Question about Makita 10" Dual Bevel Sliding Compound Miter Saw
Cornice mitre angle
How to cut an outside sloped roof corner cornice
    Scholar:
  • 171 Answers
Try this ... http://www.constructionknowledge.net/public_domain_documents/Div_6_Woods_Plastics/Partial%20Carpentry%20pdfs/Finishing_Roofs_NAVEDTRA_14044.pdf
Posted on Nov 25, 2013
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
How to mitre corners
using a set square , The angle if 45 degrees is machined into the handle draw a line at 45 degrees across the surface you wish to mitre cut
clamp a piece of timber along that line and use it as a guide to cut with the circular saw
Apr 27, 2016 | Saws
How do I cut the the corners(miter) of Polystyrene cornice.
Try making the cut with the rear of the cornice against the rear of the miter box rather than the front as you would for cutting regular (not crown) molding. I hope you are not using a circular saw to cut polystyrene.
Dec 05, 2014 | Saws
How to build a dirt floor 20 by 20 shed
Put posts in ground.
Middle posts taller so roof will have slope
Nail 2x4s across from post to post to hold siding.
One row of 2x4s around bottom, 2 rows 2x4s around middle,
1 row 2x6s or 2x8 around top.
2x6s 2x8 will hold rafters
Nail 4x8 sheets treated plywood onto the 2x4s to make walls.
Install joists across top of structure from one wall to the other wall
Install rafters at correct angle to match slope of roof, be careful to each rafter exactly the same.
Rafters sit on outside wall
http://waterheatertimer.org/images/Pole-barn.jpg
Gene
Sep 01, 2014 | Hardware & Accessories
Hi my dewalt 708 lx sliding mitre saw, 110v, seems to only have half the power(speed) that it should have, and cannot cut timber on a compound cut because of this, any suggestions please.
I have heard complaints that this saw does not do well on angled cuts because of its low power. Try running a shorter and/or thicker extension cord and checking your input voltage. That's about all I can think of, hope it helps.
Mar 12, 2010 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
How to build a wooden pyramid frame for school children, 2metres on each length of base.
cut 4 pieces of 2x2 to1.5 inches short of 2 metres. lay them out end to end to form a two metre box. it can only work one way. then take string from corner to corner to find the center, making a crosshair. then stand a level rod at the centre to the desired height and fasten equal length lines from each corner to the peak. using a compound mitre saw, place an angle finder at the bottom and top corners to give you the angle to cut your piece with the saw set at 45 degrees, to give you your compound miter for the top. just set the saw blade to line up with the angle finder to get the bottom cut. the length of your "tight" string line frome corner to peak is your length of "hip" piece
Mar 10, 2010 | RTO M-D Building Products Carpentry &...
Dewalt DW707 compound saw
Did you sense an odd smell? Try removing the brushes, there should be two, it could be one is worn too short or the connecting wire is broken.
Oct 30, 2009 | Dewalt DW703 10" Compound Miter Saw
What do i do to cut inside/outside corners for crown molding
It is very hard to make proper cuts with one of these.
You may want to buy a power miter saw.
You would be better off marking your 45 degree angle and cutting it freehand.
If you angle your saw a little the face will look like it matches up better.
If you need more help post a comment.
Tim
May 03, 2009 | Stanley Tools/Goldblatt Tool No.20 - 600...
Mitre saw won't cut square
You will have to use a regular square to check out the crafstsman and find out where it is wrong.
Jan 16, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Makita 10" Dual Bevel Sliding Compound Miter Saw Logo
145 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
