Question about Health & Beauty
Where are kidneys in body - Health & Beauty
Whare are your kidneys
In humans, the liver is located on the right side of the body above the large and small intestines and below the diaphragm and heart. The two kidneys are located on either side of the body behind the intestines and below the liver.
Apr 20, 2017 | Health & Beauty
What causes high potassium
Often, a report of high blood potassium isn't true hyperkalemia. Instead, it may be caused by the rupture of blood cells in the blood sample during or shortly after the blood draw. The ruptured cells leak their potassium into the sample. This falsely raises the amount of potassium in the blood sample, even though the potassium level in your body is actually normal. When this is suspected, a repeat blood sample is done.
The most common cause of genuinely high potassium (hyperkalemia) is related to your kidneys, such as:
- Acute kidney failure
- Chronic kidney disease
Other causes of hyperkalemia include:
- Addison's disease (adrenal failure)
- Alcoholism or heavy **** use that causes rhabdomyolysis, - a breakdown of muscle fibers that results in the release of -- potassium into the bloodstream
- Angiotensin-converting enzyme (ACE) inhibitors
- Angiotensin II receptor blockers (ARBs)
- Destruction of red blood cells due to severe injury or burns
- Excessive use of potassium supplements
- Type 1 diabetes
Mar 14, 2017 | Cooking
Sideeffect cranberry capsule 500mg
Click on the GREEN Side Effects tab.
Cranberry is LIKELY SAFE for most people when taken by mouth appropriately. Cranberry juice and cranberry extracts have been used safely in people. However, drinking too much cranberry juice can cause some side effects such as mild stomach upset and diarrhea. Drinking more than 1 liter per day for a long period of time might increase the chance of getting kidney stones. Special Precautions & Warnings: Pregnancy and baby feeding: There is not enough reliable information about the safety of taking cranberry for therapeutic reasons if you are pregnant or mummy feeding. Stay on the safe side and avoid use.
Children: Cranberry juice is LIKELY SAFE for children when taken by mouth as a food or drink.
Aspirin allergy: Cranberries contain significant amounts of salicylic acid. Salicylic acid is similar to aspirin. Avoid drinking large quantities of cranberry juice if you are allergic to aspirin.
Inflammation of the stomach lining (Atrophic gastritis): Cranberry juice might increase how much vitamin B12 the body absorbs for people with atrophic gastritis.
Diabetes: Some cranberry juice products are sweetened with extra sugar. If you have diabetes, stick with cranberry products that are sweetened with artificial sweeteners.
Low stomach acid (hypochlorhydria). Cranberry juice might increase how much vitamin B12 the body absorbs for people with low levels of stomach acid.
Kidney stones: Cranberry juice and cranberry extracts contain a large amount of a chemical called oxalate. In fact, there is some evidence that some cranberry extract tablets can boost the level of oxalate in the water works by as much as 43%. Since kidney stones are made primarily from oxalate combined with calcium, healthcare providers worry that cranberry might increase the risk of kidney stones. To be on the safe side, avoid taking cranberry extract products or drinking a lot of cranberry juice if you have a history of kidney stones.
CRANBERRY Uses Side Effects Interactions and Warnings WebMD
Dec 27, 2016 | Reaction Watches
Is 82 normal for urea blood test.
a common test
go for it
results covers a lot of possible heath problems
A blood urea nitrogen (BUN) test checks kidney function by measuring how much urea nitrogen is in your blood. Urea nitrogen is a waste product from the breakdown of protein in the body. Normally, this waste is filtered by the kidneys and leaves the body through wee
Blood urea nitrogen BUN test
Nov 24, 2016 | Health & Beauty
What is hydrochlorothiazide
hydrochlorothiazide is a "water pill that causes you to make more water ( go to the toilet a lot more often with out drinking water)
This helps your body to get rid of excess salt and water
this medication also reduces extra fluid in the body (edema) caused by conditions such as heart failure, liver disease, or kidney disease
google . webmd.com/drugs/2/drug-5310/hydrochlorothiazide-oral/details for uses , side effects, interactions, and photos
I suggest that you seriously consider a conversation with a doctor before using it because kidneys, liver and heart are vital organs
May 28, 2015 | Health & Beauty
I HAVE SHRINKING KIDNEY WHAT ARE THE SYMPTOMS
Symptoms of Kidney Shrinkage? Since kidney shrinkage is one indicator of the loss of kidney functioning tissues, patients are more likely to experience several symptoms as follows:
- Swelling: Fluid retention may appear in patients' face, legs, feet, head and some other loose tissues easily.
