Question about Garmin nuvi 750 GPS Receiver
Frozen My nuvi 350 is frozen. I know that I can hit the reset button to possibly remedy this (the power button is frozen, too). I just want top make sure that IF I hit the reset button that my favorite locations, etc. will not be erased. My Garmin 750w was working fine. I set it for a location , arrived, was there for about 50 minutes. Got back in car plugged in new location and could not get a satelite read. It has been all day and I still cannot get a read, just a big pink question mark flashing on the little car icon. I do not see any way to reset my system. i am a realtor so I am stressed about this as i have to show properties all week end helpppppppp!!!!!
  • 333 Answers
Doing a soft reset does not erase your information. Only hard resetting. For future reference, you can backup all your favorites etc using the mapsource (from the garmin website) Then if you ever do lose your imformation, you can reinstall it.
Hard reset Just FYI:
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Posted on Sep 15, 2009
My garmin nuvi 660 is frozen . how can I do?
Reset the nuvi 660:
1 Disconnect from external power.
2 Flip antenna up.
3 Locate and press small button labeled "RESET" in the antenna recess on rear of nuvi 660.
4 Connect to external power source.
The nuvi will reset, power up and operate normally. If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 20, 2011 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 255W has been working fine. I
Try resetting your unit with the reset button on the bottom. If this doesn't work, slide the power button all the way to the left and hold it for 8 seconds.
Dec 30, 2009 | Garmin nuvi 255W GPS Receiver
Just used garmin nuvi it worked fine went into the store and now the unit is locked/frozen on the garmin logo screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reset button on your nuvi 2xx, 3xx or 6xx will not restore your device to factory settings or delete any map updates. The reset button will switch your device off if you are unable to switch the device off by the power button. It will not erase any data on the device.
The reset button on your nuvi will switch the device off. The reset button can be used to switch your device off if the screen is frozen and you are unable to switch the device off by the power button.
To reset a nuvi 2xx:
  1. Look at the bottom of the device
  2. Locate the small circle with a dot inside
  3. Press the circle to reset the device.
To reset a nuvi 3xx or 6xx:
  1. Lift the antenna
  2. Locate a button with the word Reset inside
  3. Press the button to reset the device.
The device will now switch off.
Make sure to charge it fully.
Dec 29, 2009 | Garmin Nuvi 660 GPS Receiver
Get frozen old the time my gps garmin 660
if its frozen to the point that it will not turn off, lift the external antenna and push the reset button, then start it up again and see if its ok. if not
make sure its has a good charge,plug it in to the usb port2.gif on your computer for a few hours.
if that fails, try a reset
note: the master reset will erase all your saved data
with the unit off,and unplugged, try pressing and holding your finger on the low right corner of the screen and slide the power switch to the on position until you see the message "confirm if you really want to delete all user data?" hit yes and let it restart. then it will set up the nuvi again, so follow the prompts.
hook up the nuvi to the web updater and get the latest update
you can get the Web Updater HERE
bill
Nov 06, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 350 screen iz frozen. reset did not help.
Look near the SN # and press the reset button.
or
Aug 20, 2009 | Garmin Nuvi 350 Car GPS Receiver
Won't turn off, frozen screen
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try "resetting" it.
  2. Locate the small circle with a dot inside (very small)
  1. Lift the antenna
Jul 25, 2009 | Garmin nuvi 260W GPS Receiver
After trying to install new maps, Garmin nuvi 350 don't start
or
Nov 30, 2008 | Garmin nuvi 350 GPS Receiver
Frozen
The reset button on the back will NOT erase your favorites. That would require a hard reset (wipe user data) to do that.
- Jim
Sep 13, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi frozen
Did you press the reset button located under the antenna?
Jul 02, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin 660 locked up / frozen
Resetting the device merely resets the power connection, on some devices there is a reset to manufacturer defaults on settings, but not your stored data. Working with GPS's 40 hours a week I constantly have to use the reset button when they lock up. Just press it in for a few seconds then if it doesn't power back up just hit the power button and everything should be fine.
May 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 750 GPS Receiver Logo
173 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
