Question about Kodak HERO 7.1 Wireless Color Printer with Scanner Copier
Need to replace cartridge, but can't open lid
  • 96 Answers
Try to find and read the manual from your printer.
Posted on Nov 25, 2013
How tochange the ink cartridge
Open 'Printer properties' and go to 'Maintenance' page. There should be a button called 'Replace ink cartridge'. Click on it and follow the instructions...
Alternatively...if a cartridge is already indicating 'empty', opening the printer lid (with printer power on) should move the cartridges to the 'change position'. Replace the cartridge and close the lid when finished.
Aug 25, 2014 | Epson Expression XP-200 Inkjet...
Lexmarx X4975 disable complete-a-print
The Lexmark X4975 Professional is a multifunction thermal inkjet printer that not only prints documents and photos, but also makes two-sided printouts, scans and copies materials and accepts line-connected or wireless device print requests. Three color ink cartridges--cyan, magenta and yellow--and a single black cartridge rest inside an ink cartridge carrier. Printer cartridge replacement is not difficult. Each cartridge is secured in place with a cartridge carrier lid that opens with the simple press of a lever.
  • Turn on the Lexmark X4975 printer. Lift up the entire scanner unit to rest in an open, angled position that reveals the interior of the printer.
  • 2
    Press down on the lever in front of the printer cartridge that you need to replace to open the cartridge carrier lid.
    • 3 Pull the old cartridge from its slot in the carrier.
    • 4
      Grasp the tab attached to the tape covering the electrical contacts and ink nozzles on the back and bottom of the replacement printer cartridge. Pull the tape away from the cartridge carefully without touching the contacts or nozzles.
    • 5
      Insert the cartridge into the empty slot--the electrical contacts facing the back of the slot inserted before the front of the cartridge.
    • 6
      Flip the cartridge carrier lid over the top of the cartridge and then push down on the top of the lid until you feel the lever lock the lid in place.
    • 7
      Repeat the replacement process with the other printer cartridge if necessary. Lower the scanner back into position when finished.
      Increase Engine Horsepower.
Jun 02, 2012 | Lexmark X4975 3-in-1 Wireless Inkjet...
How do i get to the ink cartrage when i need to replace it
The steps to removing the ink cartridge and replacing it are rather simple. Keep in mind; however, if these steps are not done properly, there are a number of errors that could occur that could keep your printer from printing at all.
The first step is to write down the printer name and brand.
Remove the empty cartridge with care while taking care not to cause any damage to the printer.
If the user already has a replacement cartridge in his possession, then he simply opens the printer's lid while the printer is still on.
Opening the printer's lid when switched on will cause the printer cartridge seats to move into place, allowing the user to remove or reinstall cartridges.
Remove the cartridge with care then replace it with the new cartridge. Close the lid and print a test page.
The one thing to always keep in mind when changing the cartridge is to handle the cartridges with care.
If the user's ink cartridge has a print head, the user must use extra precautions to ensure that no contact is made with it.
If the cartridge has a seal at the bottom, care must be taken not to break the seal.
Nov 24, 2010 | HP DeskJet 940c InkJet Printer
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
Where do I put the replacement cartridges?? I can't see where it goes on this printer???
here is your answer this was found here in your manual if you need it heres a link with picture instructions. start on page 15
MANUAL:
Open the printer, and then press down on the print cartridge carrier levers.
Open the color cartridge foil, and then remove the cartridge from the pack.
Remove the tape from the color print cartridge, insert the cartridge in the right carrier, and then close the color
cartridge lid.
If a black print cartridge is included in the box contents, open the black cartridge foil, and then remove the
Note: You may need to purchase a black print cartridge separately.
14 Remove the tape from the black print cartridge, insert the cartridge in the left cartridge carrier, and then close
Close the printer, and then load plain paper
Mar 26, 2010 | Lexmark X4650 InkJet Printer
Cartridge holder will not go to centre ready for changing
the little rubber belt has skiped a tooth or 2.
u can pull on the belt to fix it but it will do it again.
replace printer
Sep 07, 2009 | Epson Stylus C46 InkJet Printer
Printer 964
Error 0502-Carrier Stall indicates a physically blocked carrier. This condition can occur for many possible reasons. Most often, the carrier is blocked because the ink cartridge lids are open while the printer is on (Figure 1).
Figure 1: Open Ink Cartridge Lids
Reseat the Ink Cartridges and Make Sure the Lids Are in Place
  1. Make sure the printer is turned on.
  2. Lift the printer's front cover.
    new_note.jpg Note: The ink cartridge should be in the up/loading position unless the printer is busy.
  1. Squeeze the tabs on the cartridge lids and lift the cartridge lids up. The cartridge pops up when the lid is fully lifted.
  2. Remove the cartridges.
  3. Make sure that all of the protective tape has been removed from the contacts on the ink cartridge.
  4. Replace the cartridges.
  5. Snap the lids closed.
  6. Close the printer's front cover.
  7. When prompted on the printer's LCD to choose New or Old, choose Old.
  8. Press Select.
new_note.jpg Note: For more information about reseating ink cartridges, refer to the Maintenance or Ink Cartridge Maintenance section in the Online User's Guide.
Back to Top
» Reposition the Encoder Strip
  1. Remove the power cord from the printer.
  2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
  3. Gently slide the ink cartridge carrier to the middle of the printer.
  4. Gently move the top part of the printer belt to the right.
  5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    Figure 1: Inkjet Printer Encoder Strip
  6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
  7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
  8. Once the encoder strip has been re-seated, close the scanner lid.
  9. Re-connect the power cord to the printer.
If this information has not solved your issue, then you have to contact Dell. They may need to replace the printer.
Jul 02, 2009 | Dell Photo 964 All-In-One InkJet Printer
Cover won't close after replacing cartridge
remove cartridge, close lid \
can it close? YES
put in old cartridge can it close ?
Aug 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
1 Make sure the printer is on.
2 Lift the scanner unit until the scanner support keeps it open.
The print cartridge carrier moves and stops at the loading position.
5 Remove the stickers and transparent tape from the bottom of the cartridges.
6 Insert the new cartridge. Make sure the color print cartridge is
secure in the left carrier and then snap the lid closed.
If you are installing a black print cartridge, make sure that it is
secure in the right carrier, and then snap the lid closed.
7 Lift the scanner unit and push the scanner support back while
lowering the scanner unit until it is completely closed.
Mar 02, 2008 | Lexmark X1150 All-In-One InkJet Printer
Kodak HERO 7.1 Wireless Color Printer with Scanner Copier Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