- Hematuria: Urin presents red, black or tea-colored that means there is blood in urin.
- Back pain: Back or flank pain is indeed one sign of kidney shrinkage.
- High blood pressure: Most often, the worse patients' illness condition, the higher blood pressure.
- Fatigue: It usually results from renal anemia or deposits of uremic toxins.
- Nausea, vomiting, skin itching, or other symptoms
Jan 04, 2015 | Britannica My Body, Myself (LBSCIMYBOJ)
I HAVE SHRINKING KIDNEY AND KIDNEY STONES WHAT ARE THE SYMPTOMS
Kidneys usually remain the same size over your life span.
Unless you have an MRI to measure the kidney size, you can't evaluate the size, and additionally, there must be older evaluations of the kidney in question to equate to changes in tissue size. It could be, one kidney is smaller than the other, but that is not a problem as usual. Stones are a problem. Usually the Diet is the source. Calcium in excess can cause stones, over acidity is a factor, food and drinking water another. Drink a lot of Filtered Water each day. Filtration of the body fluids is done within the Kidneys and more activity is important. You must FLUSH the Kidneys daily and although you may end up piddling a lot more, you save the kidneys and they function better. Less or No Stones over a period of time.
Jan 04, 2015 | Health & Beauty
What Really Is The basis for renal failure?
The many usual factors behind kidney disease are diabetes and high blood pressure (high blood-pressure). Studies show that diabetes causes around half of instances of renal failure, and questionable causes simply over 1 / 4 of instances.
Diabetes
Diabetes is a disorder where the human body doesn't generate enough insulin (type 1 diabetes) or will not make efficient use of it (non-insulin-dependent diabetes mellitus). Our bodies require velosulin since it reduces the glucose (sugars) in our bloodstream as a way to generate saccharide which supplies us with electricity.
In the event your diabetes isn't well-controlled, an excessive amount of glucose (sugars) may develop in your bloodstream. The sugar may subsequently harm the nephrons (miniature filters), which then, influences the skills of your kidneys to filter waste materials and liquids.
Sort 1 diabetes is more inclined to guide to elimination infection. Approximately between 20-40% of people who have type 1 diabetes may create kidney infection by age fifty.
Elimination infection seldom happens typically in the first ten years of diabetes, and between 15-25 years may move before elimination infection happens. Yet, diabetes might be better restrained, and as therapy options for diabetes enhance, the amount of people who have diabetes who produce elimination infection is slowly dropping.
Hypertension
Blood-pressure is a measure of just how much stress is called for by your center to pump the blood through your veins and arterial vessels. A lot of stress will result in heart condition, and can lead to harm to your own human body's organs.
The root of 90% of cause of kidney stones of large blood-pressure (high blood pressure) are not known, but there is apparently a connection involving the status and overall health, diet and way of life
By getting tension to the little arteries in the kidneys harm is caused by high blood pressure. This stops from operating correctly the selection procedure.
Source : http://www.kidneystonesnever.com/
Apr 03, 2014 | Computers & Internet
Whats a healthier choice, cherries or blueberries?
Both of these fruits are very healthy, and each has its' own advantages. For example, blueberries contain more antioxidants and vitamin c, but cherries contain a larger amount of vitamin a, iron, and calcium. Also, blueberries contain a large amount of vitamin k with one serving containing 36% of the RDA (recommended daily allowance).
Jan 17, 2013 | Cooking
Health & Beauty Logo
61 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
