Question about Maytag Washing Machines
Washer stops before rinse cycle
Have replaced timer/timer motor module. Not lid switch either (people point to this but the washer obviously would not get past "go" with a faulty lid switch). Timer is audible as the spin is finished and enters the rinse cycle. Then there is a light click and the timer noise stops. So the rinse water never fills the tub and the timer never advances. This happens sometimes, not all the time. And always at the same cycle point. And only on the normal cycle, even after the timer module/motor was replaced. \Maytag A211 serial# 119009BF
  • Reed N
    Reed N Nov 25, 2013
    This is an older top loading machine. It drains fine. It uses a two stage spin to drain the tub. Please do not refer to pump issues as all things are working fine other than the Normal Cycle getting stuck immediately after the wash/spin... right before the rinse cycle fills the tub.
  • Maytag Master
  • 16,166 Answers
Check the water level sensor.
Posted on Nov 25, 2013
  • 2 more comments
  • Reed N
    Reed N Nov 25, 2013
    First, why would the water level sensor be the problem when the sensor works fine to allow the machine to fill perfectly to start the wash cycle (before it gets to the trouble spot at the rinse)? And, what does "check the water level sensor" mean? Use an multi meter? Where is the sensor location?
  • Brad Brown Nov 25, 2013
    There is a tube next to the drum that measures the water level. It can get clogged with softner and debris or it is being shaken during the wash cycle
  • Reed N
    Reed N Nov 26, 2013
    Brad... the unit drains fine at all other cycle points requiring the tube to drain. Sometimes pounding on the control panel will get the washer going (i.e. entering the rinse cycle).
  • Brad Brown Nov 28, 2013
    The repair guide is here if you did not find it attached to the framehttp://allrepairmanuals.com/maytag-washe... The only thing that interrupts the timer is the lid switch.
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
Washer stops during rinse cycle and beeps at me
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 02, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Washer stops at rinse cycle and give the ul code F1
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Sep 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Model 110.27802690 stopped after rinse, still full, won't respond. Checked power source, won't work in any switch position
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.27802690
I'm assuming from your problem that the washer went through its' first wash cycle, drained and spun, then filled again for the rinse cycle, went through the rinse and didn't go to the drain / spin cycle.
If that is correct, it appears that the motor, pump and transmission are working. It also appears that the Lid Switch is working. These are the main places to look for a problem such as yours.
If you stop the washer by pushing the control knob in, moving it to the spin cycle and starting it again, and the washer still doesn't spin, the problem points to a defective timer.
Before replacing the timer, I'd check the Lid Switch again by removing the two Trim End Caps and the two screws under them. Tilt the console back and disconnect the connector from the console to the lid switch.
Using a short insulated wire, jumper the Lid Switch at the console by jumping between the two outer pins.
Following is the Whirlpool Installation and Maintenance manual for these machines with a section on how to jumper the switch.
Then try to start the machine in the spin mode.
If it works, the problem is in the Lid Switch.
If not, It is likely in the timer.
Sep 30, 2009 | Kenmore Washing Machines
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
157 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
