Question about Air Tools & Compressors
Greetings, I have a Senco SFN-2 finish nailer.. I put a new senco kit in it... It fires upon connecting air to it but then leaks like crazy at the trigger...???? Why, why, why....???? Looking for a diagram or etc.. Where can I find a diagram ????? Glen
    Problem Solver:
  • 5 Answers
You have popped the seal too much air pressure. Ive done it my self lol. diagram dont know sorry but it dont have very many parts should be easy to fix. good luck.
Posted on May 08, 2009
Senco SFN 2 needs part # LB5005 seal and # KB 5061. Where can I get these parts or repair kits?
Best place for Senco parts is www.juldan.com
They have both of these parts in stock with good pricing. Good luck
Apr 09, 2011 | Senco Tools & Hardware - Others
I have a senco coil roof nailer that all of a sudden is leaking air big time and will not coil and fire nails. What parts do I need to replace.
depends on where the air is leaking from. If you go to senco.com and type in your model number you can look at a breakdown and they will list the rebuild kits specific to the leakage, they make an upper o ring kit and a lower kit for this problem. Let me know if you need more assistance or where the air is leaking along with the model number and I will find a number for the rebuild kit. Also the senco kits have detailed instructions on how to install them.
Apr 04, 2011 | Senco Tools & Hardware - Others
Finish Pro 32 is Leaking air out of the exhaust cap
You have worn or broked o-rings/seals inside the gun. The Finish Pro 32 is one of Senco's older guns and they no longer offer a repair kit for this gun. You have to go to a site like www.senco.com or www.ereplacementparts.com, find a breakdown of your gun and order each part you need. If you are going to rebuild the gun order all the o-rings/seals (Senco parts that start with LB) and any other parts that may be damaged like the piston stop, springs, etc. Lubricate the o-rings with light grease as you put them in and make sure to oil the gun regularly when you are using it to make your work last.
Jan 27, 2011 | Senco FINISHPRO32 ProSeries 16 Gauge...
41xp - leaking air out of top headpsp
You have worn or broke o-rings in your gun. You need Senco Kits number YK0361 Firing Trigger System Kit & YK0362 Piston Stop Kit. If you have it apart, replace all of the o-rings and you'll have a new gun. Remember to replace each o-ring as you take them out so you get them back exactly where they need to go and grease them up well with the lube in the kit.
Jan 10, 2011 | Senco FinishPro 42XP 15 Gauge Finish...
SENCO Framing nailer suddenly decided not to fire. Air escapes from top of gun when trigger is pulled
You have some worn/broken o-rings inside the gun. You need Senco repair kit #YK0360 to fix it. Fairly easy to replace the o-rings, just be sure to put lots of lube on the rings as you put it back together.
Nov 29, 2010 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
Air leak top of gun senco oil less coil nailer scw40r. unclehhotmail.comowd@
Nailer scn40r is an oil less coil roofing nailer. If it will not fire and leaks out head then most likely problem is diaphragm torn or pinhole. Replace firing valve part # BAO120 for good as new operation.
Order parts from www.toolpartsdirect.com
Oct 16, 2010 | Senco Tools & Hardware - Others
I have an older model senco finish nailer that continuously blows air out the exhaust what is the problem?
probably a split or stuck o ring. You can go to Senco.com and download a breakdown and purchase a rebuild kit for this tool.
Mar 27, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
Need a kit for the 701XP
which one, they list 2 which are the yk0243 which is the firing/trigger kit and also the YK0244 which is the bumper kit. you can go to Senco.com and find out all the parts included in these kits and order them online from Senco.
Nov 17, 2009 | Senco 2H0033N Framepro 701XP Clipped Head...
Senco finish nailer not firing nails
firing pin called the driver is probably broken or needs new seals max air pressure 125 psi senco sells repair kits
May 13, 2009 | Tools & Hardware - Others
Senco sn2 air leak around out top only when the trigger is pulled
There is a cracked seal on the firing valve. It looks like it cant be replaced but it can. Look in your parts breakdown .It seals the firing valve to the cylinder
Apr 08, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
85 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
