrate. dident work.
AC blows cold, then hot, then cold... - Car Forums and Automotive ...
www.automotiveforums.com > ... > Chevrolet > Blazer
A/C now turns on but will blow cold air for 5 seconds then back to hot for the same. ...It seems be be left of the heater box somewhere but it is definately inside. .... on this '98... the things just keeps turning in there, hot, cold, hot and so forth.
Sep 22, 2015 | Cars & Trucks
My Nissan Almera 2005 Model keeps blowing heat even when the switch is off. now when l turn on the aircon hot air is mixing with cold air. Could it be the blower resister?
Could be the diverter paddle control that moves to allow cold air or hot air into the duct. It may be staying in the heat position even when you set the control to cool.
Jan 02, 2015 | Nissan Cars & Trucks
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Hotpoint RLA51 fridge keeps freezing up
A fridge makes cold air in the freezer only and blows it into the fridge throu a little air door with a small fan, one of your temerature adjustments will open and close this little door and the other ajustment (the thrmostate) will turn on and off the compressor at what ever temperature you have it set for. if the little door is closed to much the cold air can not get into the fridge fast enough to make the temperature cold enough to turn of the thermostate. This will cause items to freeze near the air door as the air comming out of it will be something like -20C. to fix this it sometimes helps to open this little door more... something like "freezer temp warmer" and also to turn the "fridge temp warmer". if that does not do it, then the thermostate may be faulty, to test it slowly turn it down untill the fridge turns off, if it only turns off at the off position, replace it. also one last thing , sometimes the airdoor can frost up and restrict the air from blowing into the fridge, so you can unplug the fridge and leave the doors open for the weekend and let everything thaw out. then set all the controls for normal and plug back in. Make sure you do not leave the unit plugged in or sometimes the little door light can get so hot it may melt the plastic lining in the fridge.
Feb 08, 2013 | Refrigerators
My 2002 Avalanche's air conditioning quits blowing cold air when in stop and go or stopped traffic. The air still blows out, but it is very hot air. Sometimes if I turn it off and then turn it on once my...
You may want to have your fan clutch checked. If the fan on your water pump does not spin very hard when the vehicle is idleing than it doesn't draw air through the condenser and that air keeps the condenser cooler plus it keeps the pressure down on the high side of the ac system. leave comment.
Jun 28, 2010 | 2002 Chevrolet Avalanche
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
