Question about Microsoft Windows 98 for PC
My computer's safe mode is not working what is the cause of this problem and how this problem can be solved.
    President:
  • 1,197 Answers
Do you completely power off the computer or just use the Windows
Shutdown command and/or the On/Off power button on the computer?
Try totally shutting off the power by switching off the power bar or
unplugging the power cord from the back of the computer. Leave it for
5 minutes then power it up again.
I just "fixed" the exact same error on a customer's computer this
morning.
When a computer is shutdown but the main power is still live there is
still some standby power being passed to the motherboard. Therefore
some of the motherboard components will have an electronic charge
present and this can cause the problem you have described. By totally
disconnecting the power for 5 minutes the motherboard will discharge
completely, thereby clearing the problem.
Another possbile cause of this type of problem is a USB device, such
as an external USB hard drive or a USB memory stick being left
connected when the computer is powered up. Somehow the boot device
sequence can get corrupted by this presence and the computer tries to
boot from the USB device and fails. Unplug any USB hard drives
and/or USB memory sticks and see if that resolves the issue.
If you can boot your computer normally, there is another way to boot into Safe Mode with Windows
Boot the computer normally.
Close all open programs.
Click Start, and then click Run; the Run dialog box will appear.
Type msconfig in the box and then click OK.
The System Configuration Utility should appear.
Click on the BOOT.INI tab.
Check the "/SAFEBOOT" option, and click OK.
You will then see the prompt to restart the computer, click Restart.
The computer will then restart in Safe Mode.
When another box opens asking if you want to run in Safe Mode; click Yes.
Good luck
Posted on May 08, 2009
Disable safe mode windows
Hello, It is not recommended that safe mode be disabled. Safe Mode is an alternet way that windows can be started in order to solve problems such as drivers that are corrupted and causes Windows in its normal start up state not to start properly. You can think of it as a special diagnostic mode for repairing your computer. Good Day.
Feb 09, 2014 | Computers & Internet
Code error 0xc0000185
Follow these steps
First you should Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
- Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacturer site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing blue screen
Jul 03, 2013 | Sony VAIO Computers & Internet
Blue screen
Which operating system you are using??
You can follow the given steps to avoid blue screen error..
Start Windows in Safe Mode:
Step1: Turn on your computer and press the F8 key repeatedly from your keyboard. You must press F8 before the Windows logo appears. It will display the Advanced Boot Options screen.
Step2: From Advanced Boot Options screen, choose Safe Mode option then press Enter.
Step3: If Windows loads and works fine in Safe Mode, a bad driver is probably causing the error. Uninstall device drivers and reinstall them. If Windows experiences issues in Safe Mode also, repair your hardware.
Startup repair:
Step1: Shut down your computer and then restart it in Safe Mode (see step1).
Step2: From Advanced Boot Options screen, select "Repair Your Computer" and hit Enter. Choose your preferred keyboard layout and then click "Next."
Step1: Click "Startup Repair", and follow the on-screen instruction .Startup repair can solve this problem.
System Repair:
Step1: Follow step1 and step2 from Startup repair section.
Step3: Now select system restore from the System Recovery Options menu. And follow the on-screen instruction to select a restore point.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Jan 24, 2013 | Acer Aspire Computers & Internet
I installed a rompaq update on the laptop and it stopped working. what do i do? the laptop is so dear to me. pls help.
if the laptop was working perfectly before you installed the rompaq update, then it means the rompaq is the cause of the problem.
You need to perform a system restore in order to undo the installed rompaq.
Run your system in safe mode and perform the system restore.
To run system in safe mode, Turn on the computer and immediately, start pressing F8 constantly till a windows booting option shows up. Use the arrow key on your keyboard to select safe mode and press enter, then wait for the windows to load completely.
After the computer and successfully booted in safe mode, go to:
Start > All programs > Accessories > System tools > System restore.
Read and follow instructions. System will restart during the restore process.....
After that try again and observe of your laptop will function/work properly/normally.
Please let me know if this doesn't solve your problem so that I can help you further.
Regards.
Jun 12, 2011 | HP Compaq Evo Notebook N410c
What does Failsafe Engine Mode mean? my manual was stolen
Hello! Fail safe mode is when the vehicle's computer detects a serious problem an allows you to "limp" off the road or highway safely.
Fail safe mode on a Jaguar is mainly caused by a dirty and gummed up throttle body. The throttle body on your auto has a protective coating, so you can not use just any cleaner. It requires a throttle body cleaner that states "safe to use with a protective coating". The butterfly valve in the throttle body will actually "stick out". This causes fail safe mode to kick in reducing the amount of power your engine can produce.
Also check the plugs on your ECM (computer) and make sure they are all seated properly.
Guru...............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Dec 13, 2009 | 1998 Jaguar XJ8L
I need to get my computer off safe mode
when starting, pres simultaniosly f5 and f8
Nov 13, 2009 | Office Equipment & Supplies
Windows failed to start
It seems that you are getting a Blue Screen Error. It is also known as BSOD (Blue Screen of Death).
Try the following steps to resolve this issue
Boot the computer in safe mode - (Restart the computer and keep hitting the F8 key till you get Advance boot options. Select Safe mode.
If you are able to boot your computer in safe mode. Log in as Administrator, It will give you an alert which says the computer is running in safe mode, Click yes on that alert. You will be taken to the system restore screen. Click on next and select a restoration date where everything was working fine. Let the computer restore and restart in normal mode.
In case you are not able to boot the computer in safe mode, Please revert with the exact stop error. You will see a stop error code somewhere at the bottom part of the blue screen.
Sep 03, 2009 | HP Pavilion dv2000t Notebook
Please please help
did you install any new software?
if not then please try to restore your windows installation by the restoration disk provided by your computer manufacturer.
Hope this solves your problem
Apr 16, 2009 | Samsung NC10-14GW Notebook
Computer crashed
by unplugging the adapter has not solved your problem because the driver is the cause of the crash. Try booting in safe mode again, but this time select last known good configuration, or boot in VGA mode(when in VGA mode uninstall the driver in add/remove programmes), if you get into last known good configuration your pc is working as normal. If none of the above work you may have to use your XP cd to do a system repair, if so post back
Sep 30, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Microsoft Windows 98 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
